Homework Help: Optimization problem
  1. May 3, 2010 #1
    A right circular cone of base radius r and height h has a total surface area S and volume V . Show that 9V2=r2(S2-2pir2S) . (i can do this part) . Hence or otherwise , show that for a fixed surface area S , the maximum volume of the cone occurs when its semi-vertical angle , theta is given by tan theta=1/2(root 2)
    3. The attempt at a solution
    From the proven equation ,
    9V2=r2(S2-2pir2S)
    Differentiate this wrt to r ,
    dV/dr=(2S2r-8pi Sr3)/(18V)
    dV/dr=0 , S=4pi r2 , substitue S with the area of cone , then
    tan theta=r/h=1/(2 root 2)
    This is my question , how do i prove that its a maximum ?
  3. May 3, 2010 #2
    Re: optimization
    when you took the derivative of the Volume function and set it equal to zero you are finding a critical value.
    There are a couple ways to test whether it is a local min or max. The second derivative test is one of them.
    note: I have to check your derivation; not that I am doubting it or anything.
