Optimization Help
  • Thread starter hallowon
hallowon
37
A telephone company has to run a line from point A on one side of a river to another point B that is on the other side, 5km down from the point opposite A. The river is uniformly 12 km wide. The company can run the line along the shoreline to a point C and then under the river to B. The cost of the line along the shore is $1000 per km and the cost under the river is twice as much. Where should point C be to minimize the cost?
Heres the recreated diagram that came qith question : http://smg.photobucket.com/albums/v28/pokemon123/?action=view&current=opimzation.gif
Cost =2000()+1000()
Answers and Replies
Dick
26,263
619
Ok, let x be the distance between A and C. Now I think you want to put expressions for distances in terms of x into () and (). Can you do that?
hallowon
37
alright ill try.
hallowon
37
i can't seem to put it in terms of x do i have to use pythagorean theorum using 12 and 5 km?
Dick
26,263
619
Yes, you do. Start with filling in the () in 1000(). You don't need the pythagorean theorem for that one. Then try the () in 2000(). You do for that one.
hallowon
37
So, Cost =1000x + 2000(12^2 + 5^2)^(1/2)
Cost' = 1000?
x= 0?
hallowon
37
Or, Cost =1000x + 2000(12^2 + (5-x)^2)^1(/2)
Dick
26,263
619
Cost' = 1000?
x= 0?
1000(x) is good. 2000(12^2 + 5^2)^(1/2) is less than good. The distance across the river is 12. The distance along the bank isn't 5. The distance along the bank between A and B is 5. What's the distance along the bank between C and B?
Dick
26,263
619
Yes. That's what you want.
hallowon
37
So far ,Cost =1000x + 2000(12^2 + (5-x)^2)^1(/2)
Cost'= ((2000x-10 000/sqrt(x^2-10x+169)) +1000)
0 =
-1000sqrt(x^2-10x+169) = 2000x-10 000
sqrt(x^2-10x+169) = -2x+10
x^2-10x+169 =(-2x+10)^2
x^2-10x+169 = 4x^2-40+100
0 = x^2-10x-23
The answer on the back of my book says it is x=0 but this one yield no nice numbers.
Dick
26,263
619
If you don't get any minima between x=0 and x=5 then the cost minimum must be at either x=0 or x=5. Test them both and see which is less. If it's any encouragment, I got the same quadratic as you did for the minimum.
Suggested for: Optimization Help
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
9K
  • Last Post
