Why do we have order of operations in math?
  • Thread starter pzona
  • Tags
    Operations
In summary, the order of operations is entirely a convention that has been developed for the sake of convenience in mental manipulation of symbols. It is not based on any mathematical reasoning and could be done differently if necessary. This convention is important in written math as it makes it easier for the human mind to comprehend and manipulate expressions. However, in programming languages, it is less important as the syntax is designed for the computer to understand. The use of letters and symbols in math notation also follows convention for ease of understanding.
pzona
234
Just a random thought I had today. Where does the order of operations come from? Is there a mathematical basis for it, or is it just a set of accepted rules developed out of necessity? As far as I can tell, these rules only exist for the purpose of having a convention to follow. Is this accurate, or is there something deeper behind it? Like I said, just curious
Mathematics news on Phys.org
It is convention as far as I know.
I believe this is a question of psychology, not mathematics.
The armchair* psychologist in me thinks it involves spatial relationships: our visual systems allow us to instantly parse a big expression like
3x + 17uvw - 16h2
But notice how it's much harder to read
[tex]3 \times x + 17 \times u \times v \times w - 16 \times h\uparrow 2[/tex]​
Interestingly, I find this somewhat easier to read:
[tex]((3 \times x) + (17 \times u \times v \times w)) - (16 \times (h\uparrow 2[/tex]))​
there are even more symbols, so I initially thought it would clutter things up, but the parentheses are cues to help group things together. I think that's just because it's typeset well and a good choice of symbols: it would probably be harder monospaced, with a more intrusive deliminter. (e.g. try # & instead of ( ))
##3*x&+#17*u*v*w&&-#16*#h^2&&
*: Meaning I have no training in this subject
It is entirely convention. PEMDAS is merely convenient for mental manipulation of symbols on the page. Parentheses alone would be adequate enough to specify order of operations.
In fact, in the Lisp programming language, this is exactly the way things are done. Lisp was designed to have the most simple syntax possible. Everything in the entire language can be written with symbols (names like f, x, cons, lambda, +, *, ...), numbers (0, 1, 2, ...), and parantheses (... do I really need to put parentheses inside parentheses?...). The operator/function name is written first, followed by the operands. So the expression x + 2y + 1 would be written as (+ (+ x (* 2 y)) 1). The result is a syntax which is easy for a computer to parse and which is totally unambiguous.
In written math, though, it's much more important that the notation cater to the human mind, not to a computer. Humans can infer meaning based on context, so it can be somewhat ambiguous. Our PEMDAS notation makes it easy to write out, group things, and mentally move symbols about the page.
We can leave off needless parentheses (which would otherwise just be "line noise" in programmer terminology), and we can do operations in parallel. If you want to know a polynomial's power, the raised position of the exponents makes it very fast to visually track down the biggest power.
When a linear operator is applied to a polynomial, it's very easy to distribute the operator over the terms.
In defining functions and doing calculus, we almost always rely on the convention of using one of x, y, z, u, v, t, s, w, or some Greek letter for the parameter. You don't see too many f(g) = g^2 - 1, even though syntactically, it's totally legitimate.
One source of confusion in programming languages (and I'm sure, in some areas of math) are use of unfamiliar operators. There are tons of operators in programming, such as &&, |, ++, !, ~, >>, <<, and ^, which appear over and over again... and it's not always clear what their precedence is. A good programmer will always put those expressions in parentheses, so other programmers, who might not be as intimately familiar with the language, are able to figure out the meaning without having to look it up in the manual. In Haskell, the situation is FUBAR beyond belief, because any programmer can define new operators and give them their own precedence.
Yes, it is purely convention, arising out of the way we choose to write formulas- which is itself convention.
Alright, this basically confirms what I thought previously. Let's take an example of 2x+y, for which x=1 and y=4. Based on the idea that the order of operations is just conventions, 10 is no less legitimate an answer than 6, right? Sorry if this seems like a basic question, it's just strange to think about, given the ideas I've been learning my entire life. Also, is there any particular reason that this set of rules is defined as the order of operations? This seems like it might be more psychological or philosophical than mathematical. Does anyone know of any good links regarding this?
By the way, thank you all for the answers so far, they've been very helpful.
What is the Order of Operations?
The Order of Operations is a set of rules that determine the sequence in which mathematical operations should be performed in an equation. It helps to ensure that everyone gets the same answer when solving an equation.
What are the steps in the Order of Operations?
The steps in the Order of Operations are:
1. Parentheses - solve equations inside parentheses first
2. Exponents - solve any exponential expressions
3. Multiplication and Division - solve from left to right
4. Addition and Subtraction - solve from left to right
Do I always have to use the Order of Operations?
Yes, using the Order of Operations is necessary in order to get the correct answer when solving equations with multiple operations. It is a universally accepted method for solving equations and helps to avoid confusion and ambiguity.
Can I change the order of operations in an equation?
No, the Order of Operations is a standard set of rules that should not be changed. Altering the order of operations can lead to getting incorrect answers and can cause confusion in mathematical expressions.
What happens if I don't use the Order of Operations?
If the Order of Operations is not followed, it can result in getting incorrect answers when solving equations with multiple operations. It is important to use this set of rules in order to get the correct solution.
  • Linear and Abstract Algebra
  • General Math
  • Quantum Interpretations and Foundations
