Optical Transistor
I was recently looking in lasers and and their uses and while watching Cosmos with Newton using a prism to shows the different colors of light from white light i got thinking. I stumbled onto the top optical or photonic computers a while ago and I decided to look into building one. After looking at current research it seems that most optical transistors and computers are being build in silicon on the small scale but little on the larger scale.
I did some researched and figured with two lasers/sources one could use constructive and destructive interference to model on and off just as a transistor uses voltage to switch the current on and off can you not do the same with light. Right now part of the challenge seems to be building an all light transistor. Can anyone shed some light on this subject and would such an idea work?
Answers and Replies
UltrafastPED
216
More is needed: you must be able to read the states for each on/off bit. Many techniques have been used for computer memory over the years - transistors became popular because thet are fast, can be miniaturized in silicon, and are cheap.
For slower memory consider the recodable CD/DVD: the laser makes a mark at a specific position for each bit ... on or off for mark/no mark. It can read the marks by monitoring reflections. All done one bit at a time.
You would need to work out a way to record multiple independent bits from the interference patterns, and a way to read them back.
Claude Bile
Also, the bandwidth of your technique would be infinitely small.
Claude.
Related Threads on Optical Transistor
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
