Oscillation of electrons
  1. Jun 23, 2015 #1
    hello
    I suppose electrons oscillate, so
    do electrons have resonance frequency?
    ie. a frequency where the amplitude is maximum?
    and where can I find it?
    thanks
  3. Jun 23, 2015 #2
    Well, If electron oscillate at frequency f, and you have extra force to electron with frequency f, then they are in resonance, resemble to we play swing in playground.
  4. Jun 23, 2015 #3
    if an electron has eigenfrequency f and we apply to it external force with frequency f, the amplitute of the electron will become maximum? right?
    but how do I find the eigenfrequency of electrons for various materials
  5. Jun 23, 2015 #4
    Yes it is right. in 2nd question, it is far beyond the original question of you. eigenfrequency means absorption spectrum of the material. In principle, It can be calculated with band gap theory of solid state physic however, It has been many decades to experimentally investigate that in spectroscopy.
  6. Jun 23, 2015 #5
    is there a way to provide waves, electricity or anything and make the electrons oscilate further or more frequent?
    apart from heat
  7. Jun 23, 2015 #6
    Well...let's say electrons are actually electrons in plasma. You can induce magnetic field to the plasma and plasma has so called cyclotron frequency. When external RF is applied to the plasma with this frequency. electrons oscillates a lot and collides to ions to heat up the plasma itself. You know what, you need to specify further which system you're thinking about to make electron oscillate. As long as there is AC electric field to electrons, it should be oscillates with the same frequency.
  8. Jun 23, 2015 #7
    no, I don't want these in plasma, I want them in solid metal
  9. Jun 23, 2015 #8
    If you are trying to think of a way to "gain" more energy than 2 electrons by having 2 electrons "constructively interfere" it will never happen, for constructive and destructive cancel out and you always have left what you started with.
  10. Jun 23, 2015 #9
    I don't quite understand what you are saying
    what is constructive and desctuctive? what interfere?
    I think I made clear what I want to do: to make electrons oscillate with maximum amplitude by finding their resonance frequency and stimulating them with that frequency to make them oscillate with maximum amplitute
    in metals
  11. Jun 23, 2015 #10
    Okay. In metal. Electron you mean can be free electrons in conduction band, not bound electrons in valence band. I don't know bound electrons can oscillates. In electrons in conduction band, free electron model can be applied and this is nothing but plasma. Every electrical field of frequency should oscillates the electron at the same frequency since electrons are very light. But there is frequency of collective behavior in plasma so called critical frequency. When you see the dispersion relationship of the plasma with collision term. Energy absorption is maximized when external field to the plasma (Here it is free electrons in metal) has that frequency however, absorbed energy is converted to plasma heat up thus I don't see the method to oscillate free electrons at some maximum resonance amplitude as you have question.
    In addition, you should have originally specified your question in a more detailed. You even didn't mention 'metal'. Every physics is material-dependent.
  12. Jun 24, 2015 #11
    what exactly is that collective behaviour at the critical frequency? what does it happen at that frequency?
    can I find a graph of the amplitute of electron oscillation and frequency of electrical field?
  13. Jun 24, 2015 #12
    The collective means electrons are moving as a fluid. they're communicated with each other due to long range feature of column force. You better study critical frequency in internal search. plasma frequency is the frequency what I mean and you can easily find relevant info for it.
    Anyway why did you ask this? What kind of study are you doing now?
  14. Jun 30, 2015 #13
    I want to increase the amplitude of electrons movements, is this possible?
    or maybe increase the kinetic energy of electrons?
  15. Jun 30, 2015 #14
    Dale
    Staff: Mentor
    You are talking about antenna design. For a basic dipole antenna, it resonates at the frequency whose wavelength is twice the length of the dipole.
  16. Jun 30, 2015 #15
    how is the antenna stimulated to resonate?
  17. Jun 30, 2015 #16
    Dale
    Staff: Mentor
    Usually with a voltage source placed in the middle between the two halves of the dipole antenna.
  18. Jul 1, 2015 #17
    ok and apart from applying a voltage in a metal to change the amplitude of electron oscillation, what other methods are there?
  19. Jul 1, 2015 #18
    Dale
    Staff: Mentor
    Just make sure that the frequency of the applied voltage matches the resonant frequency of the antenna. That will make the amplitude of the oscillation the greatest.
  20. Jul 2, 2015 #19
    what is the resonance frequency of various materials?
  21. Jul 2, 2015 #20
    Dale
    Staff: Mentor
    See post 14.
Similar Discussions: Oscillation of electrons
  1. The electron (Replies: 12)
Loading...
