Homework Help: Orthogonal vectors
  1. Mar 20, 2014 #1
    Let S be the subspace of all vectors in R4 that are orthogonal to each of the vectors
    (0, 4, 4, 2), (3, 4, -2, -4)
    What is an example of a matrix for which S is the nullspace?
    3. The attempt at a solution
    I'm not sure how I should be intepreting the question:
    [ 0 ,4 ,4 ,2 ;3, 4, -2, -4] = [ x , y ,z , t] = [ 0 , 0 ]
    0x + 4y + 4z + 2t = 0
    3x + 4y -2 z -4t = 0
    from here I set up an augmented matrix and solve for the set of vectors x ,y ,z ,t? By definition if x, y, z, t results in each linear equation = 0, then, x ,y ,z ,t are vectors with properties of orthogonality?
  3. Mar 20, 2014 #2
    ehild
    There is multiplication instead of equality in the first line? If yes, it looks all right, do it.
    ehild
  4. Mar 20, 2014 #3
    [ 0 ,4 ,4 ,2 ;3, 4, -2, -4] .[ x , y ,z , t] = [ 0 , 0 ]
    Yes, it should be a multiplicative operation-dot product.
    But I aren't exactly sure what should I be doing with the 2 linear equation. Do I perform reduce row echelon?
  5. Mar 20, 2014 #4
    ehild
    Yes. But it is of that form already... You will have two free parameters.
    ehild
  6. Mar 20, 2014 #5
    I'm still unclear. Could you explain?
  7. Mar 20, 2014 #6
    ehild
    There is the system of equations:
    What is the general solution?
    ehild
  8. Mar 20, 2014 #7
    It is done by setting up an augmented matrix:
    0 4 4 2 | 0
    3 4 -2 -4 | 0
    Perform REF(Not RREF), then solve for the variables.
    Edit: x1 = 2x3 + 2x4, x2 = -x3-0.5x4, x3, x4
  9. Mar 20, 2014 #8
    ehild
    Well, solve for the variables....
    ehild
  10. Mar 20, 2014 #9
    Post #7
  11. Mar 20, 2014 #10
    ehild
    X3=a, x4=b a,b free parameters. So the S subspace consists of vectors ((2a+2b); (-a-0.5b); a; b).
    And a matrix for which S is the nullspace?
    ehild
  12. Mar 20, 2014 #11
    Relooking at the question, I'm not sure if we interpreted it correctly.
    I think the question is asking for the {SX=0|x1=0,4,4,2, x2=(3,4,-2,-4),S[itex]\in R4[/itex]}
    Edit: I think we were on the right track.
    But this brings up a question. What if we're asked to solve S, given X where SX = 0?
  13. Mar 20, 2014 #12
    Mark44
    Staff: Mentor
    Let's untangle your notation. S is a subspace of R4 such that if v ##\in## S, then v ##\cdot## <0, 4, 4, 2> = 0 and v ##\cdot## <3, 4, -2, -4> = 0.
    The problem asks that you find a matrix (call it A) for which S is the nullspace of A. IOW, if v ##\in## S, then Av = 0.
  14. Mar 20, 2014 #13
    Isn't the vector [2z+2t; -z-0.5t;z;t] the answer?
  15. Mar 20, 2014 #14
    ehild
    S is the nullspace of a linear transformation T, that is, Tv =0 for all vectors v[itex]\in[/itex]S. Show a matrix of that transformation. (You have shown one in Post #3) .
    ehild
  16. Mar 20, 2014 #15
    Mark44
    Staff: Mentor
    See post #12. The "answer" should be a matrix, not a vector.
    In addition, what you have above would be better written as two vectors - a basis for S.
  17. Mar 20, 2014 #16
    Am I suppose to perform another one? I thought we have had all the solutions already. 2 are free variables and the corollary is that there are infinite solutions.
  18. Mar 20, 2014 #17
    ehild
    The subspace S contains infinite number of vectors. You have found these vectors already.
    The next question is
    ehild
  19. Mar 20, 2014 #18
    any matrix with coefficient [itex]\in R[/itex]?
  20. Mar 20, 2014 #19
    basis for S : z (2,-1,1,0) + t (2,-0.5,0,1)
  21. Mar 20, 2014 #20
    HallsofIvy
    Your wording is peculiar. z (2,-1,1,0) + t (2,-0.5,0,1) is a general vector in S. The set of vectors {(2, -1, 1, 0), (2, -0.5, 0, 1)} is a basis.
    The answer to this question is any matrix, A, such that A applied to each of those two vectors is 0.
Have something to add?
Draft saved Draft deleted
Loading...
