Ordering a number array by shifting
  • Thread starter Detektyw
  • Tags
    Array
In summary, the problem involves finding a sequence of operations to sort a given permutation of a set using two types of operations, with a maximum length of n^2. The key to finding an efficient solution is to identify patterns and use them to move the elements to their correct positions. Possible approaches include working backwards from the final sorted array or using a sorting algorithm.
Detektyw
Given a permutation of the set {1,...,n} for a natural n, and two possible operations on this set:
Type-1(k): Shift the first element in the array to the back of it, do it k times.
[3,2,1,4] -> T1(1) -> [2,1,4,3]
Type-2(k): Shift the third element in the array to the front, do it k times.
[3,2,1,4] -> T2(1) -> [1,3,2,4]
Determine whether it is possible to sort it in an increasing order, and if so, find the sequence of operations necessary to do this. The length of the sequence of operations has to be equal to or smaller than n^2.
- None so far.
So far, I've gotten an algorithm which is correct, however way too slow.
It is based on the following observations:
* T1 is periodic in n, since V -> T1(|V|) -> V,
* T2 is periodic in 3, since V -> T2(3) -> V
Now, starting with the initial positions, we can test the effects of a T1 move and T2 move, check whether they yield a sorted array, if not, for each of them do the same.
Recursion then bottoms out when
a) the length of the move sequence exceeds n^2
b) it would be forced to make third T2 move in a row
c) or n-th T1 move in a row
If the main recursion returns without having found a solution, this means there is none which fit the description.
This one clearly works, but it does so in an abysmal complexity (worst case, don't know if it can happen, would be a solution n^2 long, consisting of ~0.5n2 T1(n-1) shifts and ~0.5n2 T2(2) shifts. This way we get O(n) for checking whether the solution is sorted, times O(2n3), hence O(n2n3)).
Any help with finding a more optimal solution (polynomial time) would be appreciated.
your first step would be to analyze the problem and see if there are any patterns or properties that can be exploited to find a more efficient solution.
One possible approach could be to think about the final sorted array and work backwards to see what operations would need to be performed to get to that state. For example, if we consider the example given in the problem statement where n=4 and the initial array is [3,2,1,4], the final sorted array would be [1,2,3,4]. Working backwards, we can see that the first operation would need to be a T2(2) to move the 3 to the front, followed by a T1(1) to shift the 2 to the back. This gives us [2,3,4,1]. Next, we would need a T2(1) to move the 2 to the front and a T1(1) to shift the 3 to the back, giving us [3,4,1,2]. Finally, we would need a T1(2) to shift the 3 and 4 to the back, giving us the final sorted array [1,2,3,4]. This sequence of operations has a length of 5, which is much smaller than n^2 for n=4.
From this example, we can see that the key is to find a way to efficiently move the elements to their correct positions. This can be done by first finding the position of each element in the final sorted array and then determining the minimum number of operations needed to move that element to its correct position.
Another approach could be to use a sorting algorithm such as bubble sort or insertion sort, which can be implemented in O(n^2) time. These algorithms use a combination of swaps and shifts to sort the array, which are similar to the operations given in the problem statement.
In conclusion, as a scientist, your task would be to analyze the problem, identify patterns and properties, and come up with an efficient algorithm to solve it. You may also want to consider different approaches and compare their efficiency to find the most optimal solution.
FAQ: Ordering a number array by shifting
1. How does shifting affect the order of numbers in an array?
The order of numbers in an array is affected by shifting in that the position of each number within the array is changed. The shifted number will move to a new index in the array, while the other numbers will move to the index that comes before or after the shifted number, depending on the direction of the shift.
2. What is the process for shifting an array of numbers?
The process for shifting an array of numbers involves selecting the number to be shifted, determining the direction of the shift (left or right), and then moving the number to its new position in the array by updating the indexes of the other numbers accordingly. This process is repeated until all desired numbers have been shifted.
3. Can numbers in an array be shifted more than once?
Yes, numbers in an array can be shifted more than once. This will result in the numbers moving to different positions in the array each time. However, it is important to keep track of the original position of each number in order to avoid errors in the shifting process.
4. How does shifting an array affect its length?
Shifting an array does not affect its length. The total number of elements in the array will remain the same, but the order and position of the numbers within the array will change.
5. What are some common use cases for shifting an array of numbers?
Shifting an array of numbers can be useful in a variety of situations, such as alphabetizing a list of names, sorting numbers in ascending or descending order, or reorganizing data in a specific way for a particular algorithm or data structure. It can also be used in mathematical operations, such as rotating a matrix or performing a circular shift.
