Calculating Input Voltage for Switched Op-Amp Circuit
In summary, the Op-Amp circuit described in the question is not linear and behaves differently past certain threshold values. As a result, finding the correct input voltage for the circuit is difficult.
Gaz1873
Calculate the input voltage to an Op-Amp circuit. The circuit is exactly an ideal non-inverting amplifier except the inputs have been switched in that the supply is connected to the inverting input and the middle of the potential divider is connected to the non-inverting input.
I would be completely comfortable solving this problem if it was not for the inputs having been switched.
Again, had the inputs not been switched I'd use:-
Vin = R1/(R1 + R2) x Vout
The best thing I can come up with is that the answer is the same but negative as opposed to positive.
Any help much appreciated.
Take a look at the thread: Schmitt Trigger question , and see if your circuit looks anything like the one discussed there.
Hi gneill,
Yes that is the exact question funny old thing and I have the exact same answer using the formula I stated above. That thread seemed to go off on a tangent a little.
I get 1.69v using R1/(R1+R2) x Vout.
Shouldn't it be -1.69v?
Nope.
Follow the thread through to the end. The circuit does not behave linearly past certain threshold values (hence the name of the thread).
I'm a bit confused by that thread. I've read it through and I understand that the difference between Vin and V+ will determine the polarity of the output voltage. The output is given as 2.4V. From that I can deduce that Vin is less than the 1.69V I calculated earlier. The question states that Vin is constant however so that leaves me no further forward. Surely the answer is not as simple as <1.69V? Although it does make sense as any value less than 1.69V will give an output of 2.4V.
The question is a tricky one to answer because in reality the circuit would tend to latch at a supply rail value when the input passes certain threshold values (one positive, the other negative), and not move from there until the opposite threshold is passed.
Here they are specifying a particular value for the output that is (presumably) not equal to either of the supply voltage values. So the circuit can't have a history of actual operation that would have placed it in either of the "latch" states. In this case I suppose you need to assume that the given output voltage is correct and find a value for the input voltage that would hold the output at this (unstable) equilibrium.
You've done this by finding the +1.69 V value for Vin.
If Vin were to increase to and exceed the threshold value for the circuit then the output would "latch" to the lower supply rail until the input decreased below the lower threshold value (at which point the output would rise and latch to the upper supply rail). Note that the threshold values will be some fraction of the supply voltages, not the 2.4 V or 1.69 V values. The fraction depends on gain of the circuit as set by the resistors.
So you think the question is poor but the answer is correct?
Thank you very much for your help with this. It's much appreciated.
That sums it up nicely :smile:
1. How do I calculate the input voltage for a switched op-amp circuit?
The input voltage for a switched op-amp circuit can be calculated by using the formula VIN = VREF + (VOUT x RF / RG), where VREF is the reference voltage, VOUT is the output voltage, RF is the feedback resistor, and RG is the gain resistor.
2. What is the purpose of calculating the input voltage for a switched op-amp circuit?
The input voltage calculation is important because it helps determine the desired output voltage. It also ensures that the op-amp circuit is stable and does not exceed its maximum input voltage limit.
3. How do I choose the appropriate values for RF and RG in the input voltage calculation?
The values of RF and RG can be chosen based on the desired gain of the op-amp circuit. The gain can be calculated by dividing RF by RG. Generally, a higher gain can be achieved by using larger values for RF and RG.
4. Can the input voltage calculation be used for both inverting and non-inverting op-amp circuits?
Yes, the input voltage calculation can be used for both inverting and non-inverting op-amp circuits. The only difference is that for an inverting op-amp circuit, the input voltage is calculated at the inverting input, while for a non-inverting op-amp circuit, the input voltage is calculated at the non-inverting input.
5. Are there any limitations to the input voltage calculation for switched op-amp circuits?
The input voltage calculation assumes ideal conditions and may not accurately reflect the actual output voltage. Additionally, it is important to consider the input offset voltage and input bias current of the op-amp when calculating the input voltage. These limitations should be taken into account for more precise calculations.
