1. Not finding help here? Sign up for a free 30min tutor trial with Chegg Tutors
Ordinary differential equations - boat example
  1. Sep 21, 2010 #1
    URGENT! ordinary differential equations - boat example
    A boat of mass m is travelling with the velocity v0. At t=0 the power is shut off. Assuming water resistance proportional to v^n, where n is a constant and v is the instantaneous velocity, find v as a function of the distance travelled. (Note that you need to consider the two cases).
    Please help asap!
    Thanks
    2. Relevant equations
    force balance equations
    3. The attempt at a solution
    I've gotten my ODE to be: m*dv/dt = -kv^n with the initial condition v0 at t = 0.
    It says find v as a function of the distance travelled.
    So i went on to say dv/dt= (dv/dx)*(dx/dt)= v*(dv/dx) so now x is the independent variable not t.
    so, m*v*(dv/dx) = -kv^n
    v*(dv/dx)= -(k/m)*v^n
    v*(dv/dx)= -av^n where a =k/m
    v dv = -av^n dx
    integral (v/(v^n)) dv = integral (-a) dx
    integral (v^(1-n)) dv= -ax + c
    (v^(2-n))/(2-n) = -ax + c (don't know if the integral on the LHS is correct?)
    but x=o at t=0 so v(t=0)=v(x=0)=v0
    so c= (v0^(2-n))/(2-n)
    therefore,
    (v^(2-n))/(2-n) = -ax + (v0^(2-n))/(2-n)
    v^(2-n) = -(2-n)ax + v0^(2-n)
    v^(2-n) = (n-2)ax + v0^(2-n)
    therefore, v= [(n-2)ax + v0^(2-n)]^(1/(2-n))
    but a =k/m
    so v(x) = [(n-2)kx/m + v0^(2-n)]^(1/(2-n))
    does this seem right at all because it seems a little messy?? Also it says to note that you need to consider the two cases. What are the two cases as I've only considered one???
  3. Sep 21, 2010 #2
    lanedance
    Re: URGENT! ordinary differential equations - boat example
    haven't been through the working, but few standrad checks are
    - see if it behaves as you expect, ie monotonically decreasing
    - substitute back into the equation and check it satsifies the orginal DE
    for the 2 cases have a look at the integration step, and consider n = 2
Similar Discussions: Ordinary differential equations - boat example
Loading...
