Maximizing the Sum of Squares for Two Non-Negative Numbers with a Given Sum
In summary, to find the two non-negative numbers with a maximum sum of squares when their sum is 30, set a as x and b as 30-x. After expanding and taking the derivative, the maximum values occur at the ends of the interval. The solution on the worksheet may have been a typo or meant to find the minimum instead.
NATURE.M
301
Two non-negative numbers are chosen such that their sum is 30. Find the numbers if the sum of their squares is to be a maximum.
let a,b represent the two non negative numbers
a=x
b=30-x
So, x^2+(30-x)^2=s, where s is the sum of their squares
After expanding, the derivative is:
s'=4x-60
let s'=0, then x=15.
The interval for possible x values is 0≤x≤30.
So let us check which value gives a maximum.
s(15)=450
s(0)=900
s(30)=900
Therefore, the two non-negative numbers are 0 and 30. Is this right? I ask because the solution on a worksheet I have indicates that the two numbers are 15 and 15.
You are correct that the maximums occur at the ends. Probably a typo in the problem. Maybe they meant minimum.
1. What is Optimization number question?
Optimization number question is a mathematical problem that involves finding the maximum or minimum value of a given function, subject to a set of constraints. It is a commonly studied topic in mathematics and is used in various fields such as economics, engineering, and computer science.
2. What are some common techniques used to solve optimization number questions?
Some common techniques used to solve optimization number questions include calculus, linear programming, dynamic programming, and heuristic algorithms. These techniques involve finding the derivative of the function, creating a linear model, breaking down the problem into smaller subproblems, and using approximations respectively.
3. Why is optimization number question important?
Optimization number question is important because it allows us to find the best possible solution to a problem, given a set of constraints. This can help us make better decisions, improve efficiency, and save resources in various real-world situations.
4. What are some real-world applications of optimization number question?
Optimization number question has many real-world applications, including resource allocation, production planning, portfolio optimization, and network optimization. It is also used in machine learning and artificial intelligence to optimize algorithms and models.
5. What are the key steps in solving an optimization number question?
The key steps in solving an optimization number question are:
  1. Identify the objective function and the constraints of the problem.
  2. Find the derivative of the objective function and set it equal to zero to find critical points.
  3. Determine the feasible region by graphing the constraints.
  4. Use the critical points to evaluate the objective function at each point in the feasible region.
  5. Compare the values to find the maximum or minimum value of the objective function.
