Outer Space Propulsion: Degrees for Nuclear Engineering
In summary, the conversation discusses the necessary education for a career in the study of new propulsion systems for outer-space travel, specifically focusing on nuclear propulsion. The speakers suggest that an aero/astro degree would be the most suitable, but a wider knowledge of physical phenomena through a physics degree may also be useful for inventing revolutionary propulsion systems. Other important skills include computational experience, fundamental physics knowledge, and energy/machine engineering. However, one speaker cautions against betting on unproven technologies and suggests considering potential employers when choosing a degree.
Winzer
598
My B.S. will be in Engineering Physics. Suppose I want to go into the study of new/developed propulsion systems used for outer-space travel. Take for instance nuclear propulsion. Would a master's in nuclear engineering would be sufficient to get started? What other degrees besides physics, mechanical, and electrical would fit this field?
Thanks in advance.
I think it's a mistake to plan one's education assuming the success of a particular unproven technology. An aero/astro degree looks to me to be the right direction.
I 2nd this, seems like the most straightforward way to me. But if you have ambitions to invent a truly revolutionary propulsion system, maybe the wider knowledge about physical phenomena that comes with a physics degree might be useful ?
By the way, you might be interested in MIT's space propulsion course (freely available lecture notes and assignements):
http://ocw.mit.edu/OcwWeb/Aeronautics-and-Astronautics/16-522Spring2004/CourseHome/index.htm
Winzer: I think you actually are in the right track. If you want to do something totally new, you shouldn't do a aero/whatever oldtech degree. Then you should do a nuclear engineering or stuff like that, it will give you something to build on. But most of the research you will be doing yourself.
But if you don't find it tempting to work in the nuclear industry, then maybe do a degree more into your tastes.
Some of the things you need are probably a lot of computational experience (to simulate things), a lot of fundamental physics (to understand what is happening) and a lot of energy/machine-engineering to know where to start. All of this you could get on your own, or as a part of a Phd.
Winzer, I think Fearless is giving you bad advice. (And would encourage you to read his other posts in this section and the community's reaction to his advice).
Betting one's education on a particular unproven technology being successful is foolish, because by definition, you don't have enough information to make an informed choice - that's what you want the education for. "Unproven" is perhaps a little too polite - "couldn't make it work so the program was canceled - twice" is maybe closer to the truth.
One also needs to look at the issues involved - is the problem that we don't know how to make nuclear reactors on the ground, or is the problem that we don't know how to make them fly? Given that, does it make more sense to study how to build better reactors on the group, or does it make sense to study how to make things fly?
I think you also have to look at potential employers - is NASA or JPL more likely to hire someone with an aero/astro degree or with a nuke E degree? One can make a lot more progress in a field with the right job and the wrong degree than the wrong job and the right degree.
What is outer space propulsion?
Outer space propulsion is the use of technology to move spacecraft in outer space. This technology is essential for space exploration and travel.
What is nuclear engineering and how does it relate to outer space propulsion?
Nuclear engineering is a field of study that involves the use of nuclear reactions for various applications. It is closely related to outer space propulsion because nuclear reactors are often used to power spacecraft and provide the necessary thrust for propulsion.
What degrees are required for a career in nuclear engineering for outer space propulsion?
Typically, a Bachelor's degree in nuclear engineering is the minimum requirement for a career in this field. However, some positions may require a Master's or Ph.D. in the same field.
What are some potential job opportunities for individuals with a degree in nuclear engineering for outer space propulsion?
Some potential job opportunities in this field include working as a propulsion systems engineer, nuclear engineer, or a spacecraft systems engineer for organizations such as NASA, aerospace companies, or government agencies.
What are some current advancements in outer space propulsion technology?
Currently, there is ongoing research and development in various forms of outer space propulsion technology, including nuclear thermal propulsion, electric propulsion, and solar sails. These advancements aim to improve the efficiency and speed of spacecraft for future space missions.
  • STEM Academic Advising
