Homework Help: Orthogonal vectors in R4?
  1. Mar 25, 2014 #1
    Given following vectors in R4:
    v= (4,-9,-6,3)
    u = (5,-8,k,4)
    w=(s,-5,4,t)
    A. Find value of k if u and v are orthogonal
    B. Find values of S and T if w and u are orthogonal and w and v are orthogonal
    2. Relevant equations
    Orthogonal means dot product is zero
    3. The attempt at a solution
    A. I already solved and got k= 104/6 which is correct
    B.
    I tried to solve this one assuming that k was still equal to 104/6 and got
    s=4 and t=-37/3
    But this is not the answer.
    Do I assume that k is still the same result as in part A or can k be anything?
    If k is anything than I get:
    4 3 -21
    5 4 (-40-4k)
    as a matrix, but how would I solve this?
  3. Mar 25, 2014 #2
    jbunniii
    I think you should continue to use ##k=104/6## in part B. Can you show how you calculated ##s## and ##t##? You can easily check that with those values, ##w## is orthogonal to ##v## but not to ##u##.
  4. Mar 25, 2014 #3
    Okay thats what I thought b/c if k is unknown you have 3 variables which wouldn't be solveable.
    So if k= 104/6
    v*w = 4s + 45 - 24 + 3t = 0
    u*w = 5s + 40 + 416/6 + 4t = 0
    From there I combined like terms:
    4s + 3t = -21
    5s + 4t = -656/6
    Then I formed a matrix and use row operations to find that:
    s = 244
    t = -997/3
    Is this right? I think my mistake the first time using this method was when I got the 40 and 416/6 on the right hand side I added 40 instead of subtracting which changed the value.
  5. Mar 25, 2014 #4
    jbunniii
    Yes, that looks right. You can always substitute your answers back into your expressions for v*w and u*w to verify that you get zero in both cases.
Have something to add?
Draft saved Draft deleted
