Can 4-velocity Have Negative Component in Curved M?
  • Thread starter c299792458
In summary, a negative zeroth-component of a four-velocity V^0 with a curved space metric of signature -+++ allowed?
c299792458
71
Is a negative zeroth-component of a four-velocity [itex]V^0[/itex] with a curved space metric of signature [itex]-+++[/itex] allowed?
I assume we're talking about timelike vectors. A spacelike vector that had a positive timelike component in one frame could have a negative one in a different frame. I think the question is better posed as whether we can prohibit velocity vectors from lying in a certain side of the timelike light cone.
If we restrict ourselves to timelike vectors, then any velocity vector can represent the frame of reference of an observer.
Mathematically either side of the light cone is certainly allowed, because this is a vector space, and one of the axioms of linear algebra is that if v is a vector, there's a vector -v.
Physically, SR is time-reversal invariant, so there is no fundamental physical distinction between the forward and backward directions of time. Therefore there is no fundamental way to state a prohibition on velocity vectors that point a certain way instead of the opposite way. GR inherits all the same local symmetries as SR, so this applies to GR as well. (Spacetimes in GR don't even have to be time-orientable.)
There are reasons that we have an arrow of time, but those reasons can't be found within the fundamental kinematical laws of relativity.
There is at least some kinematical guarantee of sanity, which is that a timelike geodesic always stays timelike. That implies that in SR an inertial observer will never have a velocity vector that wanders from one side of the light cone to the opposite side. (To do that, it would have to pass through the spacelike region.)
For particles, you can interpret this kind of thing in terms of matter/antimatter symmetry, i.e., flipping the velocity four-vector of an electron makes it an antielectron.
Thank you, bcrowell!
1. Can 4-velocity have a negative component in a curved spacetime?
Yes, 4-velocity can have a negative component in a curved spacetime. This is because 4-velocity is a mathematical concept that represents the rate of change of an object's position in a 4-dimensional spacetime. In a curved spacetime, the concept of "positive" or "negative" components becomes more complex as the geometry of spacetime is affected by the presence of massive objects.
2. What does a negative component of 4-velocity indicate?
A negative component of 4-velocity can indicate that an object is moving in a direction opposite to the orientation of the coordinate system being used. This can be due to the curvature of spacetime or the presence of strong gravitational fields. It is important to note that negative components of 4-velocity do not necessarily indicate a decrease in speed, but rather a change in direction.
3. Is it possible for an object to have a negative 4-velocity?
No, an object cannot have a negative 4-velocity. 4-velocity is a mathematical concept that represents the rate of change of an object's position in spacetime. It is always a positive quantity, as an object cannot have a negative rate of change in its position. However, a negative component of 4-velocity is possible in certain situations, as explained in the previous answers.
4. How does the curvature of spacetime affect 4-velocity?
The curvature of spacetime affects 4-velocity by changing the concept of "straight line" in a curved spacetime. In flat spacetime, a straight line represents constant velocity, but in a curved spacetime, a straight line represents the path of an object under the influence of gravity. This means that an object's 4-velocity will change as it follows the curved path of spacetime, resulting in a negative component in some cases.
5. Are there any real-life examples of negative 4-velocity?
Yes, there are real-life examples of negative 4-velocity. One example is the orbit of a satellite around a massive object like the Earth. The satellite's 4-velocity will have a negative component as it moves in the opposite direction of the Earth's curvature. Another example is the motion of light around a black hole, where the curvature of spacetime can result in negative components of 4-velocity for the light particles.
