Optics: 2 lens problem
  • Thread starter iurod
We have a convex lens with a focal length of 8cm, which is 12cm from the second converging lens that has a focal length of 4cm. An object is 12cm from the first lens. Where is the final image?
1/do + 1/di = 1/f
So i know I have to apply the lens equation to both lens, starting with the first lens:
1/di = 1/f - 1/do = 1/8cm + 1/12cm = 1/24cm
di1=+24cm
here is where I get confused. Applying the lens equation to the second lens
I did:
1/di2= 1/f - 1/do(do here equals di1)
1/di2= 1/4cm - 1/12cm = 2/12cm
di2= +6cm
di1 + di2 = 30cm
The answer is 27cm, I've checked my math several times and still get the incorrect answer.
any help is greatly appreciated.
Thanks
Answers and Replies
ehild
15,543
1,913
di1=+24cm
I did:
No, do is not equal to di1. Both the object distance and the image distance are measured from the lens. Make a drawing to see how far is the first image from the second lens and at which side. If the object is behind the lens, you have to take the object distance with negative sign.
I think that 27 cm is the distance of the final image from the object.
It is not di1+di2.
ehild
The image after the first lens is 12cm to the left of the second lens. Im confused as what is in front and behind when it comes to the second lens. Do i take the left as front and right as back (like i did for the first lens), or is this reversed when talking about the second lens?
Thank you again for your help.
ehild
15,543
1,913
It makes things clear if you draw a figure. Is the first image between the lenses, or outside?
ehild
the image is outside, all the way to the right.
ehild
15,543
1,913
So the first image would be 24 cm away from the first lens. How far is it from the second one?
ehild
it is 12 cm to the right of the second lens. So here the object is -12cm to the lens, so instead of using positive 12 for the second lens equation i should have used -12.
1/di2 = 1/4cm - 1/-12 = 4/12cm = 3cm
di1+di2 = 24cm + 3cm = 27cm
ehild
15,543
1,913
It is all right that di1 + di2 is 27 cm, but where is the image? You should give the reference point. So it is 27 cm away from what?
ehild
I have written in my notes that it should be 27cm from the first lens.
Question, why wouldn't it be considered 27cm from the object?
Is it when us the lens equation we are always dealing with the image length relative to the lens and not the object?
Thanks for your help!
ehild
15,543
1,913
No, it is 12 +3 cm far from the first lens, but 27 cm far from the object.
The distances in the lens equation always are meant from the lens.
ehild
Now I get it, Thank you very much for all your help ehild
Related Threads on Optics: 2 lens problem
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
