Optimization problem
  • Thread starter pyrosilver
pyrosilver
39
Find the abs max and abs min values of the function
f(x) = -2x^2 + 3x + 6x^(2/3) + 2.
So the candidates are the endpoints, where f'(x) = 0, and where f(x) DNE.
f(-1) = 3
f(3) = 5.481
For the derivative of the function, i got to f(x) = -4x + 3 + (1/(4x^3)). Set it to 0. But I can't find what x is. How do I use my calculator to find this? For the past five years, I haven't been allowed to use a calculator for my math courses, so I don't really know how to do anything with it. This year, I can use one, but I'm not sure how to use it to find x.
Also, f('x) DNE at x = 0. How do I use that information to determine the value to put that as a candidate for the abs max and abs min?
Answers and Replies
8,408
f(-1) = 3
f(3) = 5.481
Your derivative has two errors. It should be f'(x) = -4x + 3 + 4x-1/3. Note that the last term is the same as 4/x1/3, not 1/(4x3), as you have.
Solving for the value that makes f'(x) = 0 involves solving a somewhat messy cubic equation. There are ways to do this analytically, but they're not usually taught.
It could be that you are expected to graph the derivative on your calculator and then observe the value(s) of x at which the y value is zero. I'm assuming you have a graphing calculator. If you don't know how to do this, look at the instruction manual for your calculator.
pyrosilver
39
Ah okay, thanks I'll fix that up.
Actually I don't currently have a graphing calculator, but i just plotted it out on an online one. To make sure the graphing calculator wasn't faulty, is x = .799999? Sometimes the online ones are a bit sketchy.
Thanks for your help!!
Anyone know about the DNE case?
8,408
The value I'm getting where the derivative is zero is about 1.6.
The domain of f is all real numbers, so there are no numbers at which f does not exist. The derivative isn't defined at x = 0, but you already knew that.
pyrosilver
39
Ah okay, thank you Mark44!!
Suggested for: Optimization problem
  • Last Post
  • Last Post
