One hard integral
Solve
[tex]\int^{\infty}_0\frac{\sin x}{\sqrt{x}}[/tex]
[tex]\lim_{t\to \infty}\int^{t}_0\frac{\sin x}{\sqrt{x}}[/tex]
[tex]\sqrt{x}=v[/tex]
so
[tex]\lim_{t\to \infty}\int^{t}_0\frac{\sin v^2}{v}[/tex]
Integration by parts maybe? What is idea?
Answers and Replies
ehild
15,543
1,915
Do not forget dx from the integral. When substituting, you need to transform dx too.
ehild
Mistake
I will get
[tex]2\int^{\infty}_0\sin v^2dv[/tex]
SammyS
Staff Emeritus
1,124
Mistake
I will get
You will get [itex]\displaystyle \int^{t}_0\frac{\sin x}{\sqrt{x}}\,dx=2\int^{\sqrt{t}}_0\sin (v^2)\,dv\,. [/itex]
But t goes into [tex]\infty[/tex] so I write in correct way last step.
Have you been introduced to the idea of using contours in the complex plane to solve integrals on the real line? Because if you have, that seems like the simplest way to solve this.
HallsofIvy
41,847
969
No, not every problem has a trivial solution!
Is there some other way?
Nope, have you been introduced to the idea I mentioned? I find it hard to believe that this question would be set if you haven't...
lurflurf
2,445
140
[tex]\int^{\infty}_0\frac{\sin x}{\sqrt{x}}=\lim_{a\rightarrow 0^+}\int^{\infty}_0 \frac{\sin x}{\sqrt{x}}e^{-a x}=\lim_{a\rightarrow 0^+}\sqrt{\frac{\pi}{2(a^2+1)(a+\sqrt{a^2+1})}}[/tex]
Complex methods are not the only way to do integrals.
or
The complex part of complex methods to do integrals can be hidden.
Depending on ones perspective.
I like Serena
6,579
178
Ok. But I would like to see some trick how to calculate this integral in the desert island :)
I would expect you to have a table of standard integrals or something in which this one is included.
or
And how you get
[tex]\int^{\infty}_0 \frac{\sin x}{\sqrt{x}}e^{-a x}dx=\sqrt{\frac{\pi}{2(a^2+1)(a+\sqrt{a^2+1})}}[/tex]
I like Serena
6,579
178
or
Looks like a Laplace transform.
Seems to me that it's not trivial to calculate it yourself.
Did you use some table to find the transform?
lurflurf
2,445
140
We want to get rid of the 1/sqrt(t) so substitute
[tex]\frac{1}{\sqrt{t}}=\frac{2}{\sqrt{\pi}}\int_0^{ \infty } e^{-s^2 t}ds[/tex]
then interchange s and t integrations
[tex]\int^{\infty}_0 \frac{\sin(b t)}{\sqrt{t}}e^{-a t}dt=\frac{2}{\sqrt{\pi}}\int_0^{ \infty }\left\{\int_0^{\infty}\sin(b t)e^{-a t}e^{-s^2 t}dt
\right\}ds=\frac{2}{\sqrt{\pi}}\int_0^{ \infty } \frac{b}{(s^2+a)^2+b^2} ds=b \cdot \sqrt{\frac{\pi}{2} \cdot \frac{1}{(a^2+b^2)(a+\sqrt{a^2+b^2})}}[/tex]
[tex]\int^{\infty}_0 \frac{\cos(b t)}{\sqrt{t}}e^{-a t}dt= \frac{2}{\sqrt{\pi}}\int_0^{ \infty }\left\{\int_0^{\infty}\cos(b t)e^{-a t}e^{-s^2 t}dt
\right\}ds=\frac{2}{\sqrt{\pi}}\int_0^{ \infty } \frac{s^2+a}{(s^2+a)^2+b^2} ds=\sqrt{\frac{\pi}{2} \cdot \frac{a+\sqrt{a^2+b^2}}{a^2+b^2}}[/tex]
That last integral is messy, but it can be done with usual elementary calculus methods and functions. These might be in some Laplace transform tables though often some manipulation is required to get the right form.
dextercioby
Insights Author
13,194
764
Nice trick, lurflurf. But residue theorem leads to a quicker solution, though. Anyway nice post. :)
Related Threads on One hard integral
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
