Oscillating spring force
  1. Feb 22, 2010 #1
    A horizontal spring with stiffness 0.7 N/m has a relaxed length of 18 cm (0.18 m). A mass of 17 grams (0.017 kg) is attached and you stretch the spring to a total length of 21 cm (0.21 m). The mass is then released from rest. What is the speed of the mass at the moment when the spring returns to its relaxed length of 18 cm (0.18 m)?
    I've attempted this problem several times, to no avail.
    These are the equations I've been using.
    Maximum speed = 0.5(mv^2) = 0.5(k)(x^2)
    where k = spring constant and x is maximum stretch
    V at any point = sqrt((k/m)*(xmax^2 - x^2))
    k is spring constant, m is mass, x is equilibrium position and xmax is it's stretched distance
    The last result I got was 0.0371 m/s. let me know if it's correct.
    thanks in advance
  3. Feb 22, 2010 #2
    Hi, since the spring is being stretched from equilibrium you take the difference of the 2 values: x2-x1= (0.21-0.18)m = 0.03m and you should get 0.19m/s
  4. Feb 22, 2010 #3
    vela
    Staff Emeritus
    Education Advisor
    No, it's not correct. Show us what you actually did so we can see where the problem lies.
  5. Feb 22, 2010 #4
    I showed you, just plug in the value of x into the formula Kx^2=mv^2 and solve for v
  6. Feb 22, 2010 #5
    vela
    Staff Emeritus
    Education Advisor
    My earlier post wasn't in response to yours.
  7. Feb 22, 2010 #6
    oops, sorry:)
  8. Feb 22, 2010 #7
    i used the maximum speed equation as the speed would be greatest at x=0 (the relaxed spring length).
    max speed
    (mv^2) = k(x^2)
    0.017 kg * v^2 = 0.7 N/m * 0.03m^2
    from this I got the result of: 0.0371 m/s.
    I haven't entered it to see, can someone confirm this or show a mistake
  9. Feb 22, 2010 #8
    I think you are not squaring 0.03^2 = 0.0009
  10. Feb 22, 2010 #9
    vela
    Staff Emeritus
    Education Advisor
    That's [itex]v^2[/itex].
  11. Feb 22, 2010 #10
    No, the x needs to be squared on the other side of the equation
  12. Feb 22, 2010 #11
    vela
    Staff Emeritus
    Education Advisor
    Try what you think the OP did. You'll see you don't get the same answer. Then try solving for [itex]v^2[/itex] instead.
Similar Discussions: Oscillating spring force
  1. Spring oscillation (Replies: 5)
Loading...
