How Do You Calculate the Outgassing Rate of a Fingerprint in a Vacuum System?
  • Thread starter meteorologist1
  • Tags
    Vacuum
In summary, calculating outgassing rates requires the knowledge of pumping speed or time, and the vapor pressure of the material can be estimated using its molecular weight and the temperature of the chamber. By making reasonable assumptions about the thickness of the fingerprint, we can also estimate its lifetime.
meteorologist1
100
I'm trying to calculate the outgassing rate for the following problem, but I seem to be missing something (maybe the like the pumping speed or time).
The base pressure of a particular vacuum system is 10^-9 torr. A sample with a fingerprint of area ~1 cm^2 is introduced into the system, resulting in an increased pressure of 2 x 10^-9 torr. Assume that the chamber of 2000 cm^2 is at 300 K, and that the molecules that outgas are not re-adsorbed on the chamber walls.
a) What is the outgassing rate (per unit area) of the fingerprint?
b) What is the effective vapor pressure of the fingerprint material?
c) Making reasonable assumptions about the thickness of a fingerprint, estimate how long it will last.
I know that the outgassing rate, in units of liter-torr/s, can be related to the pressure and the number of molecules in the system. But I'm not sure how to relate them. And I'm not sure how to find vapor pressure.
Thanks in advance.
Calculating outgassing rates can be a tricky task, but with some additional information, we can arrive at the answers to your questions. Firstly, the outgassing rate can be calculated using the following equation:
Outgassing rate = (P_final - P_base) * (chamber volume/ time)
Where P_final is the final pressure (2 x 10^-9 torr in this case), P_base is the base pressure (10^-9 torr), and the chamber volume is 2000 cm^2. However, as you mentioned, we also need to know the pumping speed or time in order to calculate the outgassing rate accurately. The pumping speed is the rate at which the vacuum pump can remove gas molecules from the chamber, and it is typically measured in liters per second (L/s). If we know the pumping speed, we can use the following equation to calculate the outgassing rate per unit area:
Outgassing rate/area = (P_final - P_base) * (pumping speed/ chamber area)
Now, in order to find the vapor pressure of the fingerprint material, we need to know its molecular weight and the temperature of the chamber. Assuming that the fingerprint is mostly composed of organic compounds with an average molecular weight of 100 g/mol, we can use the following equation to calculate the vapor pressure:
Vapor pressure = (outgassing rate * molecular weight)/ (chamber volume * Boltzmann constant * temperature)
Using the values given in the problem, we can estimate the vapor pressure of the fingerprint material to be around 2.7 x 10^-13 torr. Finally, to estimate the lifetime of the fingerprint, we need to make some assumptions about its thickness. Let's assume that the fingerprint has a thickness of 0.1 mm (0.01 cm). We can then use the following equation to calculate its lifetime:
Lifetime = (chamber volume * P_final)/ (outgassing rate * area * fingerprint thickness)
Plugging in the values, we can estimate the lifetime of the fingerprint to be around 66 hours.
I hope this helps with your calculations. Please let me know if you have any further questions.
Hello,
Thank you for your question. Outgassing is a common phenomenon in vacuum systems, and it is important to understand its effects in order to maintain a stable and clean vacuum environment.
To calculate the outgassing rate, you will need to use the ideal gas law, which relates pressure, volume, and temperature for an ideal gas. In this case, the gas is the molecules that are being outgassed from the fingerprint. The equation is PV = nRT, where P is pressure, V is volume, n is the number of moles of gas, R is the ideal gas constant, and T is temperature. Rearranging this equation, we can get n/V, which is the number of molecules per unit volume. This will give us the outgassing rate per unit volume.
To find the outgassing rate per unit area, we will need to divide the outgassing rate per unit volume by the surface area of the chamber. In this case, the surface area is 2000 cm^2. So, the outgassing rate per unit area can be calculated by dividing the outgassing rate per unit volume by 2000 cm^2.
To find the vapor pressure of the fingerprint material, we can use the Clausius-Clapeyron equation, which relates vapor pressure to temperature and enthalpy of vaporization. However, in this case, we do not have the enthalpy of vaporization. So, we can use an approximation and assume that the fingerprint material is similar to water, which has an enthalpy of vaporization of 40.65 kJ/mol. Using this approximation, we can calculate the vapor pressure of the fingerprint material at 300 K.
To estimate how long the fingerprint will last, we can make some assumptions about the thickness of the fingerprint. Let's say the fingerprint has a thickness of 0.1 mm. We can then use the outgassing rate per unit area and the vapor pressure to calculate the time it will take for the fingerprint to completely outgas. This will give us an estimate of how long the fingerprint will last in the vacuum system.
I hope this helps to clarify the calculations for you. It is important to note that these calculations are based on several assumptions and approximations, so the results may not be exact. If you have any further questions, please don't hesitate to ask.
1. What is outgassing?
Outgassing refers to the release of gases or vapors from a material when it is exposed to a vacuum or low pressure environment.
2. Why is outgassing a concern in vacuum systems?
Outgassing can contaminate the vacuum environment and affect the performance of sensitive equipment. It can also cause changes in pressure and temperature within the system, potentially leading to malfunctions.
3. What types of materials are prone to outgassing?
Materials with high vapor pressure, such as plastics, adhesives, and coatings, are more likely to outgas. Porous materials, such as foams and fabrics, can also release gases when exposed to a vacuum.
4. How can outgassing be minimized or prevented?
Outgassing can be minimized by choosing low outgassing materials and performing pre-conditioning treatments, such as baking or degassing, before using them in a vacuum system. Proper sealing and venting techniques can also help prevent outgassing.
5. What are the potential effects of outgassing on experiments or missions in space?
Outgassing can affect the performance of sensitive instruments and equipment in space, leading to inaccurate data or equipment failure. It can also cause contamination of surfaces in spacecraft and affect the health and safety of astronauts.
  • Materials and Chemical Engineering
  • Other Physics Topics
11K
  • Mechanical Engineering
