Overexpanded Flow: Low Temp Air Discharge at High Velocities
  • Thread starter sid_galt
  • Tags
    Flow
In summary, underexpanded flow can happen when the static pressure is greater than the ambient pressure. Oblique shocks at the outlet will lead to flow separation.
sid_galt
502
A VERY low temperature (like 100 K) air flow at high velocities (400 m/s - mach number around 2, static pressure = 34440 Pa) is being discharged into the ambient atmosphere (300 K, static pressure 1E5 Pa) through a converging-diverging nozzle.
Flow separation will take place due to oblique shock waves. My question is how far can the flow separation go? Will it exceed even the throat?
If the same air is being exhausted at much lower speed (100m/s - mach number around 0.5, static pressure = 34440 Pa), what will happen. Will the air refuse to go out or will a gradual temperature gradient form after the flow becomes steady.
No reply :cry:
How you're going to get low temperature flow at that velocity is a very good question, but let's keep going...
Can you rephrase this? I think I am just misunderstanding what it is you are after here. Oblique shocks in overexpanded flow are what will give a rocket/jet engine the characteristic shock diamonds in the exhaust. I don't think this is what you are referring to though.
Now it sounds like underexpaned flow. I think Clausius needs to tackle this one. I have no way to predict the flow.
Perhaps you might want to take a look at this applet:
http://www.engapplets.vt.edu/fluids/CDnozzle/cdinfo.html
Or this link:
http://www.aerospaceweb.org/question/propulsion/q0224.shtml
By cooling the air and using a fan to eject it out of a nozzle?
Well, since the mach number is greater than 1 and the flow has very low static pressure in comparision to the ambient pressure, wouldn't shock waves occur to compress the flow to increase its static pressure.
Wouldn't underexpanded flow be when the flow static pressure is greater than the ambient pressure. Here the static pressure of the flow in both cases is less than the ambient static pressure.
Can anyone help, please.
You know, Fred. I have a lot of work to do around here. I have an exam on Tuesday.
Ok. The flow is supersonic at the outlet, and the discharging pressure is less than ambient pressure. It would be oblique shocks at the outlet.
This is not completely true. Inside the nozzle, there is a negative static pressure gradient, so there is not a trivial cause for separation. Anyway in a real flow, and specially for diverging angles larger than 7º, it is almost sure a boundary layer separation due to rugosity of walls. Also, the supersonic flow inside the diverging part is not too fair. Such microscopic rugosity will cause small shock waves and maybe a further separation. Once the flow has been exerted out the nozzle, it doesn't make sense to talk about separation.
This is impossible. If the flow is subsonic at the exhaust, the pressure must be equal to ambient pressure, because pressure waves are able to travel upstream and so the flow will feel the atmosphere which is standing downstream.
What do you think about this?
Thank you for the reply.
You mean to say despite the extremely low static pressure, the flow separation will be caused by just the rugosity(viscosity?) of the walls?
Does that mean that supersonic flow is the ONLY way to discharge low pressure low temperature flow into the ambient atmosphere? Just confirming.
Usually, boundary layer separation is due to two factors: i) A positive pressure gradient, which difusses positive vorticity through walls. This is not the case, because a diverging geometry in supersonic flow causes a decreasing in static pressure. ii) Geometry, if the nozzle is well machined and has little rugosity, the flow could be considered near ideality, but in a real nozzle, the flow would be supersonically turbulent due to the high Re involved and the proper wall rugosity. The interaction between walls and flow in supersonic speed is a not well know field as far as I am concerned. Further separation could be caused via microscopic rugosity and the continuous shocks and expansion fans in the interface between external and internal boundary layer flow. There is an interaction between external flow which is supersonic, and the proper boundary layer which is subsonic. I think that some perturbation caused by wall surface may be transmitted to external flow causing shocks / expansion fans. But I am not an expert in this stuff. Take a look at some advanced book of Gas Dynamics.
If the jet is not confined, yes it is the only way. But do not include temperature in this issue. Temperature is not a mechanic boundary constraint. Any jet can be discharged into an atmosphere of different temperature. But none jet, except those supersonic, can modulate its discharge pressure to be different of the ambient one. Just one point: By ambient I am meaning an infinite atmosphere. It is not valid to consider as "ambient" a length of pipe of greater section or so. There must not be near any wall.
The reason of this is in the proper propagation phenomena of acoustic (pressure waves) which carry on the information about pressure flow. The flow in this range of Mach supersonic, has an hyperbolic behavior. This means that information is propagated via wave fronts with a finite speed of propagation. If the flow is supersonic at the outlet, any perturbation downstream will be convected before it can reach any zone of flow upstream. The supersonic jet "does not see" the ambient.
I understand. Thanks a lot for the help
What is overexpanded flow?
Overexpanded flow is a phenomenon that occurs when the pressure of a gas or fluid being discharged from a nozzle is lower than the ambient pressure. This results in the gas expanding rapidly and creating a shock wave.
What causes overexpanded flow?
Overexpanded flow is primarily caused by a mismatch between the nozzle's exit pressure and the ambient pressure. This can be due to a variety of factors such as improper design of the nozzle, changes in atmospheric conditions, or changes in the flow rate.
What are the effects of overexpanded flow?
Overexpanded flow can lead to a number of negative effects, including reduced thrust, increased drag, and decreased efficiency. It can also cause damage to the nozzle and surrounding structures due to the high velocities and shock waves created.
How is overexpanded flow controlled?
There are several methods for controlling overexpanded flow, including altering the design of the nozzle to better match the ambient pressure, using variable geometry nozzles, or implementing flow control devices such as ejectors or diffusers.
Where is overexpanded flow commonly encountered?
Overexpanded flow is commonly encountered in aerospace engineering, particularly in rocket and jet propulsion systems. It can also occur in other high-speed fluid flow applications, such as supersonic wind tunnels and gas pipelines.
  • Mechanical Engineering
  • Aerospace Engineering
