Wavefunction of Two Particles: Intuitive Explanation
In summary, the concept of wavefunction of a system is not always a simple product of the individual wavefunctions of its components. In cases where the two systems are not correlated, it is valid to use the product of their individual wavefunctions as the wavefunction of the joint system. However, in cases of correlated systems, the wavefunction of the joint system is a more complex function that takes into account the correlation between the two systems. This concept is derived from the probability theory and is applicable in quantum mechanics.
Alpharup
225
In my electronics engineering program, we have topics on quantum mech, statistcal mech and so on(only intuitive treatment, not mathematical)...We follow'Introduction to modern physics' by Sir Arthur Beiser. I have a small doubt in the wavefunction of a system..
Let a system consist of two particles A and B and let their wave-fuctions by ψa and ψb respectively..Let ψc represent the wavefuction of the system..
In this book, it is given that
ψc is a product of ψa and ψb..
How is this possible?
We have learned about the probability of existence of a particle by integrating the wave-function..Does this concept have anything to do with the wavefunction of the system..
Please explain me in an intuitive way without tough mathematics..
The wavefunction of the system is not forcedly the product [tex]\Psi_a(x)\Psi_b(y)[/tex]. It is the case only for separable systems, in general the wave-function of the system is a function of 2 coordinates set [tex]\Psi_c(x,y)[/tex].
The reason is that in the probability theory, when we have no reason to believe that states of two systems A, B are correlated, the best choice for joint probability for the joint system is the product of the probabilities for the parts.
Then, the probability density for state where the particle ##a## is at ##\mathbf r_a## and the particle ##b## is at ##\mathbf r_b## is:
\rho_c(\mathbf r_a, \mathbf r_b) = \rho_a(\mathbf r_a) \rho_b(\mathbf r_b),
where ##\rho_a## describes probability density for the particle ##a## and so on.
Since in wave mechanics the probability densities for one-particle systems are given by the Born rule
\rho_a(\mathbf r_a) = |\psi_a(\mathbf r_a)|^2,
\rho_b(\mathbf r_b) = |\psi_b(\mathbf r_b)|^2,
\rho_c(\mathbf r_a, \mathbf r_b) = |\psi_c(\mathbf r_a, \mathbf r_b)|^2,
if we think the two systems are not correlated, we can derive
|\psi_c(\mathbf r_a, \mathbf r_b)| = |\psi_1(\mathbf r_a) \psi_2(\mathbf r_b)|.
Usually the absolute values are not required, either because we just need any two-particle function for construction of a basis and we just take the simplest one formally, or since it is assumed that the phase factor will not influence results. Then we arrive at function ##\psi_c## for joint system you have seen in Beiser.
To illustrate the difference between correlated and uncorrelated systems, let's use the symbol ##\psi_1(\mathbf r_a)## for psi function describing the system A and ##\psi_2(\mathbf r_b)## for the function describing the system B.
With these, we can construct psi function
\psi_c(\mathbf r_a, \mathbf r_b) = \frac{1}{\sqrt{2}} \left[ \psi_1(\mathbf r_a) \psi_2(\mathbf r_b) + \psi_1(\mathbf r_b) \psi_2(\mathbf r_a)|\right]
which we may use to describr the joint system. This function is not simple product of the two functions for particles, and if you calculate ##\rho_a, \rho_b, \rho_c## from the Born rule above, you will see that also the probability density for the joint system is not product of the corresponding one-particle probability densities. Such function ##\psi_c## describes correlated states, where the state of system A (position ##\mathbf r_a##) is correlated with the state of the system B (position ##\mathbf r_b##). Such psi functions come out as solutions to the Schoedinger equation
\hat H \psi_c = E\psi_c,
for the joint system, for example.
1. What is a wavefunction?
A wavefunction is a mathematical description of the quantum state of a particle or a system of particles. It provides information about the position, momentum, and other physical properties of the particles.
2. What is a wavefunction of two particles?
A wavefunction of two particles describes the quantum state of a system consisting of two particles. It takes into account the properties of both particles and how they interact with each other.
3. How is the wavefunction of two particles represented?
The wavefunction of two particles is typically represented as a mathematical function with two variables, one for each particle. This function is known as a two-particle wavefunction or a biwavefunction.
4. What does the wavefunction of two particles tell us?
The wavefunction of two particles provides information about the probability of finding the two particles in a certain state or location. It also gives insight into how the particles are correlated and how they interact with each other.
5. What is the importance of understanding the wavefunction of two particles?
Understanding the wavefunction of two particles is crucial for understanding the behavior of quantum systems and predicting their outcomes. It is also essential for developing technologies such as quantum computing and quantum communication.
  • Quantum Interpretations and Foundations
  • Quantum Physics
  • Quantum Physics
