Oval Front Cog in Tour de France: Rumor or Fact?
  • Thread starter Shawnzyoo
  • Tags
    Cog
In summary, the oval chainring is a feature that has been introduced by Shimano in order to increase power and efficiency during a particular part of the cycling stroke. There is no guarantee that this modification will be without any adverse effects, but they are unlikely.
Shawnzyoo
105
this is just hearsay from another engineer
but i guess there is a guy in the Tour de France right now that is using an oval front cog for more downstroke power, and for an easier upstroke.
has anyone here heard of this?
i can't seem to find anything more on it
also would there be problems with the chain tension?
thanks
thanks
A number of years ago Shimano introduced their Biopace chain ring, which was oval in shape. The idea behind the oval chainring is to increase the effective gear ratio on the down stroke and make it lower at the bottom stroke. The shape of the chain ring wasn't quite as extreme as the one being used in the Tour though.
Chain tension shouldn't be a problem because the derailleur is designed to take up slack on the chain.
I remember those oval Shimano rings, they never really caught on for whatever reason.
The theory behind them is that when you're pedalling, there's a 'dead spot' (when your feet are at 12 and 6 o'clock) where you can't push on the pedals with as much force as, say, 3 and 9 o'clock.
An oval chain ring reduces the gear ratio during this 'dead spot', by effectively reducing the diameter of the chain ring, effectively increasing torque. When you're past the dead spot, at the part of the stroke where you can apply maximum power, the chainring diameter effectively increases. This can also reduce wind-up in full suspension bikes.
1. What is an oval front cog?
An oval front cog, also known as an oval chainring, is a type of bicycle chainring that is not perfectly round. Instead, it has an oval or elliptical shape, with a larger diameter at the top and bottom and a smaller diameter at the sides. This design is believed to provide a more efficient pedal stroke and reduce muscle fatigue.
2. Is it true that oval front cogs are used in the Tour de France?
Yes, it is true that oval front cogs have been used in the Tour de France. Some professional cyclists believe that it can improve their performance, while others have not seen any significant benefits. However, it is important to note that the use of oval front cogs is not widespread in the professional cycling world.
3. What are the potential benefits of using an oval front cog?
Proponents of oval front cogs claim that it can improve the efficiency of the pedal stroke by reducing the dead spots in the rotation and allowing for a smoother power transfer. This can lead to a more consistent and efficient pedaling motion, resulting in improved performance and reduced muscle fatigue.
4. Are there any drawbacks to using an oval front cog?
Some cyclists may find it difficult to adjust to the oval shape and may experience discomfort or even pain in their knees or muscles. Additionally, the oval front cog may not provide any significant benefits for all cyclists, and some may not notice any difference in their performance.
5. Is there any scientific evidence to support the use of oval front cogs?
There have been some studies that suggest that oval front cogs may provide small improvements in performance for certain cyclists. However, the evidence is not conclusive, and more research is needed to determine the true benefits and drawbacks of using oval front cogs in cycling.
  • Mechanical Engineering
  • General Discussion
  • STEM Academic Advising
23K
  • Art, Music, History, and Linguistics
