Is the Diameter of the Open Ball B(0,r) equal to 2r?
  • Thread starter Uniquebum
  • Tags
    Diameter
In summary, the open ball B(0,r) in ℝ² has a diameter of 2r, which can be proven by showing that it is equal to the diameter of its closure, which is also equal to 2r. This can be done by solving a maximization problem for a continuous function on a compact set.
Uniquebum
55
Show that open ball [itex]B(0,r) \subset \mathbb{R}^2[/itex] has a diameter 2r.
Intuitively i'd say right away that it can't be 2r but i presume it has to be since I'm being asked to prove it.
To simplify the situation, i'll think about this in one dimension.
Assume we have points x and y in the ball which means that
[itex]|x-y| = |x-0+0-y| \leq |x-0|+|y-0|< r+r = 2r[/itex]
And that's pretty much what i got. Based on this, the diameter should be less than 2r since the points x and y must both be less than r away from the center. What am i not understanding here?
Hi Uniquebum! :smile:
Why can't you choose x and -x? :wink:
Heh, that's obviously wiser. However, that leads to the same situation either way... or?
Since we can't choose r to be the x as it's an open ball so [itex]x<r[/itex]
[itex]|x-(-x)|=|2x|<2r[/itex]
It's better to do this way :) but it leads to the same result.
Uniquebum said:
Since we can't choose r to be the x as it's an open ball …
Why not?
Isn't there's still a diameter of length 2r from x to -x, even if the end-points aren't there? :wink:
You just have to be careful about proving it! :biggrin:
Based on this, I'd say that you need to have another look at the definition of "diameter".
Consider the open interval (0,1) in ℝ, i.e. the set ##\{x\in\mathbb R|0<x<1\}##. What's the diameter of that set? OK, I'll tell you the answer. It's 1. But how does that follow from the definition of "diameter"? That's what you need to think about.
I actually maybe got it! :)
Let's call the set [itex]A[/itex] and then [itex]sup(A)=r[/itex]. If we pick points [itex]x[/itex] and [itex] -x[/itex] we have an [itex]\epsilon > 0[/itex] from which we can state that
[itex]x+\epsilon \leq r[/itex] and [itex]|-x-\epsilon| \leq r[/itex]
Now the distance between the points
[itex]|x-(-x)|=|x+\epsilon - (-x)-\epsilon| \leq |x+\epsilon| + |-x-\epsilon|\leq r + r = 2r[/itex]
That means the largest possible value of [itex]|x-(-x)|[/itex] is [itex]2r[/itex] which would be the diameter.
I so hope that's it!
Thanks a lot.
that's all true :smile:, but it doesn't prove …
try again, starting "given any ε < 0 and < r, there exists an x with r - x < ε/2" :wink:
I don't think so. I don't understand your proof.
What set?
What does this mean? I'm guessing that you mean that "for all x in B(0,r), there's an ε>0 such that...", but it's not clear from what you're saying.
OK, now I see that you couldn't have meant "for all x in B(0,r)", because then the sum x+ε wouldn't make sense. I'm changing my guess to "for all x in (-r,r)". So you seem to be saying that for all x in (-r,r), there's an ε>0 such that |x+ε|≤r. This is true, but not very useful.
Maybe I'm missing something obvious, but I don't see how you're using the triangle inequality here. I get ≤|x+ε|+|x-ε|. Of course, if you go back and change "for all x in (-r,r)" to "for all x in (0,r)", we have |x-ε|<|x+ε|.
There are two major problems with this sentence:
1. There's no x in B(0,r) such that |x-(-x)|=2r.
2. The diameter isn't defined as the largest value of |x-(-x)|.
Oh well, banged my head against the wall for a while but still can't figure it out. At least i know that I'm doing it wrong and where i'd have to start the proper proof.
Thanks again. :)
I suggest that you do a similar but simpler problem first. Can you prove that ##\sup\{x\in\mathbb R|x<0\}=0##? you should do this by proving the inequalities ##\sup\{x\in\mathbb R|x<0\}\leq 0## and ##\sup\{x\in\mathbb R|x<0\}\geq 0## separately. The first one is rather obvious if you think of the definition of "supremum". The second is trickier. I suggest that you prove that for all ε>0, it's impossible that ##\sup\{x\in\mathbb R|x<0\}<-\varepsilon##.
Can you first prove that [itex] B(0,r)[/itex] and its closure [itex] \bar{B(0,r)}[/itex] have the same diameter? (It IS true.) Now can you convince yourself that [itex]\text{diam}(\bar{B(0,r)}) = 2r[/itex]? Computing [itex]\text{diam}(\bar{B(0,r)})[/itex] involves solving a maximization problem for a continuous function on a compact set, so has an optimal solution; you can easily solve it.
RGV
Ray Vickson said:
Can you first prove that [itex] B(0,r)[/itex] and its closure [itex] \bar{B}(0,r)[/itex] have the same diameter? (It IS true.) Now can you convince yourself that [itex]\text{diam}(\bar{B}(0,r)) = 2r[/itex]? Computing [itex]\text{diam}(\bar{B}(0,r))[/itex] involves solving a maximization problem for a continuous function on a compact set, so has an optimal solution; you can easily solve it.
I wouldn't recommend this solution, as it requires the OP to know stuff about closures, compact sets, continuity and how to solve maximization problems. It's a longer solution, even though we're using some theorems that are much more difficult than the problem itself.
The straightforward approach is to first prove that diam B(0,r)≤2r, and then prove that diam B(0,r)>2r-ε for all ε>0.
Of course, but I did not want to assume anything about what the OP knows or does not know. That is why I asked him questions, and if he answered NO he could just ignore the method. Nevertheless, your direct approach is much more straightforward.
RGV
Ok one more attempt. I'm not giving up!
So the point is to prove that [itex]sup\{d(x,y)|x,y\in B(0,r)\}=2r[/itex]?
Thus
1)[itex]sup(d(x,y))=2r[/itex] if and only if
2)[itex]sup(d(x,y))>2r-\epsilon[/itex] with any given [itex]\epsilon > 0[/itex].
1)
Antithesis:
There exists an [itex]\epsilon > 0[/itex] so that [itex]sup(d(x,y)) \leq 2r-\epsilon[/itex] and then [itex]2r-\epsilon[/itex] is an upper bound of the set. Now [itex]2r-\epsilon<2r[/itex] which contradicts with the presumptions since [itex]2r[/itex] had to be the supremus.
2)
Suppose that for any given [itex]\epsilon > 0[/itex] we find such [itex]sup(d(x,y)) > 2r-\epsilon[/itex]. Let [itex]M[/itex] be an upper bound of the set and thus [itex]2r \leq M[/itex].
Antithesis:
Let [itex]2r>M[/itex] and [itex]\epsilon = 2r - M > 0[/itex]. Now based on the presumptions [itex]2r - \epsilon < sup(d(x,y)) \leq M[/itex]
Thus [itex]2r < M + \epsilon = M + 2r - M = 2r[/itex] which is a contradiction.
This means [itex]sup\{d(x,y)|x,y\in B(0,r)\}=2r[/itex] and thus the diameter...? I think...
I was hoping you would say that. :smile:
Statement 2 is equivalent to sup(d(x,y))≥2r, not sup(d(x,y))=2r. So if you prove 2, you will have to prove sup(d(x,y))≤2r as well, before you can conclude that the equality holds.
Uniquebum said:
Antithesis:
Here you're proving that if statement 2 is false, then 2r is not the supremum. But you can't conclude that statement 2 is true from this, because we can't assume that 2r is the supremum. That's the statement we want to prove.
You're making two assumptions here. First you assume that sup(d(x,y))≥2r, which is one of the two inequalities we want to prove. Then (the "thus" comment) you assume that sup(d(x,y))=2r, which is to assume that both of the inequalities you want to prove are true.
I'll give you some additional hints:
1. I've been saying that we can prove sup(d(x,y))=2r by proving sup(d(x,y))≤2r and sup(d(x,y))≥2r separately, but this is only true if we have already proved that {d(x,y)|x,y in B(0,r)} is bounded from above. Can you prove that 2r is an upper bound of that set? What else can you conclude from this result?
2. We want to prove that for all ε>0, sup(d(x,y))>2r-ε. You should start by saying "let ε>0 be arbitrary" and then prove that the set {d(x,y)|x,y in B(0,r)} has members that ensure that it's impossible that sup(d(x,y))≤2r-ε.
Righty, here we go again.
Let [itex]\epsilon>0[/itex] be arbitrary.
Antithesis: [itex]sup(d(x,y)) \leq 2r-\epsilon[/itex]
This means that [itex]2r-\epsilon[/itex] is an upper bound of the set.
Let [itex]\epsilon>\delta>0[/itex]. Now [itex]2r-\epsilon<2r-\delta<2r[/itex] which means [itex]2r-\epsilon[/itex] cannot be an upper bound and [itex]2r[/itex] is.
Since [itex]2r[/itex] is an upper bound of the set we can state that [itex]2r\geq sup(d(x,y))[/itex]
This is as far as i can get. What I'm wondering is the statement of [itex]2r \leq sup(d(x,y))[/itex]. As far as i understand, i'd have to prove first that 2r belongs to the set [itex]\{d(x,y)|x,y\in B(0,r)\}[/itex] and i don't know how i'd go about that. So what am i missing?
i don't understand that :confused:
try again, starting "given any ε > 0 and < r, there exists an x with r - x < ε/2" :wink:
I don't see how it follows from those inequalities that a) 2r-ε is not an upper bound, or that b) 2r is an upper bound.
If this had been true, only sets that have a maximum element would have a supremum. It would e.g. be impossible for the set of negative real numbers to have 0 as its supremum. We have ##\sup\{x\in\mathbb R|x<0\}\geq 0## even though 0 isn't in the set.
The issue that you're struggling with has little to do with metric spaces, open balls, etc. It's about the concept of "supremum". So I would suggest that you try the idea I've been describing on a slightly simpler problem first. Can you e.g. prove that the supremum of all negative real numbers is 0? These are the steps:
1. Prove that 0 is an upper bound of ##\{x\in\mathbb R|x<0\}##. (OK, this step is trivial).
2. Prove that ##\sup\{x\in\mathbb R|x<0\}\leq 0##. (Also kind of trivial, if you think of what a supremum is).
3. Prove that ##\sup\{x\in\mathbb R|x<0\}\geq -\varepsilon## for all ε>0.
1. Prove that 0 is an upper bound of [itex]S=\{x\in \mathbb{R}|x<0\}[/itex]. (OK, this step is trivial).
2. Prove that [itex]S=sup\{x\in \mathbb{R}|x<0\}\leq 0[/itex]. (Also kind of trivial, if you think of what a supremum is).
3. Prove that [itex]S=sup\{x\in \mathbb{R}|x<0\}\geq -\epsilon[/itex] for all [itex]\epsilon>0[/itex].
1)
0 is an upper bound for the set, since for all [itex]x \leq 0[/itex].
2)
Since 0 is an upper bound and S the least of upper bounds, [itex]S\leq 0[/itex]
3)
This i don't know how to go about. Since, assume S would be -2 and then it wouldn't go for all epsilon. The only thing we know is that 0 is an upper bound but the difference S-0 could be other than 0.
And the way tiny-tim suggests leads to [itex]2x> 2r-\epsilon[/itex] which is pretty much what I've been trying to do the whole time. Only with the difference that [itex]2x=d(x,y)[/itex].
but isn't that what you want?
try writing it out properly, and see :smile:
Uniquebum said:
1)
2)
I'm getting the impression that you have understood these two steps, but your presentation here is a bit messed up. The "for all" statement in 1 is incomplete, and when you said "S" in 2, you meant "sup S", right.
Here's how I would do steps 1-2:
1. Clearly x≤0 for all x in S. This means that 0 is an upper bound for S.
2. Since 0 is an upper bound for S, and sup S is the least upper bound for S, we have sup S≤0
Uniquebum said:
3)
We certainly know more than that 0 is an upper bound. I will show you how to do step 3 in the problem I suggested:
3. We will prove that sup S≥-ε for all ε>0 by deriving a contradiction from the assumption that this is false. So suppose that there's an ε>0 such that sup S<-ε. Since -ε is a member of S, this contradicts that sup S is an upper bound of S.
Here's a slightly different way: Since sup S≤0 (by step 2), sup S is either negative or zero. We will prove that it can't be negative, by deriving a contradiction from the assumption that it is. So suppose that sup S<0. Then sup S is a member of S, but more importantly, there's a negative number that's greater than sup S that's a member of S (for example (sup S)/2). This contradicts that sup S is an upper bound of S.
You might want to replace this with a more precise statement. I understand what you're doing, but the words "and <r" don't make sense, you're using x as a variable for a member of ℝ when it's already being used as variable for a member of ℝ2, and the "there exists" statement doesn't specify in what set there exists something.
Hi Fredrik! :smile:
Fredrik said:
… you're using x as a variable for a member of ℝ when it's already being used as variable for a member of ℝ2
I see what you mean, but no, I do mean x is in ℝ
(though my x may not be the same as everyone else's :wink:)​
Back to the actual problem. Define ##S=\{d(x,y)|x,y\in B(0,r)\}##. We want to prove that diam B(0,r)=2r. This is equivalent to sup S=2r, which is equivalent to the following two inequalities.
1. sup S≤2r
2. sup S≥2r.
For step 1, start with "Let t in S be arbitrary" and show that t≤2r. Conclude that this result implies the first inequality. There are many ways to do step 2. One of them is to derive a contradiction from the assumption that sup S<2r. (Since sup S≤2r, a contradiction derived from sup S<2r would imply that sup S=2r).
1. What is the definition of an open ball's diameter?
An open ball's diameter is the distance between any two points on the surface of a sphere that passes through the center of the sphere. It is represented by the symbol "2r", where "r" is the radius of the sphere.
2. How is the diameter of an open ball different from its radius?
The diameter of an open ball is the length of a straight line passing through the center of the sphere, while the radius is the distance from the center to the surface of the sphere. This means that the diameter is always twice the length of the radius.
3. What is the significance of "2r" in the formula for an open ball's diameter?
The number "2" in the formula represents the fact that the diameter is twice the length of the radius. This is a fundamental relationship in geometry and is important in many mathematical calculations involving spheres and circles.
4. Can the diameter of an open ball be negative?
No, the diameter of an open ball cannot be negative. It is always a positive value, as it represents a physical distance between two points on the surface of a sphere.
5. How is the diameter of an open ball used in scientific research?
The diameter of an open ball is a fundamental measurement in many fields of science, including physics, chemistry, and biology. It is used to calculate important properties of spherical objects, such as volume and surface area, and is also used in various mathematical calculations and models.
