Operator overloading C++
  1. Sep 12, 2009 #1
    I've got an overloaded operator +
    Code (Text):
    newtype X, Y, Z, W;
    W = X + Y;  // works fine
    W = Y + X; // works fine
    // but with more arguments I'm getting compiler error
    // saying there is no match for operator+
    W = X + Y + Z;
    Sample code
    Code (Text):
    newtype operator+(newtype &A, newtype &B)
    newtype C;
    //more code
    return C;
    Is there something missing?
  3. Sep 12, 2009 #2
    Hurkyl
    Staff Emeritus
    Just eyeballing it, I agree with the compiler.
    Temporary objects cannot be implicitly converted to modifiable references -- the standard doesn't allow it, and even if it did, you shouldn't do it anyways because it can lead to all sorts of really, really hard to debug problems.
    Since X+Y is a temporary value, it cannot be converted into the modifiable reference required by your operator+.
    Now, the fix is actually very easy: write operator+ correctly! The arguments almost certainly should not be modifiable references -- they should be const references.
    (Well, technically there are occasions where you're better off without using references at all)
  4. Sep 12, 2009 #3
    Not sure what you are doing but my code compilies fine. I am using 2008 C++ Express edition.
    Here is my code.
    Code (Text):
    #include<cmath>
    #include<iomanip>
    #include<iostream>
    int x,y,z,w,pause;  // needed variables
    using namespace std;
    int main()
        x = 1;
        y = 2;
        z = 3;
        w = x+y;
        w = y+x;
        w = x+y+z;
        cout << w << endl;
        cin >> pause; // dummy input to keep the output screen visible
        return 0;
    Thanks
    Matt
  5. Sep 12, 2009 #4
    D H
    Staff Emeritus
    Even if "your code compiles fine" does not mean it is right. Besides, per your first post, your code does not compile fine. It doesn't even compile, period. I would not call that "fine".
    Make the arguments to newtype operator+ be const references and then it will be fine.
  6. Sep 12, 2009 #5
    Yes, const is a must in C++.
    Thanks
    Matt
  7. Sep 12, 2009 #6
    Woe is me. Const ref works like a charm.
Loading...
