Homework Help: Optics | index of refraction
  1. Feb 10, 2013 #1
    A non-expanding/non-contracting laser beam having a diameter 0.132 m in air strikes a piece of glass (ng = 1.62) at an angle of 52°. What is the diameter of the beam, in m, in the glass?
    2. Relevant equations
    snell's law, n1sin(θ1)=n2sin(θ2)
    3. The attempt at a solution
    I get the feeling that the diameter should remain the same. I dont understand why it would be any different than that. Please let me know if I am wrong
  3. Feb 10, 2013 #2
    ehild
    "I get a feeling" is not a prof. Prove that it is the same. A drawing can help.
    ehild
  4. Feb 10, 2013 #3
    Well I did do a drawing. And what I did was picture the "walls" of a cylinder of laser light as independent rays. Those transmitting through the surface of glass should remain parallel due to Snell's law. But I am not sure if I am allowed to do this.
  5. Feb 10, 2013 #4
    ehild
    The rays stay parallel with each other, but make an angle with the incident beam. How is the diameter of the beam defined?
    ehild
  6. Feb 10, 2013 #5
    I copied the question exactly, so that info in the op is all I got. In my drawing, the beam itself is 38 (90-52) degrees from the normal vector from the glass. Since the beam in my picture is a set of two parallel lines, then each of these lines have the same incident angle, which to me would mean that they transmit through the glass at exactly the same angle, leaving the beams parallel and thus, the diameter constant throughout the whole problem.
    I feel my logic is sound however, I cant help but wonder if there is some principle about a non converging, non diverging laser travelling from media. I mean, is it at all possible that the laser converges or diverges after it travels through the glass? It seems very possible that it does, I am just missing the "why" and "how".
  7. Feb 10, 2013 #6
    TSny
    2017 Award
    Have you tried drawing an exaggerated picture where the incoming beam is about 70 degrees to the normal while the refracted beam is about 20 degrees to the normal?
    Following echild, make sure you are interpreting the diameters correctly.
  8. Feb 10, 2013 #7
    Oh i think i understand now. Its because the beam is hitting at an angle, so the diameter of the transmitted beam will basically equal the surface area of the glass that is being essentially lit by the laser, which will be larger than the diameter.
  9. Feb 10, 2013 #8
    Is it of your guys' opinion that the 52 degrees (that the problem stated) is an incident angle or the angle with respect to the glass surface?
  10. Feb 10, 2013 #9
  11. Feb 10, 2013 #10
    TSny
    2017 Award
    Note that y is not the diameter of either beam. Can you draw the diameter of the refracted beam similarly to the way you drew the diameter of the incident beam?
  12. Feb 10, 2013 #11
    shouldnt y be correct though? I dont understand how the refracted beam could be different than that what I got.
  13. Feb 10, 2013 #12
    TSny
    2017 Award
    Note that you drew the diameter of the incoming beam as a line that is perpendicular to the rays of light. Shouldn't you do that also for the refracted beam?
  14. Feb 11, 2013 #13
    You are absolutely right, Thank you very much
Loading...
