AdityaDev
- 527
- 33
A rectangular slab of length l=20cm and thickness d=4cm is placed in left of a converging lens of focal length f=20cm. A screen is placed in the focal plane plane of lens (right side of lens).Refractive index of the material of slab increases linearly from u0 at the bottom by an amount ##du=2*10-4)## between bottom and top faces.A parallel beam is made to incident on the left side of slab. Prove that only a bright spot forms on the screen? Find its position
[tex]\Delta x=n \lambda[/tex]
[tex]y=n \lambda /d[/tex]
Here as the refractive index varies, speed of light varies. It will be faster at bottom and slower at top.
$$v=c/ \mu$$
$$ \mu = \mu_o + y \delta \mu $$
For any two rays at y1 and y2 once the slowest ray comes out of slab,
$$t=l/v => t = l/ ( \mu_0 + d \delta \mu)$$
Hence $$ \Delta x = l(\mu_0 + d \delta \mu) \frac {(y_2-y_1) \delta \mu}{(\mu_0 + y_1 \delta \mu)(\mu_0 c + y_2 \delta \mu)} $$
