Why is my sawtooth oscillator not oscillating?
  • Thread starter petterg
  • Tags
    Oscillator
In summary: Trying to take a lot of power direct from an oscillator isn't a particularly good design idea, even if it does work. If your "large" load is not a pure resistance, you might be messing up the phase shifts in the oscillator circuit, which might stop it oscillating.
petterg
162
Hi
Does anyone have an idea of why my oscillator doesn't oscillate? It's supposed to generate sawtooth. But the scope shows constant -13V. Actually the output of the oscillator has a more stable voltage than the input voltage source!
It works IRL with ua741 opamp (but the 741 doesn't provide enough current for my application)
It works in simulation with lm1875t opamp.
While I was trying to debug and placing probes around the circuit all of a sudden it started to work... and after 30seconds or so it stopped just as sudden as it had started.
Then I took the components off the board and made a square wave generator circuit that worked. I checked both opamps and the capacitor with the square wave generator, so the components seems not to be defective.
Then I put them all back to the sawtooth generator circuit, and again it's output is constant -13V.
So I took a new breadboard, all new components, this time I added some potentiometers in order to tweak it a bit. Hopefully that would get it started, but it didn't. The output is barely changing when I turn the potentiometers.
I've tried 3 different capacitors; 2nF, 20nF, 200nF. It doesn't affect the output at all (except for the startup time when voltage drops from 0 to -13).
Something elementary must be wrong. Could it be that the lm1875t is to fast at voltage changes so it adjusts for feedback too fast and becomes stable? (I have never before used any opamp as powerfull and fast as the lm1875t.)
Any ideas where I'm failing?
Attached is a sketch of the latest test circuit with potentiometers.
Where did you get the circuit from? It would be good to see a source circuit -- I can kind of see how this one is supposed to work, but a couple things about setting the hysteresis are not clear to me.
So the main difference I see right off the bat is that the 2nd opamp's + input should be grounded (at least in the simplest implementation). Try turning your 160k pot so that it grounds the + input of the 2nd opamp...
There are loads of implementations of this circuit out there.
The 160k pot is the one that (in simulation) makes the difference in rise and fall time. When turned to ground the rise and fall times will be equal. Turning it away from ground changes the output towards sawtooth - in simulation.
IRL turning the pots doesn't make any difference at all. That includes turning the 160k all the way to ground - still got the ultimate noiseless DC output.
Can you label all the nodes in the schematic with the DC voltages from your simulation?
(Sketch in #1 was made in NI Multisim 30day demo, because it's the only simulator I found that has lm1875t in it's library.)
I've now created a similar circuit in Lt Spice. Using LT1366 as opamp it worked. Using LT1210 the simulation behaves just like my RL lm1875t circuit. LT1210 is faster and more powerful than lm1875t. LT1366 is slower and less powerful. This strengthen my idea that the issue I'm facing IRL is that the opamp is to fast/powerful for the circuit. It sounds strange though.
If that actually is the case, how can I modify the circuit to work with fast and powerful opamps?
In simulation (in Ni Multisim) there is AC everywhere. Do you want me to lable simulation AC averange, or RL DC measurements?
Are you saying that the output is DC, but there are AC waveforms everywhere else? Maybe I'm misunderstanding the orignial problem...
You could leave the oscillator working with your low power op amps, and use its output to drive your high power amp (e.g. as a unity gain amplifier).
From your descriptions it seems like your "non-oscillator" has got one of the op amp outputs locked up to a supply rail voltage, which will certainly stop it oscillating - but I've no idea why that is happening.
Likes 1 person
Good point about lowpower oscillator + amplifier! That is probably the way to go.
Currently it looks like I've fried 4pc lm1875t. Voltage from powersource drops to +/-1,5V once connected to any of the 4 op amps I've used for testing. No load is connected, both inputs are grounded. Just Vcc and Vee is connected.
The LM1875 is specifically an audio power amplifier not an Op-Amp as such, its output is designed to drive a speaker, not the input to another LM1875
why did you choose this device ?
you should be using a more specific Op-Amp
Dave
I looked through the opamps listed on ebay and chose the first I came to that had enough output current and speed. I had no idea that some opamps can't drive another of the same kind.
I don't think you understood what I said ... these are not really op-amps as such
They are audio amplifier chips designed to drive speakers
You should really be using something like TL072 or similar for the actual oscillator ... once you have an osc working ... then you could use the LM1875 or some other audio amplifier chip to boost the output
cheers
Dave
I've now learned that oscillator based on lm1875 is not good.
Is ua741 suitable for driving the oscillator before lm1875 amplifies it?
(Those are the two kinds I have. If they're no good I'll need to order others, i.e TL072)
741 should drive an audio amp quite nicely.
I much prefer LM324. They're cheap and easy to use and okay for single or dual supply.
And the most widely used opamp ever so they're widely available, even Radio Shack .
Input and output specs are better than 741.
http://www.ti.com/lit/ds/symlink/lm324-n.pdf
I suspect that your trouble lies with LM1725's input.
The datasheet is a bit sketchy as to input impedance
http://www.ti.com/general/docs/lit/getliterature.tsp?genericPartNumber=lm1875&fileType=pdf
look at parameter "Input Bias Current"
so long as the amplifier can balance its inputs it draws only a microamp or so of input current
but the datasheet doesn't say what happens when input voltage differential becomes substantial as it does for U1. They don't expect us to use it that way. It's not a general purpose opamp.
Observe that in order to oscillate , your circuit must push or pull enough current through R1 to change state of U1.
and we don't know how much current that is.
Furthermore your unequal supply rails(more + than -) are in the direction to make U1's output stay positive , and your symptom(-13V out) agrees with that. There's less negative to pull current through R1 than there is positive to push it through R2 .
That's probably not an issue if R3 is set fairly high.
Lastly C1 can pass a LOT of current into U2's inverting input.
That can cause latchup in some amplifiers, see
http://www.ti.com/general/docs/lit/getliterature.tsp?baseLiteratureNumber=slya014&fileType=pdf
and that can be destructive.
I'd stick a kohm or two between U2 pin2 and junction C1-R5
It'd be very educational to get this working with 1725's.
old jim
Likes 1 person
Good point - the 1725 is meant to be a used as a linear amplifier not as a general purpose op amp.
If you really want to use the 1725 for a "one chIp" circuit you might try a Wien bridge oscillator, which will use it as a linear amplifier (and it only needs one 1725, not two).
One other comment from the data sheet - it says the 1725s must always be mounted on a heatsink, because the quiescent current can be high (100 ma). Even if they have thermal shutdown protection, they won't work till they cool down again!
Thanks for the detailed description, Jim.
I needed 6 lm1875's for the project (5 when using ua741 for the oscillator). I bought 10. Having killed 4 of them, I'm not into retrying what killed them. So I played around with LT1210 in LT Spice. The circuit with LT1210 gave a constant output of 4.8V (positive) in simulation. Adding a R7>300 on U2 pin2 and setting R6 (the 160k pot) at most 30% away from ground made the oscillation start. (The other pots were left on 50%.)
I guess something similar would get the real lm1875 circuit going. But from what I've learned I'll let the ua741's do the oscillation and use lm1875 just for amplification.
With this solution I'll run out of ua741's. Do you recommend that I order lm324 or TL074 or both?
The powersupply I'm using is supposed to be 2x 15V, according to HP. The voltage in the sketch is what I actually measure from it. My original plan was to use a +/-12V from a pc powersupply, but it turns out that -12V drops to -7V already when 32mA is pulled from the terminal. I might need to make a supply circuit too.
Yes PC's haven't much oomph on their -12 line.
You can probably find a supply at thrift store. I just picked up a HP printer wall-wart transformer that has secondary 20VAC centertapped at almost an amp.
I've never used TLO74 but its datasheet looks very good. Both opamps are specified with 2kohm load
the 074's fet input stage should give you a better sawtooth at very low frequencies
and I think they're pin compatible (at least in 14 pin dip package) so you could compare them easily. Its ~3 to 6 millivolts offset voltage won't matter much in your circuit, probably 741 is at least that bad.
lm324's are so cheap i'd say get a handful for experimenting. Someplace I have a tube of fifty which should last me the rest of my life.
lm324: http://www.jameco.com/webapp/wcs/stores/servlet/Product_10001_10001_23683_-1
22 cents apiece in quantity; but TL074 is only 39 cents
I'd like to experiment with some 1725 power amps. I have been using LM12's (more current) for a three phase 60 hz power driver but they've got terribly expensive. It's worth making a new board.
The LM12 is what you thought the 1725 to be - a general purpose opamp with 8 amp output capability, good for about 80 watts of audio. OPA541 is a possible replacement but even it's $25.
keep us posted - this is a most interesting project.
old jjim
you really mean LM1875 ... not sure how the 1725 crept into this discussion
I think Jim got sidetracked even tho he linked to the 1875 pdf :wink:
As I have already covered the fact that the 1875 is not applicable to this process, let's get petterg
going on the right path :smile:
petterg ...
The TL072 has 2 opamps in the same package ... now using the info from the datasheet, wire up the the 2 opamps in the package according to the circuit berkeman gave you right at the beginning of this thread ... NOTE the pin numbering will be different
Page 4 of the datasheet has the pinouts for the TL072 ... top row , centre diagram
Dave
oops 1875 1725 I tend to mangle names and numbers, sorry for the confusion it sure wasn't intentional
now i'll just watch from sidelines ; thanks guys for letting me play in your sandbox.
Does this sketch look OK?
L1 and R2 represents the load.
The hardest part here was to make the amplitude into 1875 small enough for it not to clip, while trying to keep the rise and fall times as far apart as possible. This circuit gets a rise/fall time factor of 4.3 at 5kHz. I was hoping to reach 5.
I might be able to increase the rise/fall factor by getting a power supply that is symmetric (or adjustable)
10pcs of lm324 is ordered. ($1.70 on ebay including shipping. Local store would set me back $50 with unknown delivery time.) As shipping takes some time I'm thinking to go with ua741 in the oscillator, and use the 324s where the 741s originally was planned to be used.
jim hardy said:
....now i'll just watch from sidelines ; thanks guys for letting me play in your sandbox.
Jim ... get off those sidelines :smile: you know more abt this stuff than I ever will !
not sure why you have 2 different voltages for your split rail supply ?
you should have them the same
also you oscillator part is a long way away from what Berkeman showed you in his earlier post
As I suggested before, replicate his circuit ( its out of a datasheet) so that you get your triangular wave
disconnect the input to the LM1875 for the time being and concentrate on getting your oscillator working
THEN you can worry about adding the amplifier
D
It's basically the same as Berkemans. I didn't bother to draw pots for fine adjustments, and it's tweaked to give sawtooth, not symmetric triangular, and it gives way smaller amplitude. The one Berkeman found will make the 1875 clip, hence make square wave.
My supply is double 15V on the sticker. Measured voltage is what the sketch show. Better to simulate with the real voltage than the theoretic.
And R6 is added because of the genius Jim. I adopted his solution for powerfull opamp circuit to the not so powerfull opamp circuit.
What is the advangtages / disadvangtages of using a small vs large C1?
I'm thinking small C1 makes it possible with large R1, which will make less power consume and less load on the opamps (= more stability)
This is the first time ever I've had a circuit that performs better IRL than in simulation! It's been running for an hour now (oscillator stage only) with a rise/fall factor of 10, and no distortion at all, and opamp temperature is barely above room temperature. (In simulation distortion get significant when the factor is above 4.5.)
i'm thinking you're exactly right.
observe all current into U1's summing junction through R1 exits through C1 to U1's output pin. And it had to be provided by [STRIKE]U1[/STRIKE] U2. EDIT - oops I said U1 at first, typo, should have called 'em left and right...
So minimizing that current eases life for those opamps.
With small C1 you probably don't need R6, I had suggested it to protect your audio amplifier from possible latchup. 741 is supposed to be inherently latchup-proof .
What do you mean by " rise/fall factor " ? Up vs down slopes of sawtooth ? Is that what your 160K R5 adjusts?
If your low power opamps are pin compatible it'd be educational to see whether the TL074(72?) or LM324 makes a difference.
Looks like this would operate in the 10khz region which is about as far as you want to push a 741.
A faster opamp might help rise and fall times.
and I note your TL074 is ~ a decade faster than both 741 AND LM324...
My apology for not noting that earlier - I think i'll acquire a tube of them myself.
Congratulations on your R4::R3 ratio, it assures oscillation.
It should also control amplitude of triangle wave am I right? (That's from intuitive look not rigorous circuit analysis so please correct me if I'm dead wrong)
If I learn something every day, I might someday know something !
old jim
Something is not right with the amplifier circuit. (I have not connected the load yet.) Signal from U1 pin6 dies when the amplifier is connected. Even with C2 removed, still no signal from U1. When R7 also is removed, the signal comes back. Or if I leave R7 in and pull out R8 og C3 there is also signal from U1.
The circuit around the lm1875 is from the datasheet example for typical application.
If I replace C2 and C3 with 20k resistors, the signal from U1 turn into pulse with negative amplitude out of range for my scope. And the frequency is 10x what comes from the unloaded oscillator. Whats going on here?
Correct. Time of the up slope devided by time of the down slope (or the other way around).
Actually R5 adjust the fall slope length, and R4/R3 ratio adjust the rise slope length. By length I mean the diagonal distance from top to bottom (or the other way around). So they affect both amplitude and frequency.
R1 affects mostly frequency.
If R5 is set close to ground, then R4/R3 has less affection on frequency.
My target is between 4kHz and 6kHz. Should be within range for 741 and 324. Although the sawtooth requires faster change in output in a fraction of the cycle than what a symmetric triangle requires at 10kHz.
  • #31
Looks like the lm1875 is doing something that is messing up the supply voltage. With nothing connected to pin1 and only R9 (the feedback) + R8 (to ground) connected it's able to kill signal from the oscillator. At this point the only thing the two stages has in common is power and ground. Setting a 47k resistance between pin 1 and pin 2 on the 1875 makes the oscillator start oscillating again. So the amplifier circuit has to be modified so that voltage on pin 1 and 2 don't drift apart - as they apparently do with the current circuit.
  • #32
this could be part of it
The LM1875 is designed to be stable when operated at a closed-loop gain of 10 or greater, but, as with any
other high-current amplifier, the LM1875 can be made to oscillate under certain conditions. These usually involve
printed circuit board layout or output/input coupling.
that's from its datasheet
and you've set gain to 2
datasheet "applications" circuits are both set to 20.
And have a larger C3.
How about:
Use a leftover pot for volume control at output of U1, or replace R7 with a volume control wiper to pin 1. Then set amp gain to 20 like the datasheet showed.
Might not work
but one needs to start with ALL the rules followed and then see which ones it'll tolerate breaking.
One gets accustomed to carefully reading datasheets. And still makes mistakes - I sure missed TL074's bandwidth.
Hang in there. This thing will work.
I assume you have adequate power supply with big filter capacitors - measure power supply voltage , both its DC value and its AC content under load.
  • #33
oops I was going to just watch ... please excuse the old fire-horse syndrome...
go fellows, go !
j
  • #34
You can't just watch, Jim. Idiocy would concur the world.
With gain at 20 (R9=20k, R8=1012) and C2 removed - this should give an amplifier with no input and no output load - I get the same behavior as with gain at 2, except that supply voltage dropped to 22,1V and the supply made some unfriendly sounds. Shorting out C3 did not make any difference.
It doesn't make sense that the powersupply can't drive one unloaded lm1875 when it surely had enough power to drive two of them yesterday - and kill them. Hence my logic say here is something very bad with the circuit.
  • #35
Let's focus on that a minute
datasheet page 3 says an unloaded 1875 can draw 100 milliamps
1. what is rating of your supply?
2. what do you read for DC output voltage, supply unloaded and loaded?
Measure + and - individually, not just across them
3. switch your meter to AC (or use your 'scope) and measure AC ripple voltage at same conditions .
That checks power supply for filtering and regulation.
1: Supply rated output:
voltage ________ and current _____________
2 & 3 : Measured output
positive output negative output
_____________ ____________ volts DC No Load
_____________ ____________ volts DC loaded with an 1875
_____________ ____________ volts AC No Load
_____________ ____________ volts AC loaded with an 1875
when things gets confusing go back to the starting point.
Old troubleshooting rule - always check power supply first thing
Power supply troubles look like they're everywhere (because power supply goes everywhere).
Davenn - chime in here...
<h2>1. Why is my sawtooth oscillator not oscillating?</h2><p>There could be several reasons why your sawtooth oscillator is not oscillating. One common reason is that the circuit is not receiving enough power. Make sure that the power supply is connected correctly and providing the correct voltage. Another reason could be that there is a loose connection or a faulty component in the circuit. Check all connections and replace any faulty components.</p><h2>2. How can I troubleshoot my sawtooth oscillator?</h2><p>To troubleshoot your sawtooth oscillator, start by checking the power supply and all connections in the circuit. If everything seems to be in order, you can use a multimeter to test the voltage and current at different points in the circuit. This can help you identify any faulty components. You can also try adjusting the potentiometer or changing the value of the capacitor to see if that affects the oscillation.</p><h2>3. What is the ideal frequency for a sawtooth oscillator?</h2><p>The ideal frequency for a sawtooth oscillator depends on the specific application. In general, the frequency should be high enough to produce a smooth sawtooth wave, but not so high that it causes instability or distortion. A common range for sawtooth oscillators is between 1Hz and 100kHz.</p><h2>4. Can I use a sawtooth oscillator in audio applications?</h2><p>Yes, sawtooth oscillators can be used in audio applications. They are often used in synthesizers to create a distinctive sound. However, the frequency range of the oscillator may need to be adjusted for different audio applications.</p><h2>5. How can I improve the stability of my sawtooth oscillator?</h2><p>To improve the stability of your sawtooth oscillator, you can use a voltage regulator to ensure a constant power supply. You can also add a feedback loop to the circuit to help regulate the output. Additionally, using high-quality components and minimizing external interference can also help improve stability.</p>
  • Electrical Engineering
