Homework Help: Optics - Intensity
  1. Jan 13, 2008 #1
    Parallel rays of light pass of wavelength 540nm throught a 0.4mm slit. The intensity of the central maximum on a diffraction pattern 1.5m away is Io. At what distance from the central maximum does the intensity fall to Io/2?
    2. Relevant equations
    I = Io sin^2 (pi a y / lambda d) / (pi a y / lambda d)^2 (????)
    3. The attempt at a solution
    Okay, I worked out the distance from the central maximum to the first minimum to be
    2.03mm, so it's obviously less than that... beyond that, I'm stuck. Any ideas?
Draft saved Draft deleted
