Originless Coordinates?
  • Thread starter AverageJoe
This is something that has always been in my mind, yet everywhere I look I can't find an answer.
Is there any type of coordinate system that has no origin?
As in, everything is found by relation to other elements within the model?
:confused:
Mentallic
3,797
94
Do you mean as in a coordinate system that cannot have an origin, or doesn't necessarily need it? I can't imagine any system where an origin isn't used for convenience.
Take the surface of the Earth. Everything can be described in relation to something else so that no origin is required, but without this origin it would be impossible to give a point on Earth a set of coordinates.
arildno
Dearly Missed
9,948
130
:confused:
Yes, that does exist.
Unfortunately, I have forgotten what we call it.
Mentallic
3,797
94
arildno
Dearly Missed
9,948
130
Can you please explain how this system works?
I only vaguely remember it, so I can't say anything further.
It is an abstract geometry without using coordinates at all, basically.
I think..
arildno
Dearly Missed
9,948
130
Okay, I have muddled a lot here!
What I was thinking of is called the "affine plane", and the reason why it doesn't have an origin is that it doesn't have coordinates.
Once you impose coordinates you have, of course, an implied origin.
Sorry about this.
256
Any vector space will have an "origin."
Hmm..Affine Space isn't exactly what I was thinking of.
402
Could it be possible that what you have in mind is a metric space (ir doesn't have to be a vector space, but the more interesting ones are), where you can calculate the distance between any two points, but none of these is a distinguished origin, but where the distance doesn't come from a norm (a norm is a special kind of distance, defined only on vector spaces, that measures distances from the origin, which allows us to define lenghts).
HallsofIvy
41,711
876
But AverageJoe asked for a space that has a coordinate system but no origin. A metric space does not have a coordinate system. Although I suspect that this is the kind of thing he is thinking of.
(By the way, a metric space does not necessarily not have a norm. It may or may not. Given a norm, we can immediately define a metric but not necessarily the other way.)
402
When I stated:
I meant a metric space with a distance that cannot be defined by a norm (for example, it's not translation invariant and/or homogeneous), I didn't meant it doesn't necessarily have a norm; many interesting metrics came from norms.
I don't completely agree (strictly speaking, the definition doesn't require it), but metric spaces that are also vector spaces have coordinate systems; we may forget the vector space structure and retain only the metric one.
But if we want to remain in the vector space category, we have two options: forget the origin and fall in affine space (already mentioned), or the Möbius homogeneous coordinate system.
Maybe it's more of an Omni-Origin coordinate system. Every element is it's own origin, and their dimensions are ratios of their sister elements.
402
Then check the barycentric coordinate system (or Möbius coordinates):
http://mathworld.wolfram.com/BarycentricCoordinates.html" [Broken]
http://en.wikipedia.org/wiki/Homogeneous_coordinates" [Broken]
HallsofIvy
41,711
876
Here's a couple of ideas I had. For the surface of a sphere of radius R, identify each point by spherical coordinates. That is, each point is identified with [itex](R, \theta, \phi)[/itex]. Since R is not 0, there is no point in that surface with coordinates (0, 0, 0).
Or- given a plane, think of it as embedded in three dimensional space and give that space a coordinate system such that its origin was not on the plane. for example, if we take our three dimensional coordinates so that the plane contains (1, 0, 0), (0, 1, 0), and (0, 0, 1), then every point in the plane is given coordinates (x, y, z) where x+ y+ z= 1. Again, there is no point in the plane with coordinates (0, 0, 0). This would be similar to "barycentric coordinates".
Related Threads for: Originless Coordinates?
  • Posted
  • Posted
  • Posted
  • Posted
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
Hot Threads
