Is the Velocity of Two Objects in a Head-On Collision Necessarily Zero?
  • Thread starter gcombina
In summary: D)?? if the momentum before was zero then for sure will be zero after, so why "may be zero"?In summary, two objects of equal mass traveling toward each other with equal speeds undergo a head on collision. Their velocities after the collision may be zero.
gcombina
157
Two objects of equal mass traveling toward each other with equal speeds undergo a head on
collision. Which one of the following statements concerning their velocities after the collision is
necessarily true?
A) They will exchange velocities
B) Their velocities will be reduce
C) Their velocities will be unchanged
D) Their velocities will be zero
E) Their velocities may be zero
I know the answer is E but why? What I understand is that when 2 cars collapse head on, they go backwards
They both go backwards? Or one goes backwards and one keeps going forward?
Likes 1 person
Suppose the first mass is a glob of glue, and the second mass is a baseball. Since they stick together on contact (a perfectly inelastic collision) no bouncing can occur, so instead of exchanging velocities (like billiard balls), they combine velocities*. Since they were going equal speeds in opposite directions, the sum of the velocities would be zero.
*The "equal masses" part is important here!
The keywords are "necessarily true" and "may be zero". The momentum is always conserved. As the initial momentum was zero (equal masses, equal and opposite velocities) the final momentum is also zero. That happens if the final velocities are also equal in magnitude and opposite. The magnitude of the final velocities may be zero.
ehild
and why "may be" why not, "will be zero" (answer D)?? if the momentum before was zero then for sure will be zero after, so why "may be zero"?
I think it's because, as you said, they could move backwards (if it's somewhat elastic) and still have a total momentum of zero
That's the only thing I can think of
Read the whole sentence including the subject. "D) Their velocities will be zero"
"E) Their velocities may be zero"
The subject is "The velocities" and not "the sum of the momenta".
The overall momentum is zero, and it stays zero if both objects travel with opposite velocities of equal magnitude. The magnitude might be even zero.
ehild
1. What is a collision?
A collision occurs when two objects come into contact with each other, resulting in a change in their motion or state.
2. What factors affect the outcome of a collision?
The outcome of a collision is affected by the mass, velocity, and direction of the colliding objects, as well as the type of material they are made of.
3. How is the velocity of objects after a collision calculated?
The velocity of objects after a collision can be calculated using the law of conservation of momentum, which states that the total momentum before the collision is equal to the total momentum after the collision.
4. What happens to the kinetic energy during a collision?
Kinetic energy is not conserved during a collision, as some of it is typically converted into other forms of energy such as heat or sound.
5. Can two objects collide without touching?
Yes, two objects can collide without physically touching each other. This is known as an inelastic collision, where the objects come into close proximity and exchange energy without making contact.
