Operator relations
Consider the operator ##F_a(\hat{X}) =e^{ia \hat{p} / \hbar} \cdot F(\hat{X}) e^{-ia \hat{p} / \hbar}## where a is real.
Show that ##\frac{d}{d_a} F_a(\hat{X}) \cdot \psi = F'(x) \psi## evaluated at a=0.
And what is the interpretation of the operator e^{i \hat{p_a} / \hbar}?
By just starting taking the derivative I find that,
## \frac{d}{d_a} F_a(\hat{X}) = (\frac{i \hat{p}}{ \hbar}) e^{ia \hat{p} / \hbar} \cdot F(\hat{X}) e^{-ia \hat{p} / \hbar} - e^{ia \hat{p} / \hbar} \cdot F(\hat{X}) (\frac{i \hat{p}}{\hbar}) e^{-ia \hat{p} / \hbar} ##
Plugging a=0 gives,
## \frac{i}{h}[ \hat{p}, \hat{F}]##. But how do I take it from here to get the required form?
And finally, what is the interpretation of ##e^{i \hat{p_a} / \hbar}##?
Thanks in advance!
Answers and Replies
Orodruin
Staff Emeritus
Insights Author
2021 Award
18,489
8,394
Are you perhaps familiar with some commutation relation involving the argument of ##\hat F##?
And finally, what is the interpretation of ei^pa/ℏeipa^/ℏe^{i \hat{p_a} / \hbar}?
What are your thoughts?
Are you perhaps familiar with some commutation relation involving the argument of ^FF^\hat F?
If the operators are hermitian I know they commute, but other than that it dosen't ring a bell.
Orodruin
Staff Emeritus
Insights Author
2021 Award
18,489
8,394
This is not correct. Hermitian operators need not commute. Just look at, just off the top of my head for no apparent reason whatsoever, say ##\hat x## and ##\hat p## ...
Okey. Anyway I'm pretty stuck at the problem. I only get as far as in my attempt of solution.
Orodruin
Staff Emeritus
Insights Author
2021 Award
18,489
8,394
Insertion gives
\frac{i}{\hbar}[\hat p, F(\hat x)]\psi,
which means that you now need to show that ##(i/\hbar)[\hat p, F(\hat x)] = F'(\hat x)##. The absolutely easiest way to do that is via the commutation relation between ##\hat p## and ##\hat x##.
