What does this tell you about how the moons were created?
  • Thread starter physics(L)10
  • Tags
    Moons
In summary: Hi physics(L)10!In summary, the two moons have different radii, which implies that they have different densities. Since the periods of the two orbits are the same, this suggests that the moons were created from the same gas disc.
physics(L)10
101
Two identical spaceships are sent to explore a planet with two moons. Each spaceship orbits one of the moons.
a)The orbital radii are observed such that the spaceship have the same period. What is the relative mass of the two moons if the two radii differ by a factor of 2.
b) If the two moons have a similar radius, what does this imply about their density? What does this tell you about how the moons were created?
a=v^2/r
v=2pi^2/T
ma=Gm(Mearth)/r^2
F=Gm1m2/r^2
a) 4pi^2/T^2=G(Mearth)/r^2
since T is the same, T=1
b) If the two moons have similar radius, then they should have different densities (if the relative masses are different in part a)
Hi physics(L)10! :smile:
(have a pi: π and try using the X2 and X2 tags just above the Reply box :wink:)
physics(L)10 said:
a=v^2/r
v=2pi^2/T
ma=Gm(Mearth)/r^2
F=Gm1m2/r^2
Not really following that … can you write it out more fully? :confused:
(and v = 2πr/T)
So where did they come from? :wink:
That was just a guess because I don't really have a clue on what to do, that's why you can't understand lol. I'm guessing they came from different planets. I can't answer b without knowing the answer to a though.
ok, start with your two equations for acceleration, then eliminate the acceleration to get an equation relating v T and r …
show us all the steps. :smile:
Well, from different places … they needn't have come "from planets", they could have been part of the same gas disc that the planets were formed from, or they could have been limps knocked off planets, or they could have been comets etc from a long way away. :wink:
a=v^2/r, where v=2πr/T
Therefore, a=(2πr/T)^2/r=4π^2r/T^2
Then, you plug this value for a into the equation ma=GmMearth/r^2
b) Believe it or not I was actually thinking that lol.
(please use the X2 tag just above the Reply box :wink:)
ok, so your equation relating v T and r is … ? :smile:
We believe you … but the examiner needs you to say it. :wink:
The equation would be 4π2r3/T2=GMearth. I`m guessing you have to isolate for r now, but I`m confused on how to integrate that the periods are the same and the radii differ by a factor of 2.
(just got up :zzz: …)
(earth? … is one of the moons called "earth"?! :rolleyes:)
ok, this is now a dimensions question …
never mind the constants (4π2 and G), they don't matter :wink:
you're only interested in the powers of r M and T …
if you keep T the same and double r, what happens to M? :smile:
Lmao, I`m used to putting earth. M gets bigger if you double the radius. So would one of the moons mass just be double the other moon and that would be your answer?
uhh? :confused:
r3/T2 = constant times M, so … ? :smile:
Ok, this is what I thought of first. When you cross multiply the T (which is constant) multiplies with M so you get M. Then you divide M by 2 and then cube root the answer and you get a smaller answer. But then I used common sense and thought that shouldn`t the mass be larger if the radius is bigger?
hmm … doing it with equations is easier than doing it in English …
you have T2 = r3/M …
so, if T is constant, then r3/M is constant ……
does that help? :smile:
Not really lol. I was thinking more along the lines of r3=M and then cubed root M to find the radius. The T can be ignored since its a constant and is the same for both moons.
Yes, that's right :smile: … what is worrying you about that? :confused:
So one moon would just be half the mass?
How did you get that? :confused:
One would be r3=M and the other would be 2r3=M which is r3=M/2
Sorry, but you'll never be able to do these questions in the exam if you don't learn to tidy up your notation. You can't keep using "r" for everything without losing track. :redface:
Your basic formula is r3 = kM (for a constant k).
Now you can put values in for each of the two satellites, making …
r13 = kM1
r23 = kM2
and you are given the relationship r2 = 2r1.
Try it that way. :smile:
One would be r13=kM1 and the other would be 2r23=kM2 which is r23=kM2/2
physics(L)10 said:
… the other would be 2r23=kM2
Nooo!
It's still only r23=kM2
that's the point of a formula!
Then where does the factor of 2 come in?? lol
uhh?
tiny-tim said:
… and you are given the relationship r2 = 2r1.
So the radius IS 2x larger
1. How were the moons formed?
The most widely accepted theory is that the moons were formed through a process called accretion, where smaller objects in the early solar system collided and stuck together, gradually forming larger bodies like moons.
2. Could the moons have been captured by the planet?
It is unlikely that the moons were captured by the planet, as this would require precise timing and positioning, and the captured moons would have a different composition than the planet itself. Accretion is a more likely explanation.
3. Is it possible that the moons were formed at the same time as the planet?
Yes, it is possible that the moons were formed at the same time as the planet, but this is less likely as it would require the planet to have a much larger disk of material around it during its formation.
4. What do the moons' compositions tell us about their formation?
The moons' compositions can provide insight into the materials present in the early solar system and the conditions under which they were formed. For example, the presence of certain elements or compounds can indicate whether the moons were formed through accretion or from a larger impact.
5. Are there any other theories for how the moons were created?
Yes, there are other theories such as the fission theory, which suggests that the moons were once part of the planet and broke off due to its rapid rotation, or the co-formation theory, which proposes that the moons and the planet formed together from the same disk of material. However, these theories are not as widely accepted as the accretion theory.
