B One way twin
  • Thread starter Buckethead
PeroK
Insights Author
2018 Award
9,402
3,428
But 1) and 3) do not take place at the same position relative to A as the acceleration in the simple case, assuming the same total space time intervals for both scenarios.
I really don't see why not. We're assuming that B executes some sort of periodic motion: half a cycle in the simple case and 1.5 cycles in the next case.
The difference in differential ageing between the scenarios must be less than the time for the periodic motion. As with all twin paradox scenarios, there are small variations based on how many acceleration phases B has.
To clarify: Are you assuming that A will age the same amount in B's frame during these two accelerations?:
S1: Single acceleration in the simple scenario
E3: 3rd acceleration in the extended turnaround scenario
Yes, of course, these are physically identical.
A.T.
1,423
We also assumed the same total space time interval (path length) for all cases, so with more periods the amplitude (maximal separation has to be less).
The aging of A in B's non-inertial frame depends on the spatial separation of A and B. Since the separation is less for E3 than for S1, A will age less in B's frame during E3 than during S1, even if B's proper acceleration and acceleration duration are the same for E3 and S1.
PeroK
Insights Author
2018 Award
9,402
3,428
The aging of A in B's non-inertial frame depends on the spatial separation of A and B. Since the separation is less for E3 than for S1, A will also age less, even if the proper acceleration and duration are the same.
You keep saying that but what prevents B from executing the same acceleration when he reaches the same distance from A? Why does B have to be closer? And why does be have to be significantly closer? If I specify the turnaround distance for B as ##1m## and I concede that E3 takes place ##2m## closer to Earth. I have no idea why, but let's accept that E3 must take place ##2m## closer to Earth than S1. These distances are negligible in the context of 4 light years. That is going to make a negligible variation to the ##6.4## years.
Please tell me why B cannot execute SHM as many times as he pleases? Back and forward the same mean distance from A? Why is SHM impossible in the twin paradox?
I only posted this idea to highlight an issue with the "acceleration causes ageing" interpretation. I didn't expect an argument on the physical feasibility of B changing direction more than once.
You must be fundamentally misunderstanding what I'm saying.
PeroK
Insights Author
2018 Award
9,402
3,428
Can you provide your analysis of the differential ageing assuming that A ages 6.4 years as a result of the first turnaround? What happens quantitatively if B changes direction linearly twice more? Why do subsequent changes of direction have mininal effect on the ageing of A?
Assume that any subsequent changes of direction of B take place in less than 1 day (in A's frame). Please show why no further significant ageing of A takes place, unless the overall journey itself is significantly extended (in A'a frame).
Please, let me see your analysis.
A.T.
1,423
I explained that here:
27,812
4,271
That can't be right. The differential ageing relative to Terence can't depend on the number of changes of direction.
But it can depend on the distance between them at the turnaround.
PeroK
Insights Author
2018 Award
9,402
3,428
What stops B making repeated changes of direction (over a relatively short time) in the vicincty of the initial turning point?
PeroK
Insights Author
2018 Award
9,402
3,428
Obviously it's the same give or take a day or two for the various acceleration phases - as it always is for the twin paradox. It's a proper time of ##6## years (give or take an arbitrary variation for the turnaround(s)).
Obviously, if B does additional accelerations that will take a small amount of proper time. But that cannot explain additional differential ageing of 6.4 or 6.3 years or whatever.
vanhees71
Insights Author
4,593
But for the one way example here, there is no way to avoid a synchronization assumption, because that is the sole determinant of what the start event is for the mars clock. There is only one incident of colocation. The interval beginnings are determined solely by a synchronization decision, which can be a physical procedure, thus invariant, but it is still a choice, and effectively defines a frame.
Then the problem is insufficiently defined. You have to clearly define everything in physical terms, i.e., in terms of physically defined events to begin with.
A.T.
1,423
Where does this "additional differential ageing of 6.4 or 6.3 years" come from?
PeroK
Insights Author
2018 Award
9,402
3,428
This is getting just silly now. I've explained a simple scenario in excruciating detail and all you're doing in nitpicking the details.
I don't know what this is all about now.
jbriggs444
7,316
2,457
I've lost track. I think it was part of a reductio ad absurdum argument to the effect that one should not attribute differential aging to acceleration.
The following narrative is how I reconstruct it:
There were two claims. One was that the progress of the stay-at-home twin from the point of view of the travelling twin would always be in the forward direction. The other is that the "point of view" of the travelling twin is always accurately reflected by an instantaneously co-moving inertial frame.
If we accept the former claim then, during periods of forward acceleration (by B away from A), A's clock advances. In effect the former claim acts as a ratchet. [This claim is arguably correct -- in any valid coordinate chart, it will hold].
If we accept the latter claim then, during periods of reverse acceleration (by B toward A), A's clock advances by 6.3 or 6.4 years each time. [This claim is also arguably correct. If we look at the "time now" on A's clock in the after-acceleration frame, it will be 6.3 or 6.4 years advanced from the "time now" on B's clock in the before-acceleration frame]. I think that @PeroK proposed trip details to arrive at those numbers.
If one accepts both claims together, then one might conclude that the stay-at-home twin's elapsed time will have advanced by a total proper time equal to the number of turnarounds multiplied by 6.3 or 6.4. That conclusion is obviously false -- so something has gone wrong.
One way of looking at what went wrong is that the sequence of instantaneous tangent inertial frames do not fit together to create a valid coordinate chart covering A's world line. The first claim only holds for valid coordinate charts. The error in the analysis is pretending that the "traveler's frame" both covers A's world line and uses a synchronization convention that matches B's sequence of tangent inertial frames.
One can build an accelerated frame around B's world line and extend it to encompass A's world line. But the attribution of differential aging based on using that frame will come as much from the details of the frame as from B's acceleration profile.
25,257
6,389
Ok, so it looks like I'm going to have to point out what @jbriggs444 predicted I would point out. :wink:
It seems logical that if the first turnaround caused A to age by 6.4 years, then so must the third change of direction.
It might seem logical, but it's not valid, because the implicit reference frame you are using is not valid. Once you have multiple turnarounds, or orbits, or whatever, the reference frame you are implicitly using to make statements like "A ages 6.4 years during the first turnaround) is not valid for such statements because it no longer validly covers A's worldline: the mapping from the frame's time coordinate to events on A's worldline is no longer one-to-one. (It is for the case of a single turnaround with no orbits, but only for that case.)
The deeper root cause of this problem is being unwilling to give up the intuition that there should be some fact of the matter about A's "rate of aging" relative to B. There isn't. That's what relativity tells us. The only invariant in the problem is the comparison of elapsed times when the twins meet again. There is no invariant that corresponds to A's "rate of aging" relative to B (or B's relative to A, for that matter). So statements like "A ages 6.4 years during the turnaround" aren't statements about physics; they're statements about some human's choice of coordinates. (And if the choice of coordinates isn't a valid coordinate chart, they're not even well-defined statements.) You can do all the physics without ever having to make such statements, so why make them at all?
PAllen
1,012
Well, you can use a physical procedure to define a frame. Einstein clock synchronization is a physical procedure, and if you specify two bodies with attached clocks performing it, the result of the procedure is frame independent, but at the same time, it effectively defines a frame based on those two bodies. The beginning events in a one way scenario are defined by a choice of bodies to perform this operation.
25,257
6,389
It's about answering the question: "How does the whole process look like in the rest frame of the traveling twin?",
And if you insist on asking that question, even though, as I pointed out in my previous post just now, you can do all the physics without doing so, then you first have to construct a consistent "rest frame of the traveling twin" that covers all of A's worldline during the trip. And the frame @PeroK is implicitly using when he talks about A "getting younger" in a scenario with multiple turnarounds or orbits does not. There are multiple ways of doing so that do cover A's worldline, but none of them will have the property that "A gets younger" during any part of the trip.
25,257
6,389
But it only works for a pair of bodies that are (a) in free-fall inertial motion, and (b) at rest relative to each other. That's a severe limitation.
I’m confused on this point. If A and B are both radioactive, won’t their relative compositions differ when they meet again? Won’t this problem now affect A & B’s invariant mass in addition to their elapsed time?
25,257
6,389
Yes, that's a consequence of the invariant I described: the comparison of elapsed proper times. But you're adding an element to the problem that nobody in this thread was including. See below.
Doesn’t this now affects A & B’s invariant mass?
This is just quibbling. Nobody has been talking about radioactive objects, or indeed objects undergoing any kind of change. We're just talking about the twin paradox. Throwing in a complication like what will happen to radioactive substances is irrelevant to the topic of the thread. If you want to know what happens to the invariant mass of a radioactive object over time, start a separate thread.
PeroK
Insights Author
2018 Award
9,402
3,428
I thought that was my whole point. That A's rate of "ageing" (it was always in quotes in my earlier posts) relative to B is meaningless.
I still think the whole idea that "acceleration of B causes A to age" is not a valid concept. Even if you can justify it with a caveat that "it only works once". It's not an explanation for differential ageing that has any physical significance, as far as I can see.
Perhaps my argument against it overlooked deeper problems with coordinate systems. But, if B makes an elaborate interstellar journey then the differential ageing can still be simply computed by the integral of the speed in A's frame. Attempts to attribute differential ageing to acceleration and time dilation in B's frame are fundamentally flawed.
PAllen
1,012
So what? That is exactly what is needed to specify the OP scenario to make it fully defined.
DaveC426913
1,633
What I was attempting to analyse was the "acceleration causes ageing" interpretation of the twin paradox. I was trying to highlight an issue with this interpretation.
Ah. Then we are in agreement.
It only depends on the velocity of the traveling twin. If that person gets anywhere near the velocity of c (compared to the universe), that person will suffer from time dilation and will lose some heartbeats, etc in aging. So that person will be younger. However, the twin on earth is also traveling at a decent speed within the universe. So it needs to be that the one going to Mars has a much faster velocity relative to the universe and something significant against c. I do not think acceleration has anything to do with time dilation directly.
Ibix
Insights Author
4,981
3,288
This is not correct. In a standard twin paradox, where one twin is inertial and one twin travels out-and-back then it's the speed of the traveller relative to the inertial observer that matters. In the "one-way" version under discussion here there is no unique answer.
"Speed compared to the universe" is not a well-defined concept.
Mister T
621
All that matters is the relative speed of the twins. And the speed need not be anywhere near ##c##. Modern clocks are precise enough to see the effect when the speed is a very tiny fraction of ##c##.
Want to reply to this thread?
"One way twin" You must log in or register to reply here.
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
Hot Threads
