- #36
Ibix
- 13,490
Note: I'm still learning GR. Don't assume the following is a valid analogy until Peter, pervect, Nugatory et al haven't shot it full of holes.
If you look at the rings on a dartboard, the radius of each circle is r, and this is equal to the distance to the centre of the board.
If you look at latitude lines on the Earth, each one is a circle with a radius r which is not simply related to the distance to the pole.
Newtonian theory assumes a flat, Euclidean background (like the dartboard), where the circumference of a circle is simply related to the distance from the bullseye. GR allows more complex geometries where the distance to the the singularity (analogous to the pole of our sphere) is not simply related to the circumference of a circle around it (analogous to a line of latitude).
So, Newtonian calculations tell you that the escape velocity at some distance from the bullseye is something. GR calculations tell you that the escape velocity at some distance from the rotation axis of the Earth is the same as the Newtonian calculation. But the distance to the rotation axis of the Earth is not the distance from the pole and, in the real space-time case rather than the sphere analogy, isn't a distance with any real meaning - just a convenient mathematical concept. Which is why everyone is telling you that it is a coincidence that the expressions are the same.
