Exploring the Mystery of Electric Charge: Origins and Properties
In summary, there is currently no definitive explanation for the origin of electric charge. It is known that electric charges have the ability to generate force and an electromagnetic field, and exhibit attractive and repulsive reactions to other charged particles. However, the question still remains about the fundamental reason for the existence of electric charge. Some theories propose that charge may be related to topological solitons or conserved quantities associated with gauge symmetries, but these explanations are still speculative. Ultimately, the origin of electric charge is still a mystery and remains an active area of research.
jafari001
Is there any explanation about the nature of electric charge? Everyon currently knows that an electric charge has ability to generate force and an electromagnetic field. Also, it has attractive and repulsive reactions to other charged particles. Finally, it is known that electric charges obey the law of conservation and quantization. But, the question still remains, what is the origin of electric charge?
Today, it seems we can hardly answer this question, we even can't imagine an "explanation".
We can a most relate the charge of observable particles to the charge of quarks they are made of.
But we probably can't even explain why electron and protons have the (same) exactly opposite charges.
Can we?
By the way, what do you call an explanation?
By the way, if you assume that the world is governed by fields and their symmetries,
the the Maxwell's equations are almost the simplest possibilities.
Maybe the explanation of charge, is "simplicity"?
______
What is the origin of gravity?
It is because an apple falls on earth.
maajdl said:
But we probably can't even explain why electron and protons have the same charge.
They don't have the same charge.
Likes 1 person
Every electron has the same amount of electric charge, conveniently designated as "-1". This has been experimentally verified to extreme precision: http://physics.nist.gov/cgi-bin/cuu/Value?e
Every proton has charge "+1", though not verified to the same accuracy as the electron.
As a result every neutral hydrogen atom (existing as an atom, not as an H2 molecule) has the same spectrum - which has been verified extensively via astronomical and terrestrial measurements: http://physics.nist.gov/Pubs/AtSpec/node03.html
What is the origin of the electric charge? This is unknown - however speculative theories often propose something topological. For example: "Particles as stable topological solitons"
http://iopscience.iop.org/1742-6596/361/1/012022/pdf/1742-6596_361_1_012022.pdf
While technically true, this is not helpful, and not relevant to the OP's question.
jtbell said:
It's the conserved quantity associated with local U(1) gauge symmetry, via Noether's theorem.
This is the answer I would say also. Charge occurs because every differentiable symmetry of the Lagrangian implies the existence of a conserved quantity. The EM Lagrangian has a gauge symmetry, and the corresponding conserved quantity is the charge.
Of course, that begs the question as to why does EM have that gauge symmetry. Right now, that is taken as fundamental and unexplained.
I know.I just said it to prevent confusion.
His post is now edited :wink:
Why does electric charge exist in the universe? Because the universe would be an incredibly boring place without things like chemical reactions, EM waves, and satellite television.
This thread is a crackpot magnet. Thread closed.
1. What is the origin of electric charge?
The origin of electric charge is a fundamental question in physics that scientists have been trying to answer for centuries. Currently, the most widely accepted theory is that electric charge is an intrinsic property of certain particles, such as electrons and protons.
2. How is electric charge created?
Electric charge can be created through various processes, such as friction, contact, and induction. When two objects rub against each other, electrons can transfer from one object to the other, creating an imbalance of positive and negative charges. This is known as the triboelectric effect. In contact, charges can also transfer between objects, and this is known as conduction. Induction occurs when a charged object is brought near a neutral object, causing the charges in the neutral object to rearrange, creating an electric field.
3. Can electric charge be destroyed?
According to the law of conservation of charge, electric charge cannot be created or destroyed; it can only be transferred from one object to another. This means that the total amount of electric charge in a closed system remains constant.
4. What is the difference between positive and negative charges?
Positive and negative charges are two types of electric charge. Positive charges are carried by protons, while negative charges are carried by electrons. These charges have opposite properties, with positive charges attracting negative charges and repelling other positive charges. This is why opposite charges attract and like charges repel.
5. Can objects have a neutral charge?
Yes, objects can have a neutral charge. This occurs when the number of positive and negative charges is equal, resulting in a net charge of zero. Neutral objects can also become charged if they come into contact with a charged object or are exposed to an electric field.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
