How to Construct a Variable-Output Current Supply Using Op-Amps?
In summary, a variable-output current supply can be constructed using an op-amp, and can be controlled by a potentiometer.
dyordyen
guys, i need some help...
is it possible to construct a variable-output current supply using op-amp(s)?
if so, can anyone help me about how to construct one?
There are tons of circuits on the web, search for current source, not supply.
Here are a few schematics.. You can beef up the current with a transistor. Also check out Bob Pease article on current sources.
http://www.edn.com/contents/images/6309110f1.pdf
http://electronicdesign.com/Articles/ArticleID/18966/18966.html <Bob Pease article
thanks very much!
so that's why, i used "supply" for searching... should have used "source"...
oh, and one more thing..
how about a variable op-amp current source?
when i search the web i only find constant current sources using op-amps...
or is there any of the kind?
sorry for the "newbie-ness" of mine...
by "variable", do you mean voltage-controlled? if no, your current source is determined by the component values. those can be changed.
As rjb says, you could use a potentiometer for the current setting control. Or, if you want it to be voltage controlled (like from a microcontroller), you could use a "digital potentiometer" device, or use a MOSFET as a voltage controlled resistance (but there are nonlinearities in doing this that need to be accounted for).
Digital pots and uCs: http://www.maxim-ic.com/appnotes.cfm/an_pk/408
Looking at Fig. 1a of that article:
http://electronicdesign.com/files/29/18966/fig_01a.gif
Shouldn't the current be
[tex]
I = \alpha \ (V_s - V_{in}) \ / \ R
[/tex]
Then to get a variable current, you could use a potentiometer for the resistor appearing between the words "Current" and "V_in".
[tex]
[/tex]
Think the current I is just [tex]I = \frac{ (V_s - V_{in}) }{ R }[/tex]
Don't see where alpha would enter in...
I'm guessing alpha accounts for the difference in collector and emitter currents for the transistor, and is very close to 1. So your equation would work just fine too.
Oh, I see the alpha factor now. Thanks Redbelly.
thanks guys,
this forum works like magic... well, strictly-physics speaking, magic don't exist... but not in this case...
1. What is an Op-Amp?
An Operational Amplifier (Op-Amp) is an electronic device that amplifies the difference between two input voltages. It typically has a high gain and can be used in a variety of applications such as amplifiers, filters, and voltage regulators.
2. How does an Op-Amp function as a current supply?
An Op-Amp can function as a current supply by using a feedback loop to adjust its output voltage in order to maintain a constant current through a load. This is achieved by using a voltage-to-current converter, where the output voltage is converted into a proportional current.
3. What are the advantages of using an Op-Amp as a current supply?
One advantage is that it can provide a stable and precise current output, even with varying input voltage or changes in the load. It also has a wide range of possible output currents and can be easily controlled through feedback. Additionally, Op-Amps are relatively inexpensive and widely available.
4. Are there any limitations to using an Op-Amp as a current supply?
One limitation is that the Op-Amp may not be able to provide high output currents, as it is limited by its internal circuitry. Another limitation is that it may introduce noise into the output current, which can affect the performance of sensitive circuits.
5. What are some common applications of Op-Amp as a current supply?
Op-Amps are commonly used as current sources in electronic circuits, such as LED drivers, motor controllers, and sensor interfaces. They are also used in precision current sources for testing and calibration purposes.
  • Electrical Engineering
