Oscillating Unvierse Theory and the 2nd law of Thermodynamics
No, that's not what entropy is. Entropy is a measure of the disorder of a system. It's not about energy being lost or gained; it's about how energy is distributed in a system. In particular, entropy tends to increase over time (the second law of thermodynamics) because the distribution of energy in the universe tends to become more and more disorderly.Energy conservation is a separate issue from entropy. Energy conservation says that energy can't be created or destroyed. Entropy says nothing about that. There can be processes where entropy increases while energy is conserved, or where energy is not conserved but entropy is still constant, or where both entropy and energy increase. They are two independent
Glenn
I have read two contraditory explanations of why the 2nd Law of Thermodynamics would prohibit an oscillating universe ad infinitum.
The first one, from a Paul Davies Books states that the second law of thermodynamics only would permit the oscillations to become larger each time. While this would lead to an infinite future, it also points to a finite past.
Another explanation used a bouncing ball as an analogy and stated that the bounces would get smaller each time.
Which is correct?
Thanks,
Glenn
Astronomy news on Phys.org
I know that in Tolman's original oscillating universe, the cycles get longer and longer. It doesn't necessarily follow that the universe then gets bigger each cycle, but I wouldn't be surprised. I haven't read the papers, though, so I don't know.
It's worth noting that Tolman's model was in the context of classical general relativity, and in quantum gravity, all bets are off; we can't extrapolate the effects of a collapse on a future expansion.
It's also worth noting that people have worked on oscillating models that try to avoid the entropy problems of Tolman's, e.g.:
http://arXiv.org/pdf/gr-qc/9510041
http://arXiv.org/abs/astro-ph/0204479
I have heard a few different takes on this myself. However, it seems to me that the law of entropy cannot be applied to the Oscilating Universe model at all. I have two reasons for this opinion;
1)Entropy is the tendency of energy to distribute itself more and more evenly throughout the universe. This means that where there is more energy (in the form of a particle of matter, for example) that energy will tend to radiate away (through particle decay) and spread out into places where there is less. That is, places within the universe. But the energy cannot leave the universe, because that would constitute anihilation, which would violate conservation. By all the observational evidence we have, energy cannot be created or destroyed. So the same energy that went into this Big Bang will also be present in the next.
2) By all the Oscilating Universe models I have seen, the basic laws of physics are randomised at the moment of the Big Crunch. If this is true, then even if entropy did mean the whole system loses energy, it would only mean that for this current oscilation. In the previous oscilation, the law of entropy may not have existed, or it may have been the opposite of what it is now, or any number of possibilities. One geuss is as good as another, once you cross the singularity-boundary between cosmoses (cosmi?).
That isn't the definition of entropy.
Conservation of energy doesn't say anything directly about what happens to the entropy.
The idea has been proposed, but I've never heard of any concrete oscillating universe model in which the laws of physics were actually different.
The kernel of truth in your argument is that we don't know what happens at a singularity, or whether there even is one
The 2nd law is a description of a phenomenon within this universe. I don't see how it can be applied to anything before or outside of this universe.
I think it does if we try to apply entropy to an entire cosmological model. If the system being studied is "the universe", then energy lost from that system is energy that ceases to exist within the universe. This amounts to the annihilation of the energy in question.
For energy to be lost from a particular system to the universe is one thing, but for energy to be lost from the universe, that energy ceases to exist. This violates conservation.
Your second paragraph is dead-on. That is why Guth's "first" model failed and why there are currently about 23 different Inflation models, none successful yet, in my humble opinion.
Labguy
LURCH, you said a lot about energy conservation, but what are you trying to say about entropy?
Originally posted by Labguy
Your second paragraph is dead-on. That is why Guth's "first" model failed [...]
Guth's original inflation model didn't fail because energy was not conserved, or was being "lost from the universe", or anything like that.
Ok, it failed for something(s) else.. I used to know a lot about entropy, but that was back when my mind was in a more ordered state. It seems to be getting more and more random as time goes by...
Guylab
That entropy involves the loss of energy from a system. If I understand you correctly, you're saying it doesn't? If entropy is not the redistribution of energy from places of higher concentration to places of lower concentration, then I've greatly missunderstood the whole concept. Can entropy take place without this movement of energy?
The total energy of a closed system will remain constant, but its entropy will tend to increase.
Entropy isn't something that "takes place". Do you mean, can entropy increase without movement of energy? Well, without local transport of energy from one part of a system to another, generally nothing happens: you have a static system. But I don't know what connection you want to make with entropy. I'm also not sure what you mean by "redistribution of energy from places of higher concentration to places of lower concentration". Do you mean that when a system equilibriates, it should end up with the same energy at all points of the system? If so, that's not the case.
well i would only say that,if everrything in this universe is happening on the basis of alll physical laws,then it would be an almost perpetual motion body revealing all its death and birth time dependently...does any meaning to the NEGENTROPY? if it is then it would be a mirror effect of either birth or of death..wanaa have something to say on this?
Which is correct?
Thanks,
Glenn
Entropy is a thermodynamic measurement of an isolated system. It is a measurement of the randomness, uncertainty, or disorder in that system. Energy is not lost as the system does what it does...the energy is converted to a less useful state. But overall energy is still conserved.
Exotic Transformation (Entropy)
Entropy (as it applies to physics); is the measure of the unavailability of a system’s (open OR closed) thermal energy for conversion into mechanical work. It can also be the measure of degradation or chaos of the Universe.
Entropy (as it applies to maths); is the measure of the rate of transfer of information in a message.
The classical laws of thermodynamics do not apply or work with all observable phenomena. They don’t. Eg. Hawking Radiation and Quantum Microstates (currently being discussed on another thread on this forum). It IS possible for energy to disappear from this Universe or to “cease to exist”. No replacement force is needed for the resultant loss of energy.
The classical laws of thermo dynamics DO apply to all physical situations. I don't know where you got the idea that they don't apply to Hawking radiation, but that's absurd as Hawking radiation is the mechanism that allows black holes to comply with the laws of thermodynamics. Again it is absurd to say that quantum microstates don't obey the laws of thermodynamics as they allow you to look at statistical mechanics from a quantum point of view.
The conservation of energy, in it's corrected form (to allow for the HUP, mass-energy equivalance, etc.) is absolute and cannot be violated.
Although it isn't a "loss of energy", perhaps Nommos Prime (Dogon) is actually referring to the black hole information loss paradox, which is a problem for the quantum thermodynamics of black holes.
...even if he isn't, can you explain what this is as it sounds very interesting.
The information loss paradox is this: if the black hole starts out in a pure quantum state, after emitting thermal radiation it ends up in a mixed state (a statistical ensemble of pure states). But unitary time evolution of quantum mechanics forbids a pure state to evlove into a mixed state. See:
http://math.ucr.edu/home/baez/physics/Relativity/BlackHoles/info_loss.html
What is the state of play with the information paradox, does the appeal to string theory for answers about the microstates of a black hole resolve this paradox?
As far as I know, a knowledge of the microstates in string theory still hasn't yet helped with the information loss paradox. I think string theorists like to appeal to the more general principle of holography, without the microscopic details being fully understood, e.g.:
http://arXiv.org/abs/hep-th/0002044
1. What is the Oscillating Universe Theory?
The Oscillating Universe Theory proposes that the universe goes through cycles of expansion and contraction, with a Big Bang followed by a Big Crunch and then repeating the process. This theory suggests that the universe is eternal and has no beginning or end.
2. How does the Oscillating Universe Theory relate to the 2nd law of Thermodynamics?
The 2nd law of Thermodynamics states that entropy, or disorder, in a closed system will always increase over time. The Oscillating Universe Theory conflicts with this law because each cycle would reset the universe to a low entropy state. However, some scientists argue that the overall entropy of the universe could still be increasing even with the cycles of expansion and contraction.
3. Is there evidence to support the Oscillating Universe Theory?
Currently, there is no conclusive evidence to support the Oscillating Universe Theory. However, some scientists point to the cosmic microwave background radiation as a potential piece of evidence. This radiation is believed to be leftover from the Big Bang and could potentially have been caused by a previous cycle of the universe.
4. What are the implications of the Oscillating Universe Theory?
If the Oscillating Universe Theory is true, it could mean that the universe is truly infinite and has no beginning or end. It could also have implications for the existence of multiple universes and the concept of time. However, until there is sufficient evidence to support this theory, these implications remain speculative.
5. How does the Oscillating Universe Theory differ from the Big Bang Theory?
The Big Bang Theory proposes that the universe began with a single event of rapid expansion. The Oscillating Universe Theory, on the other hand, suggests that this process has happened multiple times and will continue to happen in the future. Additionally, the Big Bang Theory is supported by more evidence and is currently the dominant theory in the scientific community.
15K
  • Quantum Interpretations and Foundations
  • Quantum Physics
