Wave-Only Existence: Possible or Not?
In summary, waves need energy to exist and any matter that carries energy (even a wave) has more mass than it would if the wave was not there.
lazer
Is there anything that can be considered just as a wave and not a particle or any wave that does not have particle?
How about a water wave?
is it just wave.. it needs particle to exist
Not in the way I think you are meaning, no. Then again the closer you look the more the words 'wave' and 'particle' get blurry.
A wave in a continuous medium does not require the existence of particles to exist.
A wave in continuous medium can still be quantized and considered a collection of particles, though. E.g. phonons. Any linear wave has particle properties, and any sufficiently small disturbance can be linearized. So the real answer is no, you can't really come up with anything that's just a wave.
Of course it can but I said it doesn't require discretisation which is the criterion.
i have been thinking of it and i just felt this way: I think it is not possible to have anything like just wave because I do not think there can be any wave without energy. when there is energy there is mass. mass is a matter.. hence a particle.. may be not sure..
Depends on how you define a wave.
The wave equation doesn't require mass or even time for the time independent version.
It could be just squiggles on a piece of paper.
However if you want mass how about a vibrating string?
The entire medium forms the wave and the analysis does not require the separate existence of oscillating particles within the string.
You may be partially correct. All waves carry energy and have thus the system they are in has more mass than it would if the wave was not there, however mass does not make something a particle. If you take a jar of mayonnaise and heat it up it would have more energy and thus more mass but not more matter, so you would still make the same amount of delicious fried egg and mayo sandwiches as if it were cold. Is anyone else hungry now?
Careful, standing waves do not carry energy although the possesses energy. Their energy stays in one place.
That is how I am using the word "carry". To have energy, to possesses it. Is this incorrect?
So long as it is clear to all I don't think it matters.
Travelling waves transport energy from the source to the end of the wave (ie the wave front). So until the energy is dissipated it is always traveling outwards away from the source and must be replenished by the source for the wave to keep going.
Standing waves do not transport energy. So once established the wave does not need further input of energy (dissipation apart).
Waves as squiggly lines on a piece of paper need no energy at any stage.
Well, what about the discrete molecules of water that comprise such a wave?
But -- can you give an example of a continuous medium that actually exists?
a distinction without meaning.
If I stand still with a bucket of water, am I "carrying" it?
nope.
In general, any matter [such as a particle] has an associated wave [the deBroglie wave] and a 'particle' can be considered a quanta of a wave. So for example, a photon is a quanta [particle] of light [which is an electromagnetic wave] .
No more than I can give an example of a perfect straight line or a frictionless surface etc etc that actually exists.
However any theory must be valid for such thought constructs.
I did not want to extend the discussion to higher level but since you introduce it,
The wonderful thing about nature is not that perfect continuous media cannot be found, but that an equation only proved in continuous mathematics for continuous media can be applied at all to granular systems.
That is what notion is what should be pursued.
Well, by that logic the answer to the OP is pretty simple:
And we could say "Yes. Light can be considered to be strictly a wave, as long as there are a large enough number of photons present so that the classical notion of light as a continuous wave is a reasonable approximation."
But I thought we were doing away with any such approximations in this discussion, at least that is my interpretation of the OP's question.
By the way, I completely agree with this sentiment:
I just don't think it is relevant to what the OP was asking.
Already answered. There is a difference between stating that a wave requires discrete particles to operate and that a bunch of particles can jump up and down to form a wave.
Of course, I was just giving an example of a classical wave which has no corresponding quantized 'particle', which is what I took the OP to be meaning. I'm still not sure precisely what he is asking, though.
1. Is it possible for something to exist solely as a wave?
The concept of wave-only existence is a contentious topic in the scientific community. While some theories suggest that everything in the universe can be described as a wave, others argue that particles are the fundamental building blocks of matter. Ultimately, the answer to this question is still unknown and requires further research and experimentation.
2. How do waves differ from particles?
Waves and particles are two fundamental concepts in physics that have distinct properties. Waves are characterized by their oscillating motion and can exhibit interference and diffraction, while particles have a well-defined position and can interact with other particles. Additionally, waves can have a range of frequencies and wavelengths, while particles have specific masses and charges.
3. Can particles exhibit wave-like behavior?
Yes, particles can exhibit wave-like behavior under certain conditions. This phenomenon is known as wave-particle duality and is a fundamental principle of quantum mechanics. It states that particles can behave as both waves and particles, depending on the context of the experiment. This duality is often observed in subatomic particles, such as electrons and photons.
4. What evidence supports the existence of waves?
There is a vast amount of evidence supporting the existence of waves. For example, electromagnetic waves, including light, radio waves, and X-rays, are routinely used in technology and have been extensively studied and observed. Additionally, scientists have also observed the behavior of waves in various physical systems, such as sound waves in air and water waves in oceans.
5. How does the concept of wave-only existence impact our understanding of the universe?
If it is proven that everything in the universe can be described as a wave, it would significantly impact our current understanding of the fundamental nature of reality. It would mean that particles, which we consider to be the building blocks of matter, are not the most fundamental level of existence. This could lead to a paradigm shift in our understanding of the universe and have implications for various fields of science, including cosmology and particle physics.
  • Quantum Interpretations and Foundations
  • Quantum Physics
