Homework Help: Optics physics question
  1. Nov 5, 2008 #1
    ABCD represents a square glass block. An object O is placed near the face AB as shown. When observed from the face AD, the object will
    (a) appear midway between A and B
    (b) appear nearer to A
    (c) appear nearer to D
    (d) not be seen at all
    The answer key tells me that the answer is (d) but I don't know how to prove it.
    2. Relevant equations
    [itex]\frac{sin\ i}{sin\ r}=\frac{n_2}{n_1}[/itex]
    3. The attempt at a solution
    I was trying to show that all the rays of light from O to AD are parallel or convergent (real image) but was unsuccessful.
  3. Nov 6, 2008 #2
    tiny-tim
    Re: Optics
    Hi alexmahone! :smile:
    This isn't a focussing problem.
    Hint: choose a typical point P on AB …
    draw the ray OP … where does it go … does it hit AD …
    if it does, can it get out, or is it internally reflected? :smile:
  4. Nov 7, 2008 #3
    Re: Optics
    The ray OP may escape through CD or get totally internally reflected at AD.
    The minimum angle of incidence at AD is when P is very close to A.
    So I only need to prove that total internal reflection occurs even when P is very close to A?
  5. Nov 8, 2008 #4
    tiny-tim
    Yup! :biggrin:
  6. Nov 8, 2008 #5
    Re: Optics
    But what if the rays that are totally internally reflected at AD also totally internally reflect at CD, BC and AB respectively and ultimately exit through AD?
    How do I exclude this possibility?
  7. Nov 8, 2008 #6
    tiny-tim
    If it reflects off one side, it'll hit the next side at the complementrary (90º -) angle, so it should get out.
    Even if the refractive index was so high that it couldn't get out, it would still get back to AD at the original angle, and go round again and again! :smile:
  8. Nov 8, 2008 #7
    Re: Optics
    Thanks so much! :)
