Warping Spacetime: Classical Physics & Relativity
In summary, according to classical physics, all objects have their own gravitational pull that causes them to attract each other. This means that, in theory, even the Earth is drawn closer to a tennis ball, although this effect is too small to be detected. However, Einstein's theory of relativity suggests that every physical body, no matter how small, can warp spacetime and potentially be detected through the bending of light. While this is possible in theory, the effect is too minute to be observed with ordinary objects or even a human body. It would require precise calculations to determine the exact magnitude of this effect.
Aikiman007
Based on classical physics all things attract one another due to their own gravity pull, so theoretically the Earth is drawn closer to a tennis ball even if its impossible to detect. Knowing this and Einsteins theory of relativity of spacetime could I not assume then that every physical body actually warps spacetime no matter how minute and could actually be detected with bending light? Or is spacetime something associated to massive heavenly bodies instead and not small ones like my human form?
You could, and you would be right if you were to add the qualification "could in principle be detected". In practice, the effect is far too small to detect when working with ordinary objects or something like a human body. It would be a good exercise to calculate just how small the Newtonian gravitational attraction between two people standing on opposite sides of a room is - the light-bending predicted by general relativity will be of similar magnitude.
The force is easily detectable with a small scale.
As a matter of fact, a common school exercise has the student calculate the gravitational effect between people-sized objects at room-sized distances.
1. How does warping spacetime affect the motion of objects?
Warping spacetime, as described by Einstein's theory of general relativity, causes objects to follow curved paths through space. This is due to the presence of massive objects, such as planets or stars, that create a gravitational pull and warp the fabric of spacetime.
2. Can warping spacetime explain the concept of gravity?
Yes, warping spacetime is the basis for Einstein's theory of gravity. According to this theory, gravity is not a force between masses, but rather the curvature of spacetime caused by the presence of mass. The more massive an object is, the more it warps the fabric of spacetime and the stronger its gravitational pull.
3. Is warping of spacetime the same as time travel?
No, warping spacetime does not necessarily mean time travel. While it is possible for time to be affected by the curvature of spacetime, time travel as depicted in science fiction is not currently possible according to our current understanding of physics.
4. Can warping of spacetime be observed or measured?
Yes, the warping of spacetime has been observed and measured through various experiments and observations. One example is the observation of the bending of light from distant stars as it passes through the gravitational field of massive objects, such as the sun.
5. How is warping of spacetime related to the concept of relativity?
Warping of spacetime is a key concept in Einstein's theory of general relativity, which explains how gravity works in the universe. This theory also includes the concept of special relativity, which describes the relationship between space and time for objects moving at constant speeds.
