Homework Help: Op-Amp Design
  1. Mar 6, 2014 #1
    Maylis
    Design an op-amp circuit that can perform the operation:Vo = 12VS1+3VS2, while simultaneously presenting an input resistance of 50 kΩ on the input side for source VS1 and an input resistance of 25 kΩ on the input side for source VS2.
    2. Relevant equations
    3. The attempt at a solution
    I am looking at Op-Amp gains, and I cannot find a model that will produce this output. A summation amplifier won't do it, nor a difference amplifier. What kind of model should I use?
  3. Mar 6, 2014 #2
    PhysicoRaj
    On what basis did you get this?
  4. Mar 6, 2014 #3
    Maylis
    By looking at the equations of the gains of the respective amplifiers.
    The equation has a positive sign, and the equation for a difference amplifier for Vout is given here
    http://en.wikipedia.org/wiki/Operat...erential_amplifier_.28difference_amplifier.29
    Notice the -Rf/R1 * v1 term.
    None of the equations for any of the op-amps in that article seem to work with what I want.
  5. Mar 6, 2014 #4
    CWatters
    A summing amplifier can be non-inverting.
  6. Mar 6, 2014 #5
    PhysicoRaj
    The output is (12)V1+(3)V2. Seeing this what op-amp configuration do you think would be suitable? Forget about gains for a second.
  7. Mar 6, 2014 #6
    Maylis
    A Difference amplifier
  8. Mar 6, 2014 #7
    berkeman
    Staff: Mentor
    "Difference" implies subtraction. Where do you see a subtraction?
  9. Mar 6, 2014 #8
    Try to use summing amplifier + ?? amplifier
  10. Mar 7, 2014 #9
    Maylis
    the problem with the summing circuit is that Rf/50kΩ = 12 and Rf/25kΩ = 3 will not give a solution for Rf.
    A non-inverting summer will have the same problem, where G is not satisfied by the two equations with the input resistances being set.
  11. Mar 7, 2014 #10
    PhysicoRaj
    Does your problem put a limit on to the number of amps used?
  12. Mar 7, 2014 #11
    Maylis
    No, you can use multiple op-amps
  13. Mar 7, 2014 #12
    So you can use summing amplifier and one voltage follower + 50K resistor between follower input the Vs1, and one non-inverting amplifier.
  14. Mar 7, 2014 #13
    NascentOxygen
    Staff: Mentor
    Can you pass an input through a potential divider?
  15. Mar 8, 2014 #14
    PhysicoRaj
    Then it should not be difficult. You can have a unique Rf for each op-amp.
Have something to add?
Draft saved Draft deleted
