<p> and <p^2> for uniform psi
  • Thread starter bjnartowt
<p> and <p^2> for uniform "psi"
What is <p> and <p^2> for state:
[tex]\begin{array}{l}
\psi (x) = {\rm{constant for x}} \in {\rm{[ - a,a]}} \\
\psi (x) = {\rm{0 for x}} \notin {\rm{[ - a,a]}} \\
\end{array}[/tex]
....that is: a "psi" that is constant within a finite region [-a, +a], and zero everywhere else. (No calculus required!).
[itex]\left\langle {{p_x}} \right\rangle = \left\langle {\psi \left| { - {\bf{i}}{\textstyle{\partial \over {\partial x}}}} \right|\psi } \right\rangle [/itex]
[itex]\left\langle p \right\rangle ,\left\langle {{p^2}} \right\rangle = 0[/itex]
...right? I think so, because d/dx(constant) = 0. For a wavefunction that doesn't change, you have a particle that ain't moving, right? I think this is a simple question, but I'm having a dropped-brain moment... :-p
Oh yes: if <p> and <p^2> = 0, then: momentum is exactly known to be 0, so why isn't position-uncertainty infinite?
Answers and Replies
<p>=0, because of symmetry. It is equally likely to go left as right.
However, that doesn't mean the average *speed* is zero.
Just because there is no wind in a room doesn't mean the air is frozen.
By the way, the first of your equations was cut off, at least on my browser.
I would guess integrate by parts?
However, that doesn't mean the average *speed* is zero. Just because there is no wind in a room doesn't mean the air is frozen. I would guess integrate by parts?
Thanks for your response, Cruikshank.
Anyway, it's entirely-correct that the air in the room I'm in is in motion, despite there being no wind.
Now, I sure would integrate by parts, but:
[tex]\hat p\hat p = - {\hbar ^2}{\textstyle{{{\partial ^2}} \over {\partial {x^2}}}}[/tex]
...so I'm differentiating a constant. That would make the integrand zero.
Oh! I think I thought the integral would come out zero, but I'm wrong: it would be constant. Perhaps:
[tex]\left\langle p \right\rangle \ne 0[/tex]
...after all, meaning we are both wrong.
But then: would we be left with the same or different constants of integration for <p> and <p^2>? They would need to be different to avoid violating uncertainty principle....no?
I think I deviated a bit from what you initially suggested, but you are helping me think out loud, so I'm glad for your post.
And yes: the LaTeX I write tends to get cut off. Why: I do not know.... :-p
vela
Staff Emeritus
Education Advisor
15,224
1,827
You need to consider the endpoints. What happens at x=a and x=-a? The problem is that your wavefunction isn't a valid one. Wavefunctions and their first derivatives should be continuous. One exception to this is when you have an infinite potential. In that case, the first derivative may be discontinuous at boundaries, but the wavefunction is still continuous everywhere.
Oh! I had forgotten about the continuity of the wavefunction at the boundaries. Now that I think about it: the state I described: a constant-valued wavefunction in some finite interval and zero everywhere else is contrived, rather than a physical-consequence. In fact: when a particle is placed in a finite interval with infinite-confining-power, why, you get standing waves (infinite-potential well), so you're right: the wavefunction isn't valid after all. It's just contrived.
Hey, wait: it seems we needn't apologize for the infinite potential well as a possible exception to the first-derivative rule. The derivative of the cosine function (the standing waves) is the sine-function: ain't that zero at the boundaries of the infinite potential well?
I know we're getting off-track, but it's helping me to discuss these things. I'm beefing up for the Physics GRE.
vela
Staff Emeritus
Education Advisor
15,224
1,827
Try drawing the lowest mode for the infinite square well and then sketch its derivative. You'll see it's discontinuous, and you should be able to see it'll be discontinuous for all the modes.
collinsmark
1,530
Hello bjnartowt,
Be careful. That's not necessarily true! :smile:
It is true that the potential of an infinite square well is contrived. But this problem doesn't seem to even mention what the potential is. It merely talks about the wave function itself.
And it does not state that the wave function is one of the energy eigenstates. The wave function could very well be (and in general, since no other qualifiers were given, can be assumed that it is) a superposition of energy eigenstates.
If the Hilbert space for this system is complete, it's quite possible that the valid wave function shapes are pretty nearly anything you can imagine (as long as the shape is square integrable, etc), via superposition of energy eigenstates. This is similar to how you can create pretty much any mathematical waveform that you can easily imagine using sines and cosines using the Fourier series and Fourier transforms.
Speaking of Fourier transforms, I think one possible method you could use to solve this problem is to recognize that
[tex] \Phi(p) = \frac{1}{\sqrt{2 \pi \hbar}} \int _{- \infty} ^\infty \psi (x) e^{-ipx/\hbar}dx [/tex]
and then solve for <p> and <p2> using Φ(p) using standard means. But I don't recommend doing that for this problem. Your original approach (shown in your relevant equation), is probably a lot simpler.
I suggest instead, start with the wave function as represented by [itex] \psi (x) [/itex]. Plot it on a piece of paper. Then plot [itex] \partial / \partial x [/itex] of that. Note that the derivative of a step function is a Dirac delta function. Do the same thing one more time. Note the derivative of a Dirac delta function is two Dirac delta functions, one going up, and other going down, both very close together.
Use your plots in part to find <p> and <p2> which involves a little multiplying, and summing the sections of area that are not zero (which is actually pretty easy in this case -- you just need to eyeball the figures). :wink:
[Edit: Just so we're on the same page, the relevant equation you should be using for <p> is
[tex]
\left\langle {{p_x}} \right\rangle = \left\langle {\psi \left| { - {\bf{i} \hbar}{\textstyle{\partial \over {\partial x}}}} \right|\psi } \right\rangle
[/tex]
and <p2> is
[tex]
\left\langle {{p^2_x}} \right\rangle = \left\langle {\psi \left| { - \hbar^2}{\textstyle{\partial ^2 \over {\partial x^2}}}} \right|\psi } \right\rangle.
[/tex]
I think you might have missed an [itex] \hbar [/itex] in the relevant equation in the original post.]
Related Threads on <p> and <p^2> for uniform psi
  • Last Post
  • Last Post
14K
  • Last Post
20K
  • Last Post
  • Last Post
16K
  • Last Post
  • Last Post
  • Last Post
