1. Not finding help here? Sign up for a free 30min tutor trial with Chegg Tutors
Optimization Question
Tags:
  1. Sep 5, 2015 #1
    First post on these forums, thanks all for your help!
    It is estimated that the growth rate of the fin whale population (per year) is rx(1 - x/K), where r = 0.08 is the intrinsic growth rate, K = 400,000 is the maximum sustainable population, and x is the current population, now around 70,000. It is further estimated that the number of whales harvested per year is about 0.00001 Ex, where E is the level of fishing effort in boat-days. Given a fixed level of effort, population will eventually stabalize at the level where growth rate equals harvest rate.
    EDIT- FORGOT A, B, AND C.
    a. What level of effort will maximize the sustained harvest rate? Model as a one-variable optimization problem using the five step method.
    b. Examine the sensitivity to the intrinsic growth rate. Consider both the optimum level of effort and the resulting population level.
    c. Examine the sensitivity to the maximum sustainable population. Consider both the optimum level of effort and the resulting population level.
    2. Relevant equations
    G(x) = rx(1 - x/K)
    H(x) = 0.00001 Ex
    F(x) = G(x) - H(x) <------ this F(x) isn't given explicitly in the original problem, but I think it's necessary to solve the problem.
    3. The attempt at a solution
    Intuitively, I had thought you would differentiate F(x) with respect to E, and then solving for 0 (first derivative test to see when the slope = 0, therefore E would be maximized). However, that gives you dF/dE = .00001x which is basically useless in maxing H(x)
    My next attempt will be to differentiate it with respect to x, and then perhaps run the first derivative test to see where population can be maxed? Because H(x) will be maxed when x is maxed (but E has to remain constant).
    Whatever insight the reader of this post can provide to the writer will be greatly appreciated!
    P.S. We are allowed to use Wolfram Mathematica to solve these problems.[/B][/B]
  3. Sep 5, 2015 #2
    BruceW
    Hi lazystudent ! honest name :)
    Yeah, I agree that your ##F(x)## function is important to this problem. But I don't think you should be differentiating it. First think of what that function means for this problem. ##G(x)## is a growth rate and ##H(x)## is the rate at which they are harvested, so this should tell you what ##F(x)## is, intuitively.
  4. Sep 5, 2015 #3
    Thank you for your response BruceW.
    Well, the (nominal) growth rate minus the harvest rate will equal the REAL growth rate. But I believe the problem is asking for what level of constant E will max H(x).
    I emailed my professor. I think your response just confused me more than I already was :( if we aren't supposed to use differentiation to optimize the harvest rate, I literally am stumped.
  5. Sep 5, 2015 #4
    Ray Vickson
    Given a value of ##E##, you have a recursion connecting the population ##x_{n+1}## at time ##t = n+1## with the population ##x_n## at time ##t = n##. This has the form
    [tex] x_{n+1} = f(x_n), [/tex]
    where
    [tex] f(x) =x + r x \left( 1 - \frac{x}{k} \right) - c E x. [/tex]
    Here, r = 0.08, k = 400,000, c = 0.00001 = 1.0 e(-5).
    To find the "stable" (limiting value) ##x_{\infty} = \lim_{n \to \infty} x_n##, you can apply the "cobweb plot" method; see
    https://en.wikipedia.org/wiki/Cobweb_plot or
    http://www.ms.unimelb.edu.au/~andrewr/620341/pdfs/ga_sum.pdf , for example.
    The actual level of ##x_{\infty}##---or if it exists at all---will depend on the value of ##E## that you choose. I guess that you are supposed to choose ##E## in such a way that something desirable happens to the value of ##x_{\infty}##, but your problem description does not say what that is.
    I don't think differentiation has much to do with the problem, at least not until you have determined the value of ##x_{\infty}## as a function of ##E##.
  6. Sep 5, 2015 #5
    Edited first post - totally freakin forgot A, B, C, and D!
  7. Sep 5, 2015 #6
    In rereading my attempt at a solution for A, I realized that the problems wants me to find at what constant E can we max H(x) given that F(x) = G(x) - H(x).
    I don't know what exactly I was doing differentiating H(x) with respect to E.
    EDIT
    I differentiated F = rx(1-[x/k]) -0.00001Ex with respect to x, giving me
    dF/dx= r(1-[x/k]) - (rx)/k - .00001E. I plugged in r=.08, K = 400000, and x = 70000. I set dF/dx = 0 and solved for E. I got
    E = 5200.
    Is this the correct max sustained harvest rate??? Am I even on the right track?
  8. Sep 5, 2015 #7
    Ray Vickson
    The question stated clearly that the population will settle down to a sustainable value of x for which the growth rate = the harvesting rate. For any value of E, that condition gives you an equation in x, whose solution is the sustainable population. It will be a function of E, call it X(E). What is the harvesting rate corresponding to population x = X(E)? How can you maximize it?
  9. Sep 6, 2015 #8
    BruceW
    I agree with Ray :) You used x=70,000, which is the current population. But you should be finding the long-term 'sustainable population'. Also, you were differentiating F(x) but that means you were trying to find the max value of rate of population change? that is not a relevant quantity for this problem.
Have something to add?
Draft saved Draft deleted
Similar Discussions: Optimization Question
  1. Optimization question (Replies: 1)
  2. Optimization Question (Replies: 3)
  3. Optimization Question (Replies: 1)
Loading...
