CompSci
- 9
- TL;DR Summary
- Is the one way speed of light constant?
Is there any reason to believe that the one way speed of light is constant? Not isotropic, but constant in the sense of being independent of position.
It is a postulate of special relativity that the one way speed of light is constant (although it takes a bit of care to state the postulate precisely). Theories based on other assumptions can be constructed, but all that are consistent with observations are more complicated, require other assumptions that are less palatable, and make no testable predictions that special relativity does not. Thus there are no good reasons not to proceed as if the one-way speed of light is constant.CompSci said:Is there any reason to believe that the one way speed of light is constant? Not isotropic, but constant in the sense of being independent of position.
The term for that is homogeneous. Usually “constant” refers to being independent of time.CompSci said:Summary:: Is the one way speed of light constant?
Einstein essentially defined it to be constant, homogeneous, isotropic, and frame invariant. You can define it other ways if you like - it turns out to be just a matter of choosing a non-trivial coordinate system. An obvious example is a rotating coordinate system, where the coordinate speed of light varies with radius.CompSci said:Summary:: Is the one way speed of light constant?
The only consequences are to coordinate systems. Not to observation or experiment.Mister T said:But it's an assumption that has consequences.
jbriggs444 said:The only consequences are to coordinate systems. Not to observation or experiment.
Nonetheless, it’s an an important consequence - relativity is by far the cleanest and most elegant formulation of the physics.Mister T said:Ah, yes. Of course. Because it depends on a simultaneity convention.
The One Way Speed of Light refers to the speed at which light travels in a single direction, without taking into account the round-trip time. It is an important concept in physics and is commonly denoted by the symbol "c".
According to the theory of special relativity, the One Way Speed of Light is believed to be constant in all inertial frames of reference. This means that regardless of the speed of the observer or the source of light, the speed of light remains the same.
The One Way Speed of Light can be measured using various methods, such as the use of interferometers or the measurement of the time it takes for light to travel between two points. These measurements have consistently shown that the speed of light is indeed constant.
The concept of the One Way Speed of Light is important in understanding the fundamental principles of physics, particularly in the theory of special relativity. It also has practical applications in fields such as telecommunications and astronomy.
Currently, there is no evidence to suggest that the One Way Speed of Light is not constant. However, there are some theories, such as the Variable Speed of Light theory, which propose that the speed of light may have varied in the past. These theories are still being studied and debated in the scientific community.
