Homework Help: Operators and Hermiticity
  1. Aug 24, 2011 #1
    Consider two operators, A and B which satisfy:
    [A, B] = B ; B†B = 1 − A
    A. Determine the hermiticity properties of A and B.
    B. Using the fact that | a = 0 > is an eigenstate of A, construct the other
    eigenstates of A.
    C. Suppose the eigenstates of A form a complete set. Determine if eigen-
    states of B can be constructed, and if so, determine the spectrum of the
    eigenstates of B.
    2. Relevant equations
    Condition for Hermiticity:
    [tex] \int (A^{\dagger}\psi)^{*}\psi.dx = \int \psi^{*}A\psi.dx [/tex]
    3. The attempt at a solution[/b
    Completely lost on this one. All I could think of was trying to work to the commutation relation from
    [tex] \int \psi^{*} B^{\dagger}B\psi.dx [/tex]
    but that just leads to a dead end. Any help would be appreciated.
  3. Aug 24, 2011 #2
    vela
    Staff Emeritus
    Education Advisor
    It's easy to show A = 1-BB is Hermitian. Just take the adjoint of both sides of the equation. B, I'm pretty sure, is anti-Hermitian, but I'm not sure how to show that.
  4. Aug 24, 2011 #3
    Dick
    B is a ladder operator for A, isn't it? I don't think it's either Hermitian or anti-Hermitian.
  5. Aug 24, 2011 #4
    vela
    Staff Emeritus
    Education Advisor
    Yup, you're right. :redface:
  6. Aug 24, 2011 #5
    Dick
    Beer-monster, suppose A|a>=a|a>, i.e. |a> is an eigenvector of A with real eigenvalue a. vela already told you how to show A is hermitian. Use [A,B]=B to say something about the eigenvalue of B|a>. Give us some help here.
  7. Aug 25, 2011 #6
    Okay, I guess I really need to study this stuff again because I'm lost.
    I've tried taking the adjoint of A but am not quite sure what to do with it. I guess I just need to hash through the maths.
    How did you see that B was a ladder operator, it not really clear to me.
  8. Aug 25, 2011 #7
    vela
    Staff Emeritus
    Education Advisor
    What does it mean for an operator to be Hermitian?
  9. Aug 25, 2011 #8
    That is satisfies the condition that I mentioned above.
    [tex]\int (A^{\dagger}\psi)^{*}\psi.dx = \int \psi^{*}A\psi.dx[/tex]
    and also the quantities of the operators are all real.
  10. Aug 25, 2011 #9
    vela
    Staff Emeritus
    Education Advisor
    That's not quite it. If you have two operators [itex]\hat{A}[/itex] and [itex]\hat{A}^\dagger[/itex] that satisfy[tex]\int (\hat{A}^{\dagger}\psi_l)^*\psi_r\,dx = \int \psi_l^*\hat{A}\psi_r\,dx[/tex]for all pairs [itex]\psi_l[/itex] and [itex]\psi_r[/itex] from the Hilbert space, you would say [itex]\hat{A}^\dagger[/itex] is the Hermitian adjoint of [itex]\hat{A}[/itex]. Now how are the operator and its adjoint related if it's Hermitian?
  11. Aug 25, 2011 #10
    The operator and its adjoint are equal if it is Hermitian?
  12. Aug 25, 2011 #11
    vela
    Staff Emeritus
    Education Advisor
    That's right. So you want to calculate [itex]\hat{A}^\dagger[/itex] and show it equals [itex]\hat{A}[/itex]. You should find rules in your textbook on how to calculate the adjoint of products and sums, which you will find helpful.
  13. Aug 25, 2011 #12
    I see it now. Here I was adding in kets and bras because I've often found it useful with commutator stuff.
    The [tex]B^\dagger[/tex] becomes B and vice versa would give [tex]BB^\dagger[/tex] but because factors swap round in an adjoint you get what you started with.
    I'm still not sure how you worked out B was a ladder operator. Though I had guessed something along those lines as ladder operators were the only way I could think to get an eigenspectrum with no wavefunction. i.e. the question gave it away.
  14. Aug 26, 2011 #13
    Dick
    I guessed B was a ladder operator because I've seen a form like [A,B]=B before. That's the big reason. You can figure it out for yourself if you operate both sides on an eigenfunction of A, like I suggested in post #5. Or have you already figured that out?
  15. Aug 27, 2011 #14
    Not yet. But I think it`s just a matter of beating my head against the maths and cracking out a textbook that goes over the mathematical manipulations of operators again.
    Incidently, I noticed there was a mistake in my first post. The relation between B and A is:
    [tex] B^{\dagger}B=1-A^{2} [/tex]
    This shouldn't effect the results too much as I would imagine if A*A is Hermitian so A would be.
  16. Aug 28, 2011 #15
    Dick
    Untrue, if A=i*I where I is the identity operator then A^2 is hermitian, but A isn't. You might have a bit more work to do on this problem.
Loading...
