Understanding Hydroxyl Diffusion in Optical Fibers: Causes and Effects"
In summary, the major concern in the fabrication of optical fibers is hydroxyl diffusion into the fibers, as a high hydroxyl concentration can lead to much higher attenuation. The reason for this dramatic effect is due to the presence of hydroxyls being absorbed into an excited vibration state, which is especially significant for optical fibers that use longer wavelengths such as 1.54 micrometers.
RPI_Quantum
50
It seems that a major concern in the fabrication of optical fibers is hydroxyl diffusion into the fibers. I understand that a high hydroxyl concentration can lead to much higher attenuation. I don't know why though.
Can someone please explain to me why the hydroxyl concentration affects optical signal attenuation so dramatically?
Google Results for - hydroxyl concentration affects optical signal attenuation
Result 1 - 10 of about 962. Search took 0.404610 seconds.
I'm sure you could find the answer in one of these sites
Well, "explain", hrmm... but it has something to do with vibration at least. But as I'm writing it seems odd to me that the optical and vibrational energy scales should overlap...
I think, however, the solution lies in that "optical" fibers actually don't use visible light (the association one, at least I, might get from optical). I think there was something with 1,54 mikrometers, which is rather a large wavelength. Probably this is where hydroxyls absorb into an excited vibration state. Yeah, this seems right. Am however not so eager to check with a calculation for the moment... :zzz:
1. What are optical fibers and how do they work?
Optical fibers are thin, flexible strands of glass or plastic that are used to transmit light signals. They work by using the principle of total internal reflection, where light is constantly bounced off the walls of the fiber to travel long distances without losing its intensity.
2. What are the advantages of using optical fibers over traditional copper wires?
Optical fibers have several advantages over copper wires, including higher bandwidth, faster data transmission, and immunity to electromagnetic interference. They are also thinner, lighter, and more durable, making them easier to install and maintain.
3. What is the difference between single-mode and multi-mode optical fibers?
Single-mode fibers have a smaller core diameter, allowing for only one mode of light to travel through the fiber. This results in less signal loss and higher bandwidth, making them ideal for long-distance communication. Multi-mode fibers have a larger core diameter and allow for multiple modes of light to travel through, making them better suited for shorter distances.
4. Are there any limitations to using optical fibers?
One limitation of optical fibers is their vulnerability to physical damage, such as bending or stretching, which can cause signal loss. They also require specialized equipment and expertise for installation and maintenance, making them more expensive than traditional copper wires.
5. What are some common applications of optical fibers?
Optical fibers are commonly used in telecommunication systems, such as internet and telephone networks, to transmit large amounts of data quickly and efficiently. They are also used in medical imaging, industrial sensing, and for lighting and decoration in the form of fiber optic cables.
  • Electrical Engineering
  • Classical Physics
  • Biology and Medical
