Oxygen + neutron = nitrogen ?
In summary: Most of the time it does a beta decay to oxygen, sometimes it emits an alpha particle at the same time.In summary, when water is exposed to a neutron flux, a process termed "neutron activation" occurs, which displaces the oxygen proton. This leaves the nucleus very excited, and can lead to the release of a proton.
cmb
1,128
128
I don't understand this line in iter website. How is this reaction possible?
"When exposed to the intense flux of neutrons from the fusion reaction, the oxygen present in the water generates short-lived radioactive isotopes of nitrogen—one (isotope 16) emitting a highly energetic gamma ray, the other (isotope 17) a fast neutron."
Is the neutron knocking out an oxygen proton, then? Is that very common, or the issue is the large neutron flux?
https://www.iter.org/newsline/-/3050
I also don't understand the decay mode; here is 16N in the wiki list of nitrogen isotopes;-
16N 7 9 16.0061017(28) 7.13(2) s
β− (99.99%) 16O
β−, α (.001%) 12C
I guess displacing the oxygen proton leaves the nucleus very excited?
I'd be grateful for any insight.
Lord Jestocost said:
When water is exposed to a neutron flux, a process termed "neutron activation" occurs: https://en.wikipedia.org/wiki/Neutron_activation
I would have though neutron activation was...
16O + n = 17O?
OK, I can see on that page there is an immediate release of a proton. Does this make an intermediate 17O, then, or is the proton just knocked straight out?
cmb said:
16O + n = 17O?
17O is stable. You get some of that, too, but that doesn't matter. The (n,p) reaction where the neutron kicks out a proton is more important because it leads to further reactions.
β− (99.99%) 16O
β−, α (.001%) 12C
Years ago I used to use a website where you could put in these sorts of reactions and it'd give you cross sections and things, I could have looked it up. But not sure where that is. Would you know a site/database I might be thinking of?
Various countries and the EU have nuclear data centers. In the US, the database is maintained at Brookhaven National Laboratory (BNL)
www.nndc.bnl.gov
For cross sections of elements/nuclides, see https://www.nndc.bnl.gov/sigma/
For some information on radionuclides, see https://www.nndc.bnl.gov/nudat2/
N-16 was a concern for some BWR using hydrogen injection in the feedwater. In a reducing environment, nitrogen is carried out of the core by the steam through the steam lines to the turbines. Some plants had to add additional shielding, or restrict areas near the steam lines to prevent worker exposure.
https://www.nndc.bnl.gov/nudat2/decaysearchdirect.jsp?nuc=16N&unc=nds
The (n,p) reaction in 16O has a neutron energy threshold of ~10.2 MeV, so the concern is primarily about the 14.1 MeV neutron from the d+t fusion reaction, which is the principal reaction planned for ITER.
@cmb, you might think about Newton's Cradle when thinking about these reactions. Because n and p have about the same mass, an n comes in and a p goes out. (This is modified by a bunch of nuclear physics, but it's a good starting point to visualize what happens)
www.nndc.bnl.gov
Thanks, that is super. Yes, EXFOR was the one I was thinking of.
I was thinking that, but does it happen most of the time in neutron capture, though, displacing p for n?
Given the number of nuclei and the large range of energies involved, "most of the time" is not well-defined.
cmb said:
neutron capture
'Neutron capture' by convention means that the neutron is absorbed and the nucleus of A increases in mass to A+1, e.g., 16O + n -> 17O (transmutation), and usually a gamma ray is emitted, a process called 'radiative capture'. The thresholds for (n,n'), (n,p), (n,α), or other reactions are usually in the MeV-range, typical of binding energies (of nucleons) of the target nucleus. We also observe photoneutron reactions for high-energy gammas, e.g., d+γ(~2.23 MeV) -> p+n, or 9Be+γ(~1.67 MeV) -> 2α + n, which is used in secondary neutron sources in nuclear reactors. The gamma source is 123Sb, which absorbs a neutron and becomes 124Sb, which then decays and emits a gamma of ~1.69 MeV.
https://journals.aps.org/pr/abstract/10.1103/PhysRev.80.309
https://inis.iaea.org/collection/NCLCollectionStore/_Public/14/792/14792880.pdf (~1982)
http://nuclear.ee.duth.gr/upload/2009 NIMS SbBe.pdf
When a high energy particle (e.g., neutron, proton, . . . ) interacts with a nucleus and knocks out particles, we refer to 'spallation', or sometimes 'fission'.
https://inis.iaea.org/collection/NCLCollectionStore/_Public/23/015/23015552.pdf
Also, in a nuclear reactor, besides the fission reactions and decays of fission products, absorption of neutrons leads to transmutation of structural materials, about which we have to be concerned.
1. What happens when oxygen and a neutron combine?
When oxygen and a neutron combine, they form a new element called nitrogen. This is a chemical reaction known as nuclear transmutation.
2. Is this reaction spontaneous or does it require energy?
This reaction requires energy in the form of high temperatures or intense radiation. It is not a spontaneous reaction.
3. What are the properties of nitrogen compared to oxygen?
Nitrogen is a gas at room temperature, just like oxygen. However, nitrogen is less reactive than oxygen and is often used as an inert gas in industrial processes. It also has a lower boiling point and density than oxygen.
4. Can this reaction occur naturally?
No, this reaction does not occur naturally on Earth. It can only be achieved in a laboratory setting or in extreme environments such as a nuclear reactor.
5. What are the potential uses of this reaction?
This reaction has potential uses in nuclear energy production, nuclear medicine, and scientific research. It can also be used to produce isotopes of nitrogen for various applications.
  • High Energy, Nuclear, Particle Physics
