Op Amp Offset Voltage
  • Thread starter ecestar
please
can any one give me clearly information about Op Amp Offset Voltage
with simple example and rule to explain that becaus i was found diffecalt to understsnd it .
chroot
Staff Emeritus
34
An op-amp in a feedback circuit should drive its two inputs to the same voltage. In reality, the amplifier will have some error, and the two inputs will settle at slightly different voltages. The difference in the two voltages is called the "offset voltage" or "offset error."
- Warren
ok thanks
but can u give me any example with value of input and resistor and what the solution
chroot
Staff Emeritus
34
I have no idea what you're asking for. If you need help with a homework problem, please show us the problem (exactly as it was given to you), show us your work, and explain how and why you're stuck.
- Warren
i want to send patient tempareture
so at first i have sensor (AD22100) with 10 degree range
after that send the voltage of the sensor to VCO to convert v/f (TS902).
but between the sensor and VCO i need op amp (741) but when i connect it the offset apper in the result and i am connect varaible resistor to the feedback of the op amp but i dont now how can i get the right result.
not: u can see the data sheet if u want about sensor (AD22100),VCO(TS9402).AMPLIFIRE (741).
THANKS
chroot
Staff Emeritus
34
Can you show us a schematic?
- Warren
who can i do that
berkeman
Mentor
55,324
5,505
who can i do that
How can you do that? If you have the schematic on your PC screen, you can press Alt-PrintScreen on most computers, and that will store a "screenshot" of the active window to the Windows Clipboard. Then go into an application like "Paint", and paste it in. Save it as a JPG file, or convert to PDF, and upload it here as an attachment (careful of the size -- there are limitations to upload file size). If the file is too big to upload, store it on an outside server or your own website, and post a link to it here.
Also, with an older non-CMOS opamp like the LM741, there is a trick to minimize input offset current effects (which can be worse than input offset voltage effects on some opamps). When you show us your schematic, we can look to see if you are using this trick correctly.
4,660
please
For open loop
Vout = A{V+ - V- - Voffset]
If you build a voltage follower with gain of 1 (wire from Vout to V-), and ground the positive input, the output voltage is equal to the offset voltage.
i dont software to draw this circut can u give me one
and i need example to show me the mean of offset please
berkeman
Mentor
55,324
5,505
Google is your friend. Learn to use it. I Googled the following (type it in the Google search box):
opamp input offset voltage tutorial
And Google came back asking if I meant:
op amp input offset voltage tutorial
to which I answered OK. Here is the hit list:
http://www.google.com/search?hl=en&safe=off&rlz=1T4TSHB_enUS315US316&ei=SfjSSdnKLpectAPY2vD4Cw&sa=X&oi=spell&resnum=0&ct=result&cd=1&q=op+amp+input+offset+voltage+tutorial&spell=1
There are many good hits, including a tutorial on your LM741 opamp (that's how I usually spell opamp, not op amp) as the first hit. Hope that helps.
Related Threads for: Op Amp Offset Voltage
  • Posted
  • Posted
  • Posted
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
Hot Threads
