Discover the Relationship Between Escape Speed and Circular Orbit Speed
In summary, the equation you've set up gives Vc, since it simply says that the force of gravity produces the necessary centripetal acceleration for circular motion at distance r.
starbaj12
49
Show that the escape speed from a planet is related to the speed of a circulat orbit just above the surface of the planet by Ve = square root(2Vc), where Vc is the speed of an object in the circular orbit.
I'm looking at GMem(object)/r^2 = m(o)v^2/r
But I do not know if this equation will help or how to connect it together with anything else. Any help would be great.
OK, here's some questions that may help us help you
Do you know the formula for the potential energy of an object a distance R away from a planet - and how this relates to the escape energy?
Do you know how to relate energy to velocity, to translate escape energy into escape velocity?
First of all, let's agree that the equation you've set up gives Vc, since it simply says that the force of gravity produces the necessary centripetal acceleration for circular motion at distance r.
Hence, what you are lacking, is an equation which yields the escape velocity Ve.
Unless you have that, you cannot compare Vc with Ve!
So, question:
How can you find an equation which can be said to yield Ve?
Post a few of your own thoughts on it, particularly what you think is MEANT with the concept "escape velocity"!
Are you talking about U(r) = -GMm/r
The bigger the radius the smaller the potential energy
Ve = square root ( 2GMe/Re) = square root(2gRe)
Is this what you are talking about?
escape velocity to me means the speed it takes to overcome gravity (air friction negligible) leaving orthogonal from the surface of the planet
This is correct!
Now compare Ve and Vc!
I got it!
Thank you arildno
1. What is the relationship between escape speed and circular orbit speed?
The relationship between escape speed and circular orbit speed is that they are both dependent on the mass and distance of the object being orbited. Escape speed is the minimum speed required for an object to escape the gravitational pull of another object, while circular orbit speed is the speed at which an object must travel to maintain a circular orbit around another object.
2. How are escape speed and circular orbit speed calculated?
Escape speed is calculated using the formula v=sqrt(2GM/r), where G is the gravitational constant, M is the mass of the object being orbited, and r is the distance between the two objects. Circular orbit speed is calculated using v=sqrt(GM/r), where the variables have the same meaning as in the escape speed formula.
3. Why is escape speed greater than circular orbit speed?
Escape speed is greater than circular orbit speed because it takes more energy to escape the gravitational pull of an object than it does to maintain a circular orbit around it. This is because to escape, an object must overcome the object's gravitational force completely, while in a circular orbit, the object is constantly being pulled towards the center of the orbit.
4. How does the mass of an object affect escape speed and circular orbit speed?
The mass of an object being orbited has a direct effect on both escape speed and circular orbit speed. As the mass of the object increases, both speeds will also increase. This means that it will take more energy to escape the gravitational pull of a more massive object compared to a less massive one.
5. What is an example of the relationship between escape speed and circular orbit speed?
An example of the relationship between escape speed and circular orbit speed can be seen with Earth and its moon. The escape speed from the Earth's surface is approximately 11.2 km/s, while the circular orbit speed of the moon around the Earth is about 1 km/s. This means that it takes significantly more energy to escape Earth's gravitational pull compared to the amount needed to maintain a circular orbit around it.
