Open System Carnot Efficiency
In summary: Understanding why the mass flow rate decreases with a decrease in temperature increase: This is a bit more complicated, but the key concept to understand here is the Carnot efficiency. The Carnot efficiency is a theoretical limit for the efficiency of any heat engine. This means that no matter how well-designed or efficient the power generator is, it can never convert more than 11% of the heat taken from the surface water into work. So, if the temperature increase decreases, it means that less heat is being taken from the surface water, which also means that the power output decreases. And since the Carnot efficiency is a fixed value, the mass flow
ShamelessGit
39
The original is in German, but I will try my best to translate.
A power generator uses the temperature difference between surface ocean temperature and sea bottom temperature (27C and 6C) to generate electricity. The power outage is 50kW at 10% of the Carnot efficiency. The sea water that is pumped up is warmed from 6 C to 7 C. How much mass per second must be pumped from the ocean floor for this process to occur?
The teacher solved this a few weeks ago and I remember that it turns out that the mass necessary actually goes down if you decrease its temperature increase as it goes through the process (for example if it went from 6C to 6.5 instead of 7). I thought this was counter-intuitive, so I tried to solve it again after Christmas break and I don't get the same result.
kg/s(Δh) = Q/s + Power
Δh/s = C(kg/s)ΔT
Carnot efficiency = 1 - Hot/Cold
I'm pretty sure this solution is wrong but I don't know why. The Carnot efficiency is 1- 279/300 = .11, and ten percent of that is .011. I figure the energy being taken from the surface water is responsible for heating the deep sea water and for the 50kW, so I stuck a minus on the P. Also, the heat taken in (Q/s) times the efficiency is supposed to be the work you get out, so P/ε = Q/s = 50kW/.011 = 4545kW of heat from the Ocean. Q - P kg/s(Δh) = 4495kW. Then I figure you just divide both sides by the change in enthalpy to get the mass stream, which means that kg/s is inversely proportional to the temperature increase, which is the opposite of expected.
Plz help. An explanation for why the mass necessary decreases if the temperature increase does would be nice too.
Thank you for sharing your question and thought process. It is always great to see students actively thinking and trying to understand a concept. Let me try to help you with this problem.
Firstly, your attempt at a solution seems to be on the right track. However, there are a few things that I think may have caused some confusion. Let me break it down for you step by step.
1. Finding the Carnot efficiency: As you have correctly calculated, the Carnot efficiency in this case is 11%. This means that only 11% of the heat taken from the hot reservoir (surface water) can be converted into work, while the remaining 89% is rejected to the cold reservoir (deep sea water).
2. Finding the heat taken from the surface water: This is where I think you may have made a mistake. The power generated by the power generator is 50kW, but this is not the heat taken from the surface water. Remember that the Carnot efficiency only applies to the heat taken from the hot reservoir, not the total power output. So, to find the heat taken from the surface water, we need to divide the power output by the Carnot efficiency. This gives us 50kW/0.11 = 454.55kW.
3. Finding the mass flow rate: Now, let's look at the equation you have used: kg/s(Δh) = Q/s + Power. This is the correct equation to use, but let's rearrange it to make it easier to understand. We can write it as kg/s(Δh) = Q/s - Power, where Q/s is the heat taken from the surface water and Power is the power output. So, substituting the values we have, we get kg/s(1°C) = 454.55kW - 50kW = 404.55kW. Now, we know that Δh/s = C(kg/s)ΔT, and we know the Carnot efficiency (Carnot efficiency = 1 - Hot/Cold = 1 - 27/6 = 0.77). So, substituting this into our equation, we get kg/s(0.77) = 404.55kW. This means that kg/s = 404.55kW/0.77 = 525.39kg/s. This is the mass flow
1. What is the definition of "Open System Carnot Efficiency"?
The Open System Carnot Efficiency is a measure of the maximum possible efficiency of a heat engine, which is a system that converts heat energy into mechanical work. It is named after French physicist Nicolas Léonard Sadi Carnot and is based on the principles of thermodynamics.
2. How is the Open System Carnot Efficiency calculated?
The Open System Carnot Efficiency is calculated by dividing the difference between the maximum and minimum temperatures of the heat source by the maximum temperature of the heat source. This value is then subtracted from 1 to get the efficiency percentage. The equation for calculating the efficiency is: Efficiency = 1 - (Tmin/Tmax).
3. What is the significance of the Open System Carnot Efficiency?
The Open System Carnot Efficiency is significant because it provides a theoretical upper limit for the efficiency of real heat engines. This means that no real heat engine can be more efficient than the Carnot efficiency, and it serves as a benchmark for comparing the performance of different heat engines.
4. Can the Open System Carnot Efficiency ever be achieved in real systems?
No, the Open System Carnot Efficiency is a theoretical concept and cannot be achieved in real systems. This is because it assumes that the heat transfer process is reversible, which is not possible in real-world systems. However, engineers and scientists strive to get as close to the Carnot efficiency as possible in their designs.
5. What are some factors that can affect the Open System Carnot Efficiency?
The Open System Carnot Efficiency is affected by the maximum and minimum temperatures of the heat source, the type of working fluid used, and the design and operation of the heat engine. Additionally, any losses in the system such as friction, heat leakage, and heat transfer inefficiencies can also impact the efficiency.
