How do old-timey radio buttons work?
  • Thread starter DaveC426913
  • Tags
    Radio
In summary: The system shown at A uses a finger and a rocker to set the tuning frequency. The finger is attached to a plunger that can be tightened to keep it at a fixed position. To set up a button for a station, the plunger is loosened so the finger can rotate. The button is pushed all the way in, the station is tuned in manually, and the screw is tightened to lock the finger at the correct angle. A spring returns the button to its normal position.The system shown at B uses a rocker to set the tuning frequency. The rocker is attached to a plunger that can be tightened to keep it at a fixed position. To set up a button for a station, the plun
DaveC426913
6,168
Back when dinosaurs roamed the Earth, every car had a push-button radio like this:
You pushed a button and the dial would zoom to the preset location.
To set a location, you would manually dial to the right location, then pull the button out, then push it in.
I had set my sights on figuring this out from first principles - perhaps examining on old radio from the local electronics surplus store but never got around to it.
My pride to figure this out on my own has waned, and now I just want to know what I was missing.
How does the mechanism work?
I'm old enough to remember that the tuning knob moved a string loop that wrapped around the shaft of a rotating variable capacitor. The buttons moved the string, but I don't remember how they recorded the position.
Yep, That's about my understanding too.
It was the 'setting' part that got me.
Pull button, releasing string, snap button closed on new setting. One way; seems to my recollection(s), there were a couple other mechanisms.
When manual tuning is done, the dialcord rotates the funny cage assembly consisting of two rods between end plates.
Pulling the pushbutton out releases a brake on the blade allowing the blade to pivot.
When the pushbutton is pushed, the blade rotates to match the two bars on the cage assembly.
Further force on the pushbutton engages the brake on the blade, not allowing further rotation.
To tune to another preset station, the appropriate pushbutton is operated, forcing its blade against the rotatable cage assembly, pulling the dialcord to the preset position.
MAGIC! You now are now tuned to the new station.
EDIT: Clarification from post #12 below (thanks to @DaveC426913 for point this out):
The diagonally oriented part to the upper right is the front view of the 'funny cage assembly' (in the real world it is horizontal ). The rest is a view from the left side of the radio.
The left-most piece in the dwg. is the left end of 'funny cage'.
Cheers,
Tom
Greg Bernhardt said:
I feel like @dlgoff would know :)
I've seen the string type that rotates a variable capacitor for changing the frequency of a tuning oscillator. I looked around for an old car radio but could only find this set of push-buttons from, IRC, an old table-top radio. With this type, each button switches in different LC tuning circuits. The switches circuit board is made of a Phenolic Paper material which is a type of Bakelite. Note that the buttons have windows where labels of the station's call-sign can be inserted.
The mechanical mechanism is rather complicated but still works, sort of:
I know I have an old push-button car radio somewhere. I'll keep looking.
Likes Bystander, Greg Bernhardt and jim mcnamara
This suggests a fun thread that might get wide participation.
"Mechanical replacements for familiar electric gadgets."
Years ago it would have been, "Electric replacements for familiar mechanical gadgets." But today, I think the "familiar" balance has flipped.
There is also "Digital replacements for familiar gadgets." But we already did that under https://www.physicsforums.com/threads/what-do-smart-phones-partially-replace.932077/
In AM only radios I believe it was typically variable inductors that did the tuning.
Likes Tom.G
Cheers,
Tom
Thanks. I'm mostly there.
I'm having trouble divining orientation from your beautiful diagram. It's hard to tell the difference between discrete parts and different views of the same part.
A system similar to the one described by @Tom.G :
The diagrams at A and B show one of the finger and rocker units used in the mechanical automatic tuning systems of some Crosley receivers (including the Crosley Safety-Tune auto radio), while the sketch at C shows the complete tuning unit with a gear drive to a gang tuning condenser. Tightening the screw on the plunger locks the finger rigidly in position. To set up a button for a station, this screw is loosened so the finger can rotate, the button is pushed all the way in, the station is tuned in manually, and the screw is tightened to lock the finger at the correct angle. A spring returns the button to its normal position when pressure is released, leaving the tuning condenser at the correct setting for the desired station.
Other systems descriptions can be found from the source of this quote.
Likes dlgoff
Yeah, not as clear as it could be. :sorry:
Clarification duly added to post #6.
In both my '49 Buick and '53 Ford that was indeed the case. I'm not sure why but i think it had to do with the proneness of those variable capacitors to trap dust in their plates and detune.
In those days car radios were made for extreme sensitivity so that you could get decent reception far away from the cities.
To that end most had a tuned RF stage ahead of the mixer, meaning you'd need a three or four gang tuning capacitor.
Probably it was quicker to manufacture using pre-adjusted tunable inductors instead.
My Ford radio had a single ended 6V6 pentode audio output stage that was adequate - probably around five watts.
The Buick (a Roadmaster), being an upscale car used two 6V6's in push pull . Judging by output transformer size i'd guess it was good for fifteen watts. That would be the envy of tubophiles today.
I saw one of those radios recently in a junkpile - should have picked it up just to salvage its output transformer.
Sigh, something told me to snag it and if i had i could answer your question about the pushbuttons...
old jim
Likes dlgoff
Ohhh. Now I see it.
And now I see it in Tom G's diagram.
The only thing I can't quite make out is the brake release. I think the brake is (G), and it presses on the finger, holding its setting. When you pull the button out, it releases the brake, so that the finger can rotate freely. Then you push it in, the finger is set by the pivot plate (F) and the brake is reapplied.
Man, I wish I had some simple animation software. I'd animate this.
I recall being told in school that the reason was dust.
Should have picked it up to restore. :oldgrumpy:
Likes jim hardy
1. What are "Oldey-timey radio buttons"?
"Oldey-timey radio buttons" are a type of user interface element used in early radio devices and mechanical calculators. They are small, circular buttons that can be pressed to select a specific option.
2. How do "Oldey-timey radio buttons" work?
When one button is pressed, it physically moves to a different position, indicating that it has been selected. At the same time, it also ensures that all other buttons are in the "off" position.
3. What is the purpose of "Oldey-timey radio buttons"?
"Oldey-timey radio buttons" were used as a simple and efficient way to select between a limited number of options without the need for a more complex interface. They were commonly used in early radio receivers and mechanical calculators.
4. Are "Oldey-timey radio buttons" still used today?
While they are not commonly used in modern technology, "Oldey-timey radio buttons" can still be found in some devices, such as vintage-style radios or calculators. However, they have largely been replaced by digital buttons and touch screens in most modern devices.
5. What are the advantages of "Oldey-timey radio buttons"?
One of the main advantages of "Oldey-timey radio buttons" is their simplicity and ease of use. They require minimal instruction and can be operated easily without any prior knowledge or training. They also do not rely on electricity or complex circuits, making them durable and long-lasting.
  • Electrical Engineering
  • Mechanical Engineering
  • STEM Career Guidance
  • Computing and Technology
  • STEM Academic Advising
